    To my surprise, my Crane Quad just shipped...
    25
    892
    • Danalundefined
      Danal
      On FitForLaunch, I funded a printer a LONG time ago. Crane Quad, mixing printer, can either switch between four inputs very rapidly, or mix them. They make CMYK calibrated filament, theoretically allowing 50,000+ mix colors.
      FitForLaunch, KickStarter, etc. are notorious for never shipping printer projects... so I am a little surprised.
      And... best of all... the Crane Quad uses a Duet controller!!
      Should be here Saturday. We'll see...
      droftartsundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
        I was wondering whatever happened with those.
          droftarts administrators @Danal
          @Danal Check the bed wiring! https://forum.duet3d.com/post/134922
          Danalundefined 1 Reply Last reply Reply Quote 0
          • deckingmanundefined
            deckingman @Danal
            @Danal Best of luck - the only one I saw "working" was soooo slow. BTW, it doesn't mix. It just combines filaments like every other "mixing" hot end that is on the market. So what you get is akin to stripey toothpaste (albeit a claimed 50,00 varieties of stripes). So don't waste your money buying "calibrated" CYMK filaments because unless you actually mix them together, you'll never get the colour you expect. Oh and the "K" is either black or white but you can't have both. And be careful setting the mixing ratios - I know of one beta tester that got it wrong and the hot end exploded! Other than that, it's probably a wonderful machine. ☺
            Danalundefined 1 Reply Last reply Reply Quote 1
            • chas2706undefined
              chas2706
              @Danal said in To my surprise, my Crane Quad just shipped...:
              Hope you enjoy your new printer and have fun!
              • Danalundefined
                Danal @droftarts
                @droftarts said in To my surprise, my Crane Quad just shipped...:
                Thank you!! VERY much. I had not "Connected the dots" on the brand vs. the specific printer name. I will check, and mitigate as required, before I power.
                THANK YOU.
                • Danalundefined
                  Danal @deckingman
                  @deckingman said in To my surprise, my Crane Quad just shipped...:
                  Yeah, in all honesty, I don't expect much. Kick/Fit, etc have not, to my knowledge, every produced a 'revolution' in 3D Printing.
                  If it simply multi-materials cleanly, it will be useful to me.
                  • DocTruckerundefined
                    DocTrucker
                    Is that a bit of a dodgy belt line on the x axis? Ok, I appreciate the effect on accuracy is negligable.
                    Edit: Photo source - a zoomed in image from their website: https://store.printm3d.com/products/the-crane-quad-3d-printer#
                    • Danalundefined
                      Danal
                      Yeah, that photo certainly looks like the geometry is wrong.
                        DocTrucker
                        Hopefully it clamps top side and lower is just passing over an idler.
                          They copied the Ender 3 so completely they even got the bad belt arrangements. Nice. Totally negligible for such a short axis, but still...
                          DocTruckerundefined 1 Reply Last reply Reply Quote 0
                            DocTrucker @Phaedrux
                            @Phaedrux there is something ironic about a western company copying an eastern one like that!
                              Well I guess they didn't copy it completely. The base has a square frame, whereas the Ender has a cross shape.
                                DocTrucker
                                CR10?
                                I made a similar mistake on my y-axis belt line in an early version of my flavour of the P3Steels. I went and calculated the effect it had and was surprised how little it was. Fixed it all the time as watching the machine run with the belt angle waving at me was like listening to a bearing squeaking its way toward not being a bearing any more! 😄
                                  Ah yes, the Cr10 has a square base.
                                  Actually I wouldn't be surprised if they were just upgraded CR10s. The secret sauce is the mixing hotend and maestro anyway. Hard to break new ground on an i3 design these days.
                                    DocTrucker
                                    My next P3Steel build is underway at the moment and ideas are brewing for the final pile of bits that I haven't completed. Belt z (not particularly original!) was one thought, but last thought was Core XZ (slightly fewer of these), but need to look very closely at resolution and drop on power down.
                                    I was wondering the same thing (regarding buying in and building on Creality machines). Tidy markup if so, but I guess creality have cut price with both having a very wide quality control and buying from suppliers that employ similar techniques. Therefore I bet someone building on their machines would buy 10 and get 7 or 8 usable machines worth of parts!
                                    • Danalundefined
                                      Danal
                                      Well, sure enough, the bed connection is just a blown mosfet waiting to happen. I think I'm just going to put a couple of coats of "liquid tape" on that area.
                                      • Danalundefined
                                        Danal
                                        Also, the eccentric on the carriage couldn't be tightened. The bracket is bent, "spreading" the wheels apart. The eccentric wheel mounts it that tab that is sticking down, bent.
                                        Easy enough to bend back... but... the way it was all packed, there's no way this happened in shipping. Very poor QC.
                                          DocTrucker
                                          Does it look like a modified Creality in the flesh? Isn't that machine supposed to retail at $1k+?
                                          • Danalundefined
                                            Danal @DocTrucker
                                            @DocTrucker said in To my surprise, my Crane Quad just shipped...:
                                            Yeah, if you didn't pre-fund, they are $750.
                                            Creality looking? Sort of. I have an S10 that I bought to evaluate for a friend. In my eyes, that S10 (with dual Z) was an OK printer, particularly with upgraded firmware. It did/does produce reasonably decent prints. About is only downside is a long-ish bowden.
                                            The Crane Quad is loosely similar, but much flimsier and cheaper looking/feeling. All 3 wheel with eccentric, but the two wheel side spacing is minimal, and even when properly adjusted, there is still not a lot of rigidity. Classic bottom frame with inverted U arch, and absolutely no bracing, just some cap head screws joining that 90. No belt tensioners. And so forth. Just incredibly cheap all the way around.
                                            If anyone wants to experiment with the Quad head, I'd recommend getting just the head and mounting it on whatever platform you have laying around.
                                            It is driven by a Duet Maestro, and I can post the config.g. I haven't looked at that config yet; still, I'm sure we can make almost any Duet (with enough drivers) work.
                                            Dougal1957undefined 1 Reply Last reply Reply Quote 0
