    External SD Card not Reading (Maestro with 12864 Display)
    572
    • JadonMundefined
      JadonM
      Hey guys! First I want to give a hearty thank you for your great service and community! Next, I want to apologize. I finally finished my custom-built printer, and now I decided to start converting my fleet of Flashforge Creator Pros, so you'll likely be getting a stream of questions from me again! 🙂
      I bought a (supposedly) genuine Reprap Discount Display from eBay (yes, that's probably a red flag) and everything works except the SD card reader. I absolutely love the display, and I'm working on a set of menu files for it to fix the issues that I saw with the other systems, (I'll notify you when they're on Github.) but the SD card reader was one of the main reasons I bought it.
      I tried multiple cards of different capacities and brands (Samsung and SanDisk) along with formating them in varying ways, including the official formatter. However, if I try to mount the SD card using M21 it says the card is unusable, M39 says it's not present, and M20 says there are no files.
      Here's a link to the display I bought, and I have about a week yet in the return period. Do you think the issue is hardware or user error? (Knowing me, the latter is much more likely!)
      I'd appreciate any ideas or insight. Thanks!
      BTW, I'm running a Maestro on RRF 3.01-RC2, and the display worked straight from the box. There was no cutting and twisting connectors.
      Here's an M122 dump with the SD card inserted:
      RepRapFirmware for Duet 2 Maestro version 3.01-RC2 running on Duet Maestro 1.0
      Board ID: 08DJM-956DU-LLMS4-7JKD2-3S07J-1VPQJ
      Used output buffers: 3 of 24 (9 max)
      Static ram: 21876
      Dynamic ram: 94616 of which 56 recycled
      Exception stack ram used: 212
      Never used ram: 14312
      Tasks: NETWORK(ready,872) HEAT(blocked,1364) MAIN(running,2036) IDLE(ready,84)
      Owned mutexes:
      Last reset 00:25:22 ago, cause: power up
      Last software reset time unknown, reason: Hard fault, spinning module Display, available RAM 13840 bytes (slot 2)
      Software reset code 0x406f HFSR 0x40000000 CFSR 0x00008200 ICSR 0x0400f803 BFAR 0x0100000d SP 0x20004354 Task 0x4e49414d
      Stack: 00443c41 0044571e 210d0200 0000000d 2001ac58 01000000 00000000 00000000 00443c41 a5a5a5a5 0044aa99
      Error status: 0
      Free file entries: 10
      SD card 0 detected, interface speed: 15.0MBytes/sec
      MCU temperature: min 13.9, current 22.4, max 23.1
      Supply voltage: min 0.0, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, read errors 0, write errors 0, ifcount 7, reads 60848, timeouts 0
      Driver 1: standstill, read errors 0, write errors 0, ifcount 7, reads 60848, timeouts 0
      Driver 2: standstill, read errors 0, write errors 0, ifcount 7, reads 60848, timeouts 0
      Driver 3: standstill, read errors 0, write errors 0, ifcount 7, reads 60848, timeouts 0
      Driver 4: standstill, read errors 0, write errors 0, ifcount 6, reads 60849, timeouts 0
      Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 60855
      Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 60854
      Date/time: 2020-02-27 21:14:13
      Slowest loop: 54.81ms; fastest: 0.13ms
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      === AuxDDARing ===
      Bed heaters = 0 -1, chamberHeaters = -1 -1
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      lcd is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 5.75ms; fastest: 0.02ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      Interface state 5, link 100Mbps full duplex
        Is there any indication of what the pinout is on the silk screen of the PCB?
        JadonMundefined 1 Reply Last reply Reply Quote 0
        • JadonMundefined
          JadonM @Phaedrux
          @Phaedrux said in External SD Card not Reading (Maestro with 12864 Display):
          Unfortunately, there's none whatsoever. It did come with an adapter for using it with a ramps board though, and that seems to be the same as the official adapter as far as I can tell.
            There isn't any configuration to do for the external SD card, it should just work assuming that you have plugged both ribbon cables into the correct 2 ports of the Maestro. If both the LCD and the rotary encoder are working then you've got that right.
            Before you send the LCD unit back, let me test that the external SD card support still works in RRF 3.02-RC2 for the Maestro, because it's been a while since I tested it.
              dc42 administrators @dc42
              @dc42 said in External SD Card not Reading (Maestro with 12864 Display):
              I can't get the external SD card working on my 12864 LCD either, so it's probably a firmware bug. If so, you reported this just in time for me to fix it in 3.01-RC3.
                Confirmed, it's a firmware bug in the RepRapFirmware 3 series for the Maestro. Now fixed in 3.01-RC3, which I hope to release later today.
                • JadonMundefined
                  JadonM @dc42
                  David, thanks very much for your time, investigation, and quick response! I really appreciate it, and I've never found a company with service that even compares to yours!
                  Thanks for the quick fix! When you release the update, I'll test it and be sure to get back with you.
                  Jadon
                  • JadonMundefined
                    JadonM @JadonM
                    @JadonM said in External SD Card not Reading (Maestro with 12864 Display):
                    I can confirm that the external SD card works perfectly with the new firmware version. Thanks!
                      dc42 administrators @JadonM
                      You're very welcome!
                      Kiwi3Dundefined 1 Reply Last reply Reply Quote 0
                      • Kiwi3Dundefined
                        Kiwi3D @dc42
                        @dc42 Hi David,
                        Ive just got my Maestro Zaribo built...and facing t he same issue. I'm on 3.1.1
                        12864 rotary encode is working and can use the screen fully. SD card on the screen is working from DWC 3.1.1 but not from the 12864
                        Thoughts?
                        Many thanks
                        Ray
                          Phaedrux Moderator @Kiwi3D
                          @Kiwi3D said in External SD Card not Reading (Maestro with 12864 Display):
                          @dc42 Hi David,
                          Thoughts?
                          Many thanks
                          Ray
                          Probably best if you start your own thread.
