    Duet Buddy - a proof of concept remote monitor
    85
    8.0k
    • zaptaundefined
      zapta @jay_s_uk
      The github repository has now a script to download the firmware to a M5Stack Core. For now it's only for windows but writing a similar shell script for Mac or Linux should be easy.
      With this script, the Arduino IDE is not needed anymore (unless if you want to make code changes) and it just requires the Silicon Labs USB/Serial driver (available at m5stack.com and silabs.com).
      https://github.com/zapta/misc/tree/master/duet3d_buddy/release
      Please let me know howit works and feel free to send me pull requests.
      • tekkydaveundefined
        tekkydave
        It's arrived ๐Ÿ™‚
        ~ tekkydave ~
        D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
        FreeCAD, PrusaSlicer
        • hayseed_byteundefined
          hayseed_byte @zapta
          Very cool project!
          Is there a way to do something similar but display the status of multiple printers on a computer monitor? Maybe with the use of a raspberry pi? I have nine printers that I'd like to monitor from another room but I don't want to buy nine of those. ๐Ÿ˜„
          https://wildbot.me/wildbot
          Gcode Definitions for VSCode extension: https://github.com/hayseedbyte/rrf-gcode-definitions
            Phaedrux Moderator @hayseed_byte
            @hayseed_byte Perhaps something like this?
            https://github.com/DanalEstes/MultiDuetWebMonitor
            hayseed_byteundefined 1 Reply Last reply Reply Quote 1
              hayseed_byte @Phaedrux
              @Phaedrux That's perfect. Thanks! Don't know how I haven't come across that.
              • Danalundefined
                Danal
                I've never tried it, but that should run just fine in a Pi browser. Let me know if it does not.
                PM here, or danal (dot) estes (at) gmail (dot) com
                • richardmckennaundefined
                  richardmckenna
                  @zapta any chance you could move the duet buddy code to its own repo? It would make it easier to fork without pulling all your other misc stuff as well ๐Ÿ™‚
                    richardmckenna
                    I did something!
                    I added a battery level indicator and the printer name. Strangely the M5Stack API only returns the battery level in increments of 25, not sure if there is a way to get round this by skipping the M5Stack API method and going straight to requesting it from the I2C. Will have to look into it more, but from what I can discern from the basic docs and the Chinese datasheet for the IP5306 it only returns 1 of 4 values depending on the voltage range.
                    This is the current method in the API:
                    // Return percentage * 100
                    int8_t POWER::getBatteryLevel() {
                      uint8_t data;
                      if (M5.I2C.readByte(IP5306_ADDR, IP5306_REG_READ3, &data) == true) {
                        switch (data & 0xF0) {
                          case 0x00:
                            return 100;
                          case 0x80:
                            return 75;
                          case 0xC0:
                            return 50;
                          case 0xE0:
                            return 25;
                          default:
                            return 0;
                      return -1;
                    I also don't quite know what is happening with the switch statement and data & 0xF0but that's just my lack of C++ knowledge and IC programming. So if someone can educate me that would be great ๐Ÿ˜‰
                    I'm going to try adding the charging status as well for when it is plugged in and maybe tweak the layout a bit, then if someone can test it, I'll create a pull request to Zapta's original ๐Ÿ™‚
                    zaptaundefined 1 Reply Last reply Reply Quote 0
                    • zaptaundefined
                      zapta @richardmckenna
                      @richardmckenna, very nice!
                      The IP5306 seems to have only 25% increments for the LEDs and possibly the IP5306_I2C has the same resolution but with I2C interface instead of LEDs. Hard to find information about the IP5306_I2C.
                      M5Stack Schematic
                      http://community.m5stack.com/assets/uploads/files/1515402963959-97994060-2969-49dc-ad9c-7b3887d95a17-image.png
                      IP5306 (non I2C) Datasheet
                      https://datasheet.lcsc.com/szlcsc/1809201029_INJOINIC-IP5306_C181692.pdf
                      The expression (data & 0xF0) returns the 8 bit value of 'data' with the four right bits forces to '0'.
                      BTW, the two temperature fields in your picture seems to have extra characters. Is it intentional?
                      richardmckennaundefined 1 Reply Last reply Reply Quote 0
                        richardmckenna @zapta
                        @zapta said in Duet Buddy - a proof of concept remote monitor:
                        Yeah that is all I could find. Oh well 25% increments are better than nothing. Iโ€™ve added a charging status now as well so when it is plugged in it shows โ€œChargingโ€ and when full โ€œChargedโ€.
                        That was me trying to find the degrees symbol only to discover it doesnโ€™t exist in the included font. It seems to be standard ASCII with only some of the extended ASCII characters. Iโ€™ve given up on that and removed them.
                        • zaptaundefined
                          @richardmckenna, how did you implement the 'Kossel Max' title? Is it hard coded in your arduino code? One option is to add a title field to the config file on the SD card.
                          Or, anybody knows if it's possible to query the printer name from the printer using a HTTP request?
                          richardmckennaundefined 2 Replies Last reply Reply Quote 0
                            @zapta I added an extra field to the json file and parsed it like the others. Didnโ€™t even think about pulling from the duet, I will explore that possibility.
                            The reason behind me wanting the name displayed was that Iโ€™m thinking about the best way of adding multiple machines to it. So having an array of machine objects defined in the json. Then you can navigate between the different machines with the left and right buttons.
                              @zapta The printer name is available through /rr_status?type=2 so should be easy enough to do an initial call to that to get the name and other info about the printer.
                                In the forthcoming RRF 3.01-RC2 it's also available via M409 K"network.name".
                                zaptaundefined 1 Reply Last reply Reply Quote 1
                                • zaptaundefined
                                  @richardmckenna, if type=2 has also the other relevant information we can just switch to it instead of type=3.
                                  Does it require changes in the duet response json parser?
                                  • zaptaundefined
                                    zapta @dc42
                                    @dc42 said in Duet Buddy - a proof of concept remote monitor:
                                    Thanks for the info. This require posting gcode to the duet, right? What is a reasonable and simple way of doing it?
                                    Once we figure this out it will be useful for other functionality such as pressure-advance up/down buttons for interactive experimentation.
                                      @zapta type 1,2 and 3 all seem to share some information but unfortunately not all the bits we are are looking at.
                                      status-type-1.json
                                      status-type-2.json
                                      status-type-3.json
                                      So I think it would need a single call to 2, to get the name and repeated calls to 3 as it currently does.
                                      the duet parser will need tweaking as it only looks for:
                                      char state_char;
                                      float progress_percents;
                                      float z_height;
                                      float temp1;
                                      float temp2;
                                      But that's straight forward. And if the JSON config file is changed just to have the IP, the rest of the URL can be provided by the code depending on which call it is doing.
                                      I will continue to have a play with it, see what I can do.
                                      You can see my updated battery code in my fork here https://github.com/richard-mckenna/misc/tree/master/duet3d_buddy/arduino
                                      Would you be able to separate Duet Buddy into it's own git repo?
                                      • zaptaundefined
                                        zapta
                                        Hi Richard, I create a separate duet_buddy repository here https://github.com/zapta/duet_buddy
                                        If you will send me your github id I can add you as a contributor.
                                        richardmckennaundefined 1 Reply Last reply Reply Quote 1
                                          @zapta excellent thanks. GitHub id is just "richard-mckenna".
                                          • zaptaundefined
                                            @richardmckenna, sent you an invite via github.
                                            Please feel free to touch anything, including the project page and documentation files.
