    My 6 input (5+1) mixing hot end
    My Duet controlled machine
    18
    109
    7.4k
    • deckingmanundefined
      deckingman @Wurstkarton
      @Wurstkarton said in My 6 input (5+1) mixing hot end:
      For me, the whole multicolor printing topic is kind of bottomless,
      That just about sums it up - having masochistic tendencies helps too ☺
      I am wondering if there is a slicer that lets you put full color on your object (like a bitmap)?
      Not that I know of but this https://hackaday.com/2019/08/20/lithophanes-ditch-the-monochrome-with-a-color-layer/ is on my list of things to investigate
      Quality wise you somewhat degrade by having to use a Bowden setup, which you countered by using a second xy axis.
      This new hot end doesn't have the huge great cooling fan mounted on the top like the Diamond, which makes it quite a bit shorter. So maybe I will be able to drop the height of the upper "UV" gantry which will reduce the length of my Bowden tubes even more. I might be able to get them down to 100 - 150mm or so - we'll see.... The other thing is that the Bowden tubes on the Diamond exit the heat sinks at an angle of about 20 degrees, which means that they have to be curved to line up with the extruders. With my new hot end, the tubes should be very much straighter which should also help.
      This is something that I am not willing to do
      Have you considered using "remote" flex drive extruders like the Zesty Nimble ?
      and hence I am thinking if it might not have made more sense to use a prusa MMU with direct drive extrusion in my case.
      AFAIK, the Prusa MMU does not mix. It just allows you to automatically load different filaments but you can only print one at a time. And have you seen the size of the purge tower it produces?
      But I have invested a lot in the current setup and it's working and so I think I should stick with it. In the other hand knowing you may perform better is nagging. 😉
      ☺ Which brings us back to your first sentence "..... the whole multicolor printing topic is kind of bottomless".
      Dougal1957undefined 1 Reply Last reply Reply Quote 0
      • Dougal1957undefined
        Dougal1957 @deckingman
        @deckingman Kiss slicer supports applying colour via a bitmap image now and supports unto 12 extruders now
        Kiss features
        Wurstkartonundefined deckingmanundefined 2 Replies Last reply Reply Quote 1
        • Wurstkartonundefined
          Wurstkarton @Dougal1957
          @Dougal1957 interesting. I was originally on slic3r&cura, but now switched to iceSL for having the possibility of coding parts of the slicing myself easily in lua.
          How about kisslicer in this regard?
            deckingman @Dougal1957
            @Dougal1957 said in My 6 input (5+1) mixing hot end:
            Kiss features
            Wow, that's interesting! I really must try to find the time to start playing with it.
              deckingman
              Part 3 is out now for anyone who might be interested https://somei3deas.wordpress.com/2020/03/09/my-6-input-mixing-hot-end-v2-part-3/
                deckingman
                ......and now part is out https://somei3deas.wordpress.com/2020/03/12/my-6-input-mixing-hot-end-part-4/
                • DaBitundefined
                  DaBit
                  Not much comment, but still reading!
                    Wurstkarton
                    Just had a look at your new posts. 🙂 Congrats! Looks good!
                    Strangly, the sealing issue did not come to my mind during your previous articles. I also had issues with the Cyclops in this regard... Depending on how you want to tackle this, there is always the option of making a high temperature gasket - even though I do not really like this (you may destroy the gasket if you disassemble your parts and need to create a new one every time).
                    https://www.permatex.com/products/gasketing/gasket-makers/permatex-high-temp-red-rtv-silicone-gasket/
                      @Wurstkarton I had thought that it might be necessary to use some sort of sealant between the plates which make up the mixing chamber which I simply assembled "dry". But now that I've been able to remove the hot end and inspect it, the problem was as I thought. Simply that the upper plate which the heat breaks screw into had distorted at the (unclamped) edges. There were no leaks from the area around the central heat breaks which are surrounded by screws. Nor were there any signs of leakage anywhere else - including the joints between the mixing chamber plates. I've taken those plates apart completely and can see that there is filament in all the slots and holes, but no seepage whatsoever. So I'm fairly confident that lapping the plates perfectly flat is a technique that works without the need for any sealant - (providing that the plate is clamped in such a way that there are no unsupported edges). But for sure, rtv silicone is always a possibility if all else fails. I also have some Boron Nitride paste that I could try if needs be.
                        deckingman
                        I'm up to part 7 of my journey now https://somei3deas.wordpress.com/2020/04/18/my-6-input-mixing-hot-end-part-7/.
                        I haven't been posting updates here, but this latest post might be of interest to some, as it contains details of how I use the nozzle as a Z probe/homing switch. This is an extract...
                        "I now have a Z probe / homing switch that is arguably as precise and repeatable as they come, has zero offset between the physical nozzle position and the switch trigger point in X, Y and Z, has no hysteresis, does not need any deployment mechanism, does not need any signal conditioning, and is self compensating in that the physical end stop is intrinsically linked to the electrical trigger point. Oh, and it was cheap"................
                          deckingman
                          I've just published part 8 of my journey https://somei3deas.wordpress.com/2020/04/28/my-6-input-mixing-hot-end-part-8/. There is a little YouTube video embedded in that post which shows my "nozzle as Z probe" (that I gave details of in part 7) in operation. I'm quite chuffed with the way that turned out.
                            deckingman
                            I'm now up to part 12 of this particular journey but I've moved over to doing updates via my YouTube channel rather than my blog. Link here if anyone is interested. https://www.youtube.com/watch?v=Sl4DMXJHvnU
                            Phaedruxundefined 1 Reply Last reply Reply Quote 2
                              Phaedrux Moderator @deckingman
                              @deckingman Does that signal the end of the written form entirely for you? No more blog posts?
                                deckingman @Phaedrux
                                @Phaedrux said in My 6 input (5+1) mixing hot end:
                                Undecided but probably yes. There is a chance that I could make a small amount of money from YouTube. It would never be much as it's a bit of a niche market and I don't do reviews which is what drives a lot of traffic. But if I could get some income, however small that might be, it would help towards my development costs (although knowing me I'd likely spend it on photography gear).
                                There are two criteria one has to meet. The first is to get 1,000 subscribers and I've recently made that target. The second is to accumulate 4,000 public viewing hours in a 12 month period. I only have 1,600 or thereabouts. So I have some way to go with that.
                                But I'm always open to feedback. Which format do you prefer?
                                arhiundefined dc42undefined 2 Replies Last reply Reply Quote 1
                                  I like both. Youtube more for entertainment/edutainment. It's good to see things in motion sometimes, but it's also nice to be able to read a long form description with technical details and study a still high quality photo.
                                  • arhiundefined
                                    arhi @deckingman
                                    @deckingman said in My 6 input (5+1) mixing hot end:
                                    both 😄
                                      If I HAD to choose, I'd prefer long form blog posts.
                                        deckingman
                                        Hmmmm. I'll give it some thought. Both formats take a surprisingly long amount of time to do.
                                          I have no doubt.
                                            dc42 administrators @deckingman
                                            I prefer blog posts because I can skim through them. But if you have financial reasons to prefer video then I'll try to add to your viewing figures.
                                            PS - also I can more easily search for your blog posts. I recently needed to link to your work on moving the extruder gantry less than the print head, and it took me a long time to find the video. Maybe you could publish videos and also short blog summaries that link to them?
