    duet ethernet blew both fuses, replacing hasnt helped
    1.7k
    • A Former User?
      A Former User @droftarts
      @droftarts said in duet ethernet blew both fuses, replacing hasnt helped:
      Not sure why the fan fuse would blow too
      and presumably causing both TR1 and D21 to fail?
      imrj said in duet ethernet blew both fuses, replacing hasnt helped:
      .if I short the botton block the PWM FAN2 gets got.....
        dc42 administrators @droftarts
        @imrj Is it possible that you have applied 24V power with VIN and GND swapped? This would generally have the effect of destroying the stepper drivers; see https://duet3d.dozuki.com/Wiki/How_to_destroy_your_Duet_2#Section_Methods_that_might_work_or_only_impact_some_functions_of_your_Duet
        Then applying power the correct way around would cause the shorted stepper drivers to blow the fuse. Not sure why the fan fuse would blow too. 5V is protected by a diode, which is why it works with the voltage the correct way around.
        @dc42?
        I agree, I suspect that either you are applying VIN and ground the wrong way round now, or you have done so in the past.
        btw applying reverse polarity doesn't always blow the drivers, it depends on the current limit of the PSU. I have got away with it in the past.
        arhiundefined 1 Reply Last reply Reply Quote 0
        • A Former User?
          A Former User
          without more information on the what happened prior to the failure I'm hesitant to suggest what to replace, but its pretty clear at a minimum you'll need to replace the parts you identified as getting warm TR1, D21, U5, U6, U7, U8 and U9 + U3 and D1 i'd recon. Almost $40 worth of parts, and a bit of work.
          if this is caused by wrong polarity that may well be it. if its caused by over voltage/transient there could be more damage. having the 5v regulator and fan2 output fail is a bit concerning in that respect.
          what was the printer doing before it failed?
          • arhiundefined
            arhi @dc42
            @dc42 said in duet ethernet blew both fuses, replacing hasnt helped:
            I find a beefy fast diode across Vdd and Vss immediately after the main fuse tends to protect the board in most cases. Adding a low drop / schottky trough diode after that for the low current side of things tends to increase the chance of everything surviving reverse polarity sky high as high current stuff usually can survive reverse polarity for the short period till fuse is blown due to current flowing through the fast diode across Vdd/Vss and the low drop will completely protect the low current parts from negative voltage.
              dc42 administrators @arhi
              There is already a diode protecting the 5V regulator.
              If you apply reverse polarity then the body diodes in the output mosfets of the stepper drivers will conduct. Each driver has 2 pairs of series connected mosfets. So that's 10 pairs sharing the short circuit current of the PSU.
              arhiundefined 1 Reply Last reply Reply Quote 1
              • arhiundefined
                arhi @dc42
                @dc42 great, so the fuse should blow before the big damage
                  @arhi said in duet ethernet blew both fuses, replacing hasnt helped:
                  It depends on the short circuit current of the PSU. If the PSU supplies 20A continuously into the Duet, then I think it's likely that the drivers will blow, because that's 2A * 2 * about 2V per driver, which is about 8W per driver, and the 15A fuse will probably take a minute or two to blow. If the PSU has short circuit protection then it will probably go into hiccup mode, resulting in much less average current and the fuse remaining intact. That's what happened when I connected VIN the wrong way round.
                  If the fuse blows instantly when you connect VIN then it's likely that your PSU is providing a lot more than 20A.
                  • arhiundefined
                    arhi @dc42
                    @dc42 interesting, I don't have much experience with these "blade" type fuses. I never used them in my projects. Minutes sounds too long. I like to use polyfuses and the glass ones for "lower" current setup and efuse for high current ones. For low current stuff, I never measured response time but it's kinda "instant". E-fuse will trip faster then millisecond depending on the schematic. I never considered that fuse will take "minutes".
                    Polluting the topic, but maybe useful, some military stuff I designed some years back had interesting power protection. We controlled a lot of heavy stuff (over 40kW in total) and the guy who designed the power input part of the controller (remember, this can and will be, "serviced" by a 19yo soldier in the mud somewhere far from a service station) used a delayed circuit with a relay (big chunky ones) so when you connect power, the system does a "diagnostic" checking if power is ok (voltage levels, polarity, stability) and after a second or two if everything is ok it will turn on the relay and power the rest of the board. Normally we'd put there a beefy rectifier so input polarity gets irrelevant but we are pulling over 100A from those 48V sources
                    • A Former User?
                      A Former User @arhi
                      Can take hours even. Depends on the over current and fuse rating ofc, even your 16A residential fuse/breaker would support 20A for anywhere between 30 and 60 minutes or more unless specifically installed as a fast breaking fuse which is uncommon.
                      • arhiundefined
                        arhi @A Former User
                        @bearer said in duet ethernet blew both fuses, replacing hasnt helped:
                        I'm talking about electronics, not mains 😄 For mains I have 3 "slow" ones just after the meter (one for each phase) and then I have "normal" ones on the each floor of the appartment and then my room / workshop has it's own breaker box with "ultra fast" breakers + the workbench is 5kW 1:1 galvanic separated from the rest of the world with 3 separated variaks after the 1:1 with some super fast "settable" breakers (you can vary the current that will trip them). I'm moving this year into a new place (yeeeeeeeeeah) where I'll have a whole small 50m2 house just for my workshop, doing installation "these days".
                        So those big copper ones and the heat ones and the bimetal ones I get, but the blade ones to me fall in same category as those small glass ones that have very low "holding" strength and fail rather quickly 🙂 and due to the difference of low current and short circuit they break inside milliseconds as even if your psu can deliver 100mA only just an output cap will be enough to break the glass one or trigger a poly when you short it out. That's why I mentally just wrongly looked at the blade fuses while it's totally normal as while on "micro electronics board" it's actually energetic part handling 10+ amps :). It's a common issue when you don't use something you look at it with completely different, often very distorted, eye sight.
                        • imrjundefined
                          imrj
                          ok i took care of the problem......
                          • A Former User?
                            A Former User
                            👍 that is one way to fix it.
                            I'd still recommend trying to find the cause of the failure before hooking up an even more expensive board though.
                            imrjundefined 1 Reply Last reply Reply Quote 1
                            • imrjundefined
                              imrj @A Former User
                              @bearer power was checked before firing it up, all checks out, is just this dam new RRF3 thats driving me nutz now....
