Keenovo 220V Configuration
  • Hi, Today I'm configuring my heated bed, I'm receiving 2000° of temp, the wiring is ok, i tried to move the bed connector on extruder connector and it works.
    My conf file is this:
    M550 P"RatRig CoreXY" ; set printer name
    M667 S1 ; select CoreXY mode
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P2 S0 ; physical drive 2 goes forwards
    M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm
    M566 X600 Y600 Z60 E600 ; Maximum jerk in mm/min
    M203 X12000 Y12000 Z1200 E2500 ; set maximum speeds (mm/min)
    M201 X900 Y900 Z60 E1200 ; set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X300 Y300 Z300 S0 ; set axis maxima
    ;M574 X1 Y1 Z1 S1 ; set active high and disabled endstops
    M574 X1 Y1 S1 ; set active high and disabled endstops
    M574 Z1 S2 ; set endstops controlled by probe
    M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
    M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P25 X-28 Y-37 Z1.88 ; set Z probe trigger value, offset and trigger height
    M557 X15:215 Y15:195 S40 ; define mesh grid
    ;M140 H-1 ; disable heated bed
    M305 P0 T100000 B3950 R4700 H0 L0 ; set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
    ; Hotend
    M143 S240 ; max hotend temperature to 240C
    M307 H1 A282.1, C183.5, D10.4 S0.6 ; PID heather
    M305 P0.6 X100 ; heater P1/H1 on channel 1
    M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    ; Firmware Retraction & Pressure Advance -----------------
    M207 S0.5 R-.1 F5400 T5400 ; Firmware Retraction : Positive S retracts, negative R unretracts (possitive R extra-extrudes)
    ; F retract speed, T unretract speed, Z zlift - Slicer must insert G10 & G11
    M572 D0 S0.05 ; Pressure Advance, acts like 'coast' in Simplify 3D.
    Thanks
  • @Dav said in Keenovo 220V Configuration:
    Im not 100% sure but i think you don't need the H and L parameter for the bed
  • ; Heaters
    M305 P0 T100000 B3950 R4700 ; set thermistor + ADC parameters for heater 0
    I've changed it but same, I see 2000°
  • What type of thermistor is it?
  • @jay_s_uk
    Keenovo 300x300mm 220V 750W Silicone Heater Bed Pad w/ NTC 100K Thermistor
  • did you use a thermocouple or PT100 ? if not i think you don't need this M305 P0.6 X100 ; heater P1/H1 on channel 1
  • @SIam said in Keenovo 220V Configuration:
    thermocouple
    no nothing i only connected the bed withe the wiring scheme and a solid state relay
    Genuine DELIXI SSR 40A480VAC Solid State Relay Input 3V~32VDC 40DA
    so what i've to change in the code?
    remove this :
  • Check the thermistor input by connecting JUST a 100k resistor. The reading should then be 20 degrees.
    This would confirm your code is correct and the issue lies with your wiring.
  • @SIam
    It workssss! Thanks a lot!
    Do you know if I need to do pid tuning for the bed?
  • yes it makes sense
