Z axis off, Layers to tall.....
  • my layers appear to tall on Z all holes that should be circles are elongated to ovals, so im pretty sure my Z axis stepping is off... how to determine the correct settings for Z ? so how does one caluclulate the proper stepping for Z scews
    M569 P0 S0 ; physical drive 0 goes forwards
    M569 P3 S0 ; physical drive 3 goes forwards
    M569 P4 S0 ; physical drive 4 goes forwards
    M584 X0 Y2 Z1:4 E3 ; set drive mapping
    M92 X80.00 Y80.00 Z1600.00 E420.00 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X800 Y800 Z800 E800 I80 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
  • @dingo007 Some details of your machine might be useful! Is it a commercial machine you're converting, or building yourself? Are Z motors 1.8º (200 steps per rotation) or 0.9º (400 steps per rotation)? What does the Z leadscrew look like?
    There's a leadscrew calculator built in to the RepRapFirmware configurator on the motors page https://configtool.reprapfirmware.org/ or use the Prusa one https://blog.prusaprinters.org/calculator/#stepspermmlead
  • @droftarts in Marlin it was set as below. The machine is home built, not commercial branded, the Z motors are 1.8 the Z screw looks like a normal z screw, nothing odd.
    • Default Axis Steps Per Unit (steps/mm)
    • Override with M92
    •                                  X, Y, Z, E0 [, E1[, E2...]]
    #define DEFAULT_AXIS_STEPS_PER_UNIT { 160, 160, 1600, 185 }
  • They are based on the pitch of the lead screw.
    So if you haven't changed something at the drive the values doesn't change.
    Maybe there is to much friction....
    To calculate you can use the online config tool.
    In the motor tab click into the value of steps per mm.
  • @dingo007 said in Z axis off, Layers to tall.....:
    Override with M92
    What was the microstepping in Marlin? You halved the X and Y steps per mm. The pitch of the thread on the Z screw is the important thing, saying "the Z screw looks like a normal z screw, nothing odd" doesn't help define what it is at all; there's a huge range. If you don't know, post a picture.
  • @droftarts sorry i dont see any microsteppings in marlin config.... ! ive uploaded a photo, also i note, i measured the with of the circle printed it was 4.5, the length top/bottom of the elonagted side was 9, so im just guessing here that i need to cut my step in half somehow, now trying to narrow down the screw i have looking at RR config the only one that makes sense with new steps of 800 is trapezoid 20200110_075159.jpg image url)
    Strange.. I was thinking about some tenth....
  • @DIY-O-Sphere nope, i can assure you its way out.... X and Y seem fine.... but Z is definitly off 20200110_081231.jpg
  • So I think Ive nailed it, taking a guess at editing the Z steps... measuring the width says 4.5mm however circle height was 9... by my calculation that says i am 100% over stepping, playing with the variables in RR config and not knowing the screw pitch, i can determine that Trapezoid TR4 gives my the exact 800 number which is 50% of the 1600 it was originally set at. So i reset it to 800, and printed a 20x20x20 XYZ test cube... and it came out as perfect 20x20x20.... so looks like i nailed it and my Z screws are Trapezoid TR4. So consider this fixed.... now onto adding my second Z end stop.
    M92 X80.00 Y80.00 Z800.00 E420.00 ; set steps per mm
    before you do please read
    https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
    that is a better and easier solution
  • @Veti thanks, ive read the document, though i dont see alot of information about dual Z endstops also
    theres also this so im still a bit confused
    https://duet3d.dozuki.com/Guide/Independent+Z+motors+and+endstop+switches/18
    the point is that you dont really need dual z endstop.
    the bed is probed and the height is adjusted to truely level the bed.
    if you really want dual z endstop you should update to rrf3
    see
    https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3
  • ... how does a single end stop provide a truey level bed.... it cant, it requires 2+ to level both sides.... as for using RR3 id like to once i get it all configured properly... and i looked at rr config for 3 and it doesnt appear to function.
    not by using an endstop, but a probe.
    the dual endstop feature is only really supported in rrf3
    there is a workaround in rrf2 by splitting the axis up during homing, but there is no point setting that up anymore in my opinion.
