    Another Predator
    204
    14.3k
    • NexxCatundefined
      NexxCat @Carlo
      @Carlo Your repeatability isn't as low as mine, but it still seems well within reason:
      M98 P"0:/macros/ProbeRepeatability.g"
      G32 bed probe heights: -0.036 -0.036 -0.042 -0.036 -0.036 -0.042 -0.036 -0.042 -0.036 -0.036, mean -0.038, deviation from mean 0.003
      When you run the delta calibration, are you doing it with the bed and nozzle cold or hot? My macro for calibrating heats the bed to 60C and the nozzle to 130C before it calibrates.
      Carloundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @Carlo
        @Carlo If you're probing the bed with heaters on, turn them off by adding B1 to your M558 command. To quote @dc42 here https://forum.duet3d.com/post/97669
        The reason we keep the heaters off during the recovery time is that some probes (e.g. BLTouch) need to recover from the effects of the magnetic field generated by the bed heater.
        • Carloundefined
          Carlo @NexxCat
          @NexxCat
          Hi NexxCat,
          Hot..220c hotend 70c Bed....I'll set the heat as you have mentioned.
          Thanks
          B1 added Thanks droraft.
          • Carloundefined
            Carlo @NexxCat
            @NexxCat
            Results at 110c and 60c
            M98 P"0:/macros/Probe test"
            G32 bed probe heights: 4.041 4.053 4.041 4.066 4.041 4.053 4.053 4.053 4.053 4.066, mean 4.052, deviation from mean 0.009
            Thanks
            NexxCatundefined 1 Reply Last reply Reply Quote 0
            • Danalundefined
              Danal
              @Carlo said in Another Predator:
              0.009
              That's pretty darn good. Some mechanics (switch and/or overall printer) may do better... but that's a very good number on its own.
              • NexxCatundefined
                NexxCat @Carlo
                @NexxCat
                Thanks
                That's an excellent result, though I'm curious as why the probe heights are now in the positive and last night they were negative. That offset would certainly explain why nothing is sticking to the bed.
                Carloundefined 1 Reply Last reply Reply Quote 0
                • Carloundefined
                  Carlo @NexxCat
                  @NexxCat
                  Ahh apologies I did change the endstops.... had to the only thing I hadn't changed adjusted the height so now..
                  G32 bed probe heights: -0.196 -0.196 -0.196 -0.196 -0.196 -0.196 -0.196 -0.196 -0.196 -0.184, mean -0.195, deviation from mean 0.004
                  Better ?
                  Thanks
                  • NexxCatundefined
                    NexxCat @Carlo
                    @Carlo Yeah that looks fine. Hm. What is your current Z offset set to? In config.g you're after the line like:
                    G31 P100 X0 Y0 Z-0.210
                    Sorry if this has already been mentioned in the thread, just looking for things at the state of play right now.
                    • Carloundefined
                      Carlo @NexxCat
                      @NexxCat
                      No that's fine I'll add that in....not sure I want to click upload now don't want to be disappointed ...or cry in front of dudes!
                      • Carloundefined
                        Carlo @NexxCat
                        @NexxCat
                        Sorry I didn't read that fully Z-0.06
                        • Carloundefined
                          Carlo @Carlo
                          @Carlo
                          This is the result I think everyone looks and thinks it's too far from the bed but it's not actually completing the print move it's changing direction before it should in the picture you can see where the print does a U turn on it's self so it never joins the print together it just doesn't complete the move almost like the radius is wrong like the circle is smaller than it is I'm watching it and it does not complete the circles or arcs it never makes it to the end it changes direction and doesn't go back to finish it.
                          Where it has printed ..it stuck and the outer ring is on the second layer but there is a gap in it.. as have all the arcs and full circles they all have a gap in them and relative to the size the outer are bigger gaps than the inner i.e. the further out it goes the bigger the gap.
                          NexxCatundefined dc42undefined 2 Replies Last reply Reply Quote 0
                          • NexxCatundefined
                            NexxCat @Carlo
                            @Carlo
                            Have you re-sliced that bed level print, or are you printing the gcode that came with the predator?
                            • Carloundefined
                              Carlo @NexxCat
                              @NexxCat
                              It's re-sliced and I have one sliced by another user on these forums they are both the same in fact all prints are the exactly the same.
                              I wanted to rule the file out so another one of you extremely helpful users kindly sliced it for me to rule the file out for my own sanity.
                              • NexxCatundefined
                                NexxCat @Carlo
                                @Carlo
                                Give me a few minutes. I'm going to craft a gcode file for you to run, based on my startup settings and prime line. If you want to try that, we'll see what happens?
                                • Carloundefined
                                  Carlo @NexxCat
                                  @NexxCat
                                  Really appreciate your help and well everyone's help to be honest
                                  That file prints fine on my linear plus and ender3
                                  Cheers
                                  • NexxCatundefined
                                    NexxCat @Carlo
                                    @Carlo
                                    Test.gcode
                                    Try printing that. It contains my startup code, the calibration of the printer, the prime line, and a single layer 40x40 square.
                                    Unless things are going really wrong, let it finish and take a picture. Obviously if it starts to make a real mess, stop it and photo that instead 😛
                                    You will need the web UI open as the calibration has a user prompt to make sure the nozzle is clean. Lastly, are you cleaning your bed with anything? If you've got isopropanol alcohol handy, give it a wipe with that whilst cold.
                                    • Carloundefined
                                      Carlo @NexxCat
                                      @NexxCat
                                      Thanks for this I'll try that now...Yeah I clean it with brake cleaner ..acetone I'll clean it first and always have to wipe the nozzle.
                                      Thanks
                                      • Carloundefined
                                        Carlo @NexxCat
                                        @NexxCat
                                        Ok ....
                                        Looks great
                                        • NexxCatundefined
                                          NexxCat @Carlo
                                          @Carlo
                                          Well that was unexpected 😛 Can you take a closer picture of the square it printed if possible please?
                                          • Carloundefined
                                            Carlo @NexxCat
                                            @NexxCat
                                            Yeah of course here we go its off center ...shadow
