    Show me your duet 3 enclosures!
    duet3 enclosure
    18
    35
    683
    • oliof
      oliof last edited by
      While there are a number of duet2 enclosures out on the internet, duet3 enclosures seem to be scarce. Who has one they want to show off?
        Still working on one.
        • garyd9
          garyd9 last edited by
          I whipped up a couple of brackets to mount the duet3 under the print bed of my delta printer. In that sense, it's really not enclosed at all.
          • oozeBot
            oozeBot last edited by
            Still working on this, but here is my v1 mock-up..!
            • Chasedog
              Chasedog last edited by
              Got this one done and I left the STEP file: https://www.thingiverse.com/thing:4231655
              • mwwhited
                mwwhited last edited by
                I was thinking about designing and printing brackets and then I remembered I had a pile of acrylic glass left over from another project. The cover for the high voltage connections is my first hand formed acrylic... took several tries and isn't very sexy but it gets the job done.
                I have alot more upgrades planned... sucks that this world wide lock-in has caused the majority of my part orders to be canceled or delayed.
                • Psylenceo
                  Psylenceo last edited by
                  I feel the need to add cooling I just haven't figured how I want to do it though. I also have not printed it yet.
                  • jumpedwithbothfeet
                    jumpedwithbothfeet last edited by jumpedwithbothfeet
                    Finally posted my enclosure on Thingiverse, Iโ€™ll be making further refinements but itโ€™s mostly there, Iโ€™m really happy how the logo came out, any suggestions Iโ€™m happy to hear them ๐Ÿ™‚
                    https://www.thingiverse.com/thing:4307535
                    #edit I have unfortunately had to close my account on thingiverse due to the recent hacking etc Iโ€™ll attach the latest STLs to this post soon for those who want them ๐Ÿ™‚
                    335A3CCF-9F2A-4B73-8F14-A9DB29940A1E.jpeg 3075DBE0-8EC4-4102-A72F-AC3A41D112B2.jpeg 1129D221-9A16-42B6-9D2B-DBF33ABFA64E.jpeg
                    jumpedwithbothfeet 1 Reply Last reply Reply Quote 1
                    • CCS86
                      CCS86 last edited by
                      DocTrucker mwwhited 3 Replies Last reply Reply Quote 0
                      • DocTrucker
                        DocTrucker @CCS86 last edited by
                        @CCS86 I presume that PSU is heavily modified? The fans tend to exhaust in that location and you've got the fan blowing in?
                        CCS86 1 Reply Last reply Reply Quote 0
                        • DocTrucker
                          DocTrucker @CCS86 last edited by DocTrucker
                          @CCS86 ...but since you suck ( ๐Ÿ˜ฎ ) you could consider adding fan filters so dust doesn't clog up the back side of the duet. Nice fan ducting though, food for thought! ๐Ÿ™‚
                          • mwwhited
                            mwwhited @CCS86 last edited by
                            That's not a duet3 ๐Ÿ˜‰ ... pretty nice looking enclosure anyway. I was debating between plywood and acrylic for my baseplate.
                            • CCS86
                              CCS86 @DocTrucker last edited by CCS86
                              @DocTrucker said in Show me your duet 3 enclosures!:
                              It isn't modified besides the fan replacement. The original fan also blew into the power supply like this, but it was loud. Most axial fans are setup to blow through, not pull.
                              I could, but I'm not too worried about it. There is nothing to "clog up" on the back side of that PCB.
                              @mwwhited said in Show me your duet 3 enclosures!:
                              Whoops, it's too early!
                              But the same concept applies, regardless of the board.
                              DocTrucker 1 Reply Last reply Reply Quote 0
                              • DocTrucker
                                @CCS86 there's no pattern to it. I've got your power supply and indeed it does suck in.
                                The 500W meanwell has a fan on the top edge that sucks out, and a 200W meanwell as well as a 350W no name suck in.
                                • Danal
                                  Danal last edited by
                                  Not strictly speaking an enclosure, this is the back of a "Jubilee" tool changing printer:
                                  • mwolter
                                    mwolter last edited by
                                    Remixed a case for the Duet 2 that I found quite good. It provides ample natural cooling, cable access and the lid swings out of the way. Also includes mounts for a 92mm and 40mm fan, even though fans are not necessary if using typical NEMA 17 steppers.
                                    https://www.thingiverse.com/thing:4308292
                                    • CCS86
                                      You can't "suck in". It is "blowing in" regardless of whether the fan is mounted flush to the inside or outside of the enclosure.
                                      • DocTrucker
                                        @CCS86 you're being pedantic, I am merely indicating direction.
                                        Anyhow whats the problem? I was merely saying even with one manufacturer the airflow direction isn't consistent. Hence my original confusion with the direction of your fan.
                                        • gtj0
                                          gtj0 last edited by
                                          From https://forum.duet3d.com/topic/14883/black-beauty-arises
                                          • mwolter
                                            mwolter last edited by mwolter
                                            @gtj0 Impressive! Shielded stepper cables?
                                            Planning to install a Pi once DSF is a little more stable. Curious what pins you connected from the D3 to the Pi. Interested in only using whatโ€™s necessary and leaving the rest for future GPIO.
                                            PS Your bearing block on the Z lead screw is a great idea. Might have to steal that one ๐Ÿ˜‰
                                            DocTrucker gtj0 2 Replies Last reply Reply Quote 0
                                            • DocTrucker
                                              DocTrucker @mwolter last edited by DocTrucker
                                              @mwolter check out the schematics. The required connections are listed there. If you supply an isolated external 5v (negating need for the +5V cores) to the Pi I'm not sure if it would be possible to save on a few of the negative connections too.
                                              Edit: if you do use an external supply for the pi ensure the dc negative isn't directly linked to earth as you could set up an earth loop with considerable current if your main psu is earth tied.
                                              A Former User 1 Reply Last reply Reply Quote 0
                                              • A Former User
                                                A Former User @DocTrucker last edited by A Former User
                                                earth loop
                                                drew up an isolator (back in January) but haven't had a chance to test it (nor decided weather to add a 3.3v ldo instead of a 3.3v header)
                                                suppose could create a new topic to discuss if there is interest. (edit, changed to ADuM1200BR to allow 10mbps, ISO7721DR seems to be pin compatible and i'll do a test with that)
                                                Moved it to a a less personal EasyEDA account, https://easyeda.com/bearer/duet36hc-isolator
                                                DocTrucker arhi 2 Replies Last reply Reply Quote 2
                                                • DocTrucker
                                                  DocTrucker @Guest last edited by
                                                  @bearer nice work!
                                                  • arhi
                                                    arhi @Guest last edited by
                                                    @bearer isn't 1200 "not for new designs" replaced with 120n ?
                                                    • A Former User
                                                      A Former User @arhi last edited by
                                                      @arhi said in Show me your duet 3 enclosures!:
                                                      quite possibly, I just picked what jlcpcb could assemble today (initially the 1mbps part because it was in the basic selection)
                                                      i would suspect any new parts to be pin compatible so not something i put much thought into tbh.
                                                      arhi 1 Reply Last reply Reply Quote 0
