    garbled when upload file on web
    109
    • netuser
      netuser last edited by
      On Duet2 Wifi v1.04
      Sometimes upload files on web would be garbled.
      Once I edit config.g, Sometimes upload Gcode Files..
      like this...
      My firmware is rrf 3.0
      deckingman Phaedrux 2 Replies Last reply Reply Quote 0
      • deckingman
        deckingman @netuser last edited by
        @live The first thing to do is enable CRC checking in the web interface.
          Phaedrux Moderator @netuser last edited by
          @live said in garbled when upload file on web:
          What version of DWC are you using? Should be 2.0.7
          netuser 1 Reply Last reply Reply Quote 0
          • netuser
            netuser @Phaedrux last edited by
            @Phaedrux I use 2.07 zip
            but in web it show 2.04..
            I have already use CRC
              Upload the zip file to the system folder. It should update the DWC for you, and I think that should solve your problem. There was a bug with the CRC code early on I believe.
              • netuser
                @Phaedrux /www or /sys
                I have upload the newest www files
                  The system tab where config.g is. Upload the entire zip file there.
                  • netuser
                    @Phaedrux Thank you , Is this OK?
                      Nope.
                      https://github.com/chrishamm/DuetWebControl/releases/tag/2.0.7
                      • arhi
                        arhi last edited by
                        check SD card, when I started getting garbled files after upload it happened to be broken SD card fault
                          dc42 administrators @netuser last edited by
                          I recommend that anyone using RRF 3.0 upgrades to 3.01-RC4. There have been many improvements since 3.0. The only reason 3.01 hasn't been released yet is in case further changes are needed to work with the forthcoming major release of DSF and DWC.
                          Caveat for Duet Maestro users: speed and extrusion factor controls on a 12864 display don't work properly in 3.01-RC4.
