    Duet pi GUI
    244
    • BearcatTD
      BearcatTD last edited by
      So I installed the latest Duet Pi with the GUI. I updated the WPA-supplicant file with all of my wifi options. DuetPi starts up and connects to the internet fine. But I cannot tell which SSID that the pi is actually connected to. I ran hostname -i and it came back with 127.0.0.1. The problem is none of my APs produce ip addresses in that range. I have internet access, but I need to know where I am connected and what is the right ip address. I need to know this so I can ssh into the pi.
      The selection of apps available is pretty slim...I get it, don't want the machine bogged down. I tried to do an apt-get upgrade / update...no joy.
      Any help would be appreciated.
      Professor of Theatre, Lighting and Scenic Designer, Northwest Missouri State University
      Hardware: Ender 3 with a Duet 2 wifi, CR-10 V2 with a Duet3
      tekstyle 1 Reply Last reply Reply Quote 0
      • A Former User
        ifconfig (or sudo ifconfig) will give you a more detailed list of network addresses.
        i suspect iwconfig will do the same for the wifi name
        (no idea where those things are in the gui unfortunately)
        edit: 127.0.0.1 is a special addres for loopback testing, refered to localhost. it doesn't go anywhere; weird hostname -i outputs it if it has other addresses.
        • BearcatTD
          Thanks! I do the ipconfig, then arp -a, which gives a list of all ip addresses connected to each AP. Nothing new shows up.
          A Former User 1 Reply Last reply Reply Quote 0
          • A Former User
            A Former User @BearcatTD last edited by A Former User
            @BearcatTD said in Duet pi GUI:
            that had me raise an eyebrow; for several reasons
            • arp is only a mac to ip address mapping, and only populated and cached for 2-5 minutes for addresses the host has connected to
            • it will not include the hosts own address under any circumstances i think where did you run arp -a?
            edit: I'm thinking your pi is probably not connected to the internet or any network for that matter; but puzzled what would make you think it is. erase and rewind a little - how do you interface to the pi currently?
            • BearcatTD
              arp -a runs on mac after ifconfig and on Windows after ipconfig
              • A Former User
                ah, i assumed you'd run this on the Pi, as that is where it would have made sense to run hostname -i neither command would have done you any good outside of the Pi.
                also note ifconfig , not ipconfig for the Pi.
                This is what I thought you'd be after, and wanted you to try:
                pi@duet3:~ $ iwconfig
                eth0      no wireless extensions.
                lo        no wireless extensions.
                wlan0     IEEE 802.11  ESSID:"bearlink"
                          Mode:Managed  Frequency:2.447 GHz  Access Point: D4:5F:25:EC:B4:54
                          Bit Rate=72.2 Mb/s   Tx-Power=31 dBm
                          Retry short limit:7   RTS thr:off   Fragment thr:off
                          Power Management:on
                          Link Quality=54/70  Signal level=-56 dBm
                          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
                          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
                pi@duet3:~ $ ifconfig
                eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
                        ether b8:27:eb:08:5c:88  txqueuelen 1000  (Ethernet)
                        RX packets 0  bytes 0 (0.0 B)
                        RX errors 0  dropped 0  overruns 0  frame 0
                        TX packets 0  bytes 0 (0.0 B)
                        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
                lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
                        inet 127.0.0.1  netmask 255.0.0.0
                        inet6 ::1  prefixlen 128  scopeid 0x10<host>
                        loop  txqueuelen 1000  (Local Loopback)
                wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
                        inet 10.10.0.237  netmask 255.255.255.0  broadcast 10.10.0.254
                        inet6 fe80::451b:b7f0:f1ab:e16d  prefixlen 64  scopeid 0x20<link>
                        ether b8:27:eb:5d:09:dd  txqueuelen 1000  (Ethernet)
                        RX packets 194  bytes 18456 (18.0 KiB)
                        TX packets 80  bytes 15217 (14.8 KiB)
                • BearcatTD
                  YES! I did this about 5 seconds before your post came through...LOL Thanks!
                  • A Former User
                    Did you resolve the issue?
                    BearcatTD 1 Reply Last reply Reply Quote 0
                    • BearcatTD
                      BearcatTD @Guest last edited by
                      @bearer It did! Now I just need to figure out where and how everything plugs in!
                      • tekstyle
                        tekstyle @BearcatTD last edited by
                        @BearcatTD
                        Can you tell me how you installed duetpi? I've been trying for 2 days. I downloaded duetpi.zip, used balena etcher. Put it into the raspberry pi model 3. And all I get is a black screen with some codes but it stops there.
                        A Former User BearcatTD 2 Replies Last reply Reply Quote 0
                        • A Former User
                          A Former User @tekstyle last edited by
                          @tekstyle said in Duet pi GUI:
                          You should probably create a new topic and include "some codes" to get help with your problem.
                          • BearcatTD
                            BearcatTD @tekstyle last edited by
                            @tekstyle I downloaded the duetpi file with the full GUI. I connected the pi to the duet 3 with the ribbon cable. Did you edit the wpa_supplicant.conf? So you can connect to wifi. If you haven't done this yet, make sure you use a good text editing app (I swear by Atom), as Windows and Mac stock apps sometimes put weird line breaks and other funkyness in the files.
