    PanelDue and Motors will not function properly with Duet Wifi
    80
    4.0k
      Ok that photo looks good. Looks like the Y endstop is at the front now for Y min.
      Just noticed your drive mappings are pretty... non-standard
      M584 X3 Y4 Z2 E1 ; set drive mapping
      Don't think it really matters here, but wondering if there's rhyme to the reason? Are we dealing with a blown driver or something?
      Typically they'd be connected like so:
      M584 X0 Y1 Z2:3 E4:5:6 ; Driver 0 controls the X motor, 1 controls Y, 2 and 3 control Z motors, 4 5 and 6 control E motors
      Axis limits and endstops look correct.
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X280 Y280 Z280 S0                         ; set axis maxima
      M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S1 P"zstop"                            ; configure active-high endstop for low end on Z via pin zstop
      Your homing moves look correct.
      ; homeall.g
      G91                    ; relative positioning
      G1 H2 Z5 F600          ; lift Z relative to current position
      G1 H1 X-285 Y-285 F600 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-285            ; home X axis
      G1 H1 Y-285            ; home Y axis
      G1 X5 Y5 F600          ; go back a few mm
      G1 H1 X-285 F180       ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-285            ; then move slowly to Y axis endstop
      G1 H1 Z-285 F180       ; move Z down stopping at the endstop
      G90                    ; absolute positioning
      G92 Z0                 ; set Z position to axis minimum (you may want to adjust this)
      The next thing to nail down is the direction of rotation for the X/Y motors.
      M569 P3 S1                                     ; physical drive 3 goes forwards
      M569 P4 S1                                     ; physical drive 4 goes forwards
      M569 P2 S0                                     ; physical drive 2 goes backwards
      M569 P1 S1                                     ; physical drive 1 goes forwards
      Now in your setup P3 and P4 would be X and Y. This is where we'd do the G91 G1 H2 X10 and G91 G1 H2 Y10 moves and go from there.
      https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
      The testing begins with the assumption that we'd be using M569 P3 S0 and M569 P4 S0 so change those to S0 and do the movement test.
        This would also be a good time to test the endstops before even testing homing just to ensure they are configured corrected. If you trip them manually do they show as triggered in the machine status view?
        • Danalundefined
          Danal
          Curious where the X endstop is, physically?
            I believe it's on the printhead on the HEVO. You can see the Red green black wires for the optical endstop running to it. The flag is on the left X gantry block.
            • firex726undefined
              firex726
              Hi All,
              Carriage is in the center, normally 140, 140...
              G91 G1 H2 X10
              Moves diagonal towards 0, 280.
              G91 G1 H2 Y10
              Moves diagonal towards 0, 0.
              M569 P3 S0
              M569 P4 S0
              G91 G1 H2 X10
              Moves diagonal towards 280, 0.
              G91 G1 H2 X10
              Moves diagonal towards 280, 280.
              Correct, which is also why the homing speed is so slow, to give my hand time.
              Yes, earlier when having issues with only one motor moving it ended up being the diver was blown.
              A Former User? Phaedruxundefined 2 Replies Last reply Reply Quote 0
              • A Former User?
                A Former User @firex726
                @firex726 said in PanelDue and Motors will not function properly with Duet Wifi:
                you can test the switches without moving the motors, just press and hold a switch while you run M119 release switch and run M119again to confirm both states. repeat for each axis
                  jay_s_uk @A Former User
                  @firex726 Or use the machine specific settings page in DWC to watch the endstops while triggering them, rather than running M119
                  • Danalundefined
                    Danal
                    This post is deleted!
                      droftarts administrators @Danal
                      Danalundefined 1 Reply Last reply Reply Quote 0
                      • Danalundefined
                        Danal @droftarts
                          Edit: Posts deleted to avoid confusion! But leaving this bit because of note about documentation.
                          He's basically doing this: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
                          Though document needs updating to change S2 to H2 moves.
                          • Danalundefined
                            Danal
                            YIKES!!!
                            Working from memory, I thought the H2 was endstop related ( as a safety net).
                            I've deleted my above post... thanks for catching that.
                              Phaedrux Moderator @firex726
                              Hi All,
                              G91 G1 H2 X10
                              Was this with M569 P3 S1 and M569 P4 S1?
                              G91 G1 H2 Y10
                              M569 P3 S0
                              M569 P4 S0
                              G91 G1 H2 X10
                              From the test description: If it moves towards +X and -Y, swap the X and Y motor connections.
                              G91 G1 H2 X10
                              I assume you mean Y10?
                              Swap the motor connections and test again. Make sure you're using M569 P3 S0 and M569 P4 S0.
                              • firex726undefined
                                firex726
                                Well that did it.
                                Reversing the motor directions and also swapping the wiring. It'll both home and move in the correct directions now...
                                Thanks for everyone's help!
                                Now to clean up the wiring and calibrate it.
                                • Danalundefined
                                  Danal
                                  Woo Hoo!!! Extremely glad to hear that things are moving in the anticipated directions, etc, etc.
                                  Woooo Hoooo!!!!
                                    I knew we'd get there eventually.
                                    • richardmckennaundefined
                                      richardmckenna
                                      Ha ha I haven't commented on this thread before but have followed it along the way. Just goes to show while building and setting up 3D printers can be very frustrating at times, if you stick with it and work through problems logically you get there in the end.
                                      I've been a member of this forum for 5 years now, active off and on and it is by far the best community I have found.
                                      For those that are far more knowledgable than I and constantly strive to help others and never giving up, like in this thread, and never getting fed up with constant "noob" questions, I thank you!
                                      On a personal note, I'm immensely grateful to have such a wealth of knowledge at my finger tips and probably would have given up on this hobby long ago.
                                      Oh dear god, I seem to have something in my eye causing it to water 😂 I'm going now lol
