diy panel due
hi after tinker around with the duet i have add a raspberry pi to stream a cam trough octoprint
make me think that i have a raspberry pi touch display so i wonder can i make a better panel due with bigger display than panel due I7 do any one have a idea or know how to help
you could just display the dwc in a browser window on the pi display.
@poohzaza said in diy panel due:
make me think that i have a raspberry pi touch display so i wonder can i make a better panel due with bigger display than panel due I7 do any one have a idea or know how to helpYes you could do that; but it might be easier to run Duet Web Control on the Pi.
@dc42 hi dose the duet web control support touch screen display and cam stream
Yes.
how to conect duet 2 wifi to raspberry and run duet web interface
The Duet 2 Wifi doesn't connect to a raspberry pi natively. The web interface runs on the Duet itself. It's already on there, you just connect to it.
https://duet3d.dozuki.com/Wiki/Step_by_step_guide
It is possible to use a raspberry pi running octoprint and connecting to the Duet via USB allowing the octopi to completely control printing, but that isn't recommended for a few reasons. You lose a lot of the nice features of the Duet and printing over USB is prone to issues.
Yes, you connect the Duet to the network and then connect to the Duet through its ip address in a browser.
i want to connect by panel due port and have a direct connection via a wire in serial what should i do
Buy a PanelDue, or create/write the equivalent.
The physical port is 3.3V TTL Async Serial. The data that flows over it is G and M codes, and JSON responses. Easy.
