    Wifi not connecting
    844
    • Paddyundefined
      Paddy
      Full disclosure: I have a Duet Wifi 1.03 clone.
      If after my disclosure you would still like to assist - this is my problem.
      My board is about 1 year old. Last night I was connecting fine to DWC then this morning I couldn't.
      I'm running the latest FW 3.01-beta3 and wifi 1.23.
      I get the following errors randomly;
      Error connecting to xxxxxx
      Bad format
      no known networks found.
      I have re-flashed the firmware by placing it on the sdcard and running M997 S0 and M997 S1.
      I also used the erase button and then used bossa to reload the firmware.
      Nothing has helped.
      Debug ;
      m122<CR>
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-beta3 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9T6BU-FG3S4-6J1F8-3SN6L-1VNZG
      Used output buffers: 1 of 24 (11 max)
      Static ram: 27988
      Dynamic ram: 92792 of which 40 recycled
      Exception stack ram used: 304
      Never used ram: 9948
      Tasks: NETWORK(ready,1272) HEAT(blocked,1240) MAIN(running,1612) IDLE(ready,76)
      Owned mutexes:
      Last reset 00:06:13 ago, cause: software
      Last software reset time unknown, reason: User, spinning module GCodes, available RAM 9948 bytes (slot 0)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 25.7, current 26.0, max 26.4
      Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      Cache data hit count 531601002
      Slowest loop: 1.25ms; fastest: 0.10ms
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is ready with "m122" in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1.03ms; fastest: 0.00ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 0 of 8
      - WiFi -
      Network state is changing mode
      WiFi module is trying to connect
      WiFi firmware version 1.23
      WiFi MAC address cc:50:e3:4a:b8:38
      WiFi Vcc 3.38, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 28264
      === Filament sensors ===
      Extruder 0 sensor: ok
      ok
        https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors
        Try this part
        If unable to connect to your wireless network at boot up, try deleting all saved wifi networks with M588 S"*" (That is, using an asterix for the network name), then re-adding it with M587. For example, M587 S"networkname" P"password".
        You can manually reset the wifi module if you have console access via USB, or a PanelDue. Send M552 S0, to disable networking, followed by M552 S1 to enable networking.
        • SIamundefined
          SIam
          Have you tried to re add your network M587 ?
          have you tried to reset your wlan router? and last change the W-lan Channel in your router
          Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
          Duet WiFi 1.02 or later + DueX5
          RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
          Duet WiFi Server: 1.26
          Duet Web Control 3.4.0beta4 (2021-09-27)
          • Paddyundefined
            Paddy
            Thanks for the replies.
            @Phaedrux - Sorry I should have said that I had tried forgetting the save networks and then putting it back in. No joy.
            @SIam - I did reboot my AP and firewall but this didn't help. I've just created a new ssid for testing but got the same results. Also no other devices are having problems.
            As a test I set my mobile to be an AP and the duet wifi wouldn't connect to that either.
            I was thinking it might be hardware as I was seeing
            Error retrieving WiFi status message: bad reply format version
            but as a final test I put the card into AP mode and this worked fine - I could connect and then reach the DWC.
            Putting it back to client mode and it won't connect.
              Try reflashing the wifi server?
              Paddyundefined 1 Reply Last reply Reply Quote 0
              • Paddyundefined
                Paddy @Phaedrux
                @Phaedrux said in Wifi not connecting:
                I have reflashed the WiFi server. Didn't help
                • SIamundefined
                  SIam
                  have you tried to flash the latest stable rrf version 3.0?
                    When connected to a USB terminal, send M98 Pconfig.g and see if you're getting any errors on execution.
                    • Paddyundefined
                      Paddy
                      I really want to thanks both of you guys for taking the time to help.
                      @Phaedrux M98 Pconfig.g returned no errors.
                      @SIam I flashed fw 3.0 but still got the error. I reflashed wifiserver 1.23 but still couldn't connect. Finally I deleted my known network and reapplied it and this time it connected no problem.
                      It's a strange one as it was connecting fine with 3.0-beta3 until it stopped for seemingly no reason.
                      I think I'll stay with 3.0-release for the time being.
                      • A Former User?
                        A Former User
                        This thread deals with something similar, suggested bad wifi module. But maybe you can verify you've tried the suggestions there
                        https://forum.duet3d.com/topic/10139/failed-to-add-ssid-to-remembered-list-duet-2-wifi
                        • Paddyundefined
                          Paddy @A Former User
                          @bearer said in Wifi not connecting:
                          I was thinking that was the problem, but then it worked in AP mode so that cast some doubt in my mind.
                          Anyway after multiple re-flashes and networks deleted and added it has started to work again.
                            Maybe the firmware is revolted by being on a clone. 😰
                            • Paddyundefined
                              Paddy @Phaedrux
                              @Phaedrux Possibly 🤣
                              I was upfront about using a clone and therefore appreciate the help given.
                              • A Former User?
                                A Former User
                                The majority doesn't care one way or the other, but it's nice to know as component quality can be a factor.
                                I haven't studied the protocol between the esp and the duet, but I imagine AP mode is simpler than returning a list of networks so wouldn't be surprised if it worked despite failing at STA mode.
                                Silly question, but are you sure the wifi firmware upload was a success? If you have serial access maybe worth downgrading and upgrading to be relatively sure it works?
                                • Paddyundefined
                                  Yeah I'm sure. I was actually running the previous version when the problem first appeared. I found a post that said it could be caused by the fw versions getting out of step - so upgrading to 1.23 was one of the first things I tried.
                                    It might be worth measuring the voltage on the +3.3V rail, to see if it is within tolerance. The WiFi modules are fussier than other chips on the Duet WiFi about the supply voltage they get.
                                    Is it the same ESP-12S module that we use on genuine Duets, or is it one of the older ESP-12 series modules?
                                    • Paddyundefined
                                      Paddy @dc42
                                      @dc42 said in Wifi not connecting:
                                      It's the ESP-8266MOD.
                                      It's been rock solid for a year before it played up. Now that it's working again and has been stable for the last couple of days, I'm reluctant to start poking around with a probe. It would be just like me to short it out.
                                      If it plays up again I'll bear it in mind to check.
