    Temperature Fluctuations
    323
    • drmaestro
      drmaestro last edited by
      I am trying to eliminate temperature fluctuations on the hotend thermistor. They sometimes are very severe so that the printing stops due to safety measure. The most probable culprit is the thermistor or its wiring of course but I don't have a spare thermistor right now, so I can't change it right now. Is there a way to test it to be absolutely sure that the proble is there? When the print head is not moving (when the heater is beginning its heating process or when it is in parking position and keeping a constant temperature) there are generally no fluctuations but I can't always induce fluctuations by moving the wiring of the thermistor, so I can't be sure.
      Thanks
      • PaulHew
        PaulHew last edited by
        @drmaestro Have you 'tuned' your heaters.
        Had a similar issue but this sorted my issue.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M303_Run_heater_tuning
        HTH
        Paul.
        RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
        Voron 2.4 disassembled..... Waiting for the RailCore Mini....
        • drmaestro
          Thanks for the suggestion. I normally had done PID tuning, however it is possible that I've changed the thermistor after a certain period so I ran m303 again. The values were different from what was my last PID values so I changed them. I still get fluctuations but they are not as deep as they are in the picture, and for now it didn't stop the printing process, however I used to have an absolutely flat temperature graphic so I still think there is an additional problem somewhere.
          • PaulHew
            @drmaestro
            I just found this as I remember someone else had a similar issue.
            https://forum.duet3d.com/topic/2828/hot-end-temps-fluctuating/3
            DC42 suggests increasing the D value.
            Regards,
            Paul.
            • deckingman
              deckingman @drmaestro last edited by deckingman
              @drmaestro Those temperature transients look too sharp and random to be anything other than noise on the thermistor signal. If you can't easily re-route the cable, then the best way to fix it IMO is to use screened cable for the thermistor and connect one end of the screen to gnd. (At least that has always worked for me).
              Edit. On the basis of what @jens55 said below, it's possible that the noise is being generated by the thermistor itself. So the best thing to do would be try another thermistor and if that doesn't work, use screened cable.
              • jens55
                jens55 last edited by
                With about 90% certainty, I can say you have a dud thermistor. Another 5% goes to a bad connection someplace and the last 5% is phase of the moon related. Notice there is 0% chance of this being tuning related.
                Why am I so certain? Because I happen to have had the exact same issue and struggled with it for quite some time before deciding to put a second thermistor on the build plate. I relegated the original thermistor that is buried in the heater to backup status and use the new thermistor as the thermistor 'in charge'.
                I display both values in the temperature chart for kicks and the original one is still doing it's dance.
                As a side benefit, the replacement is more accurate as it isn't buried in the heater.
                A tuning related issue will show an undulating temperature but what you see here is sudden temperature spikes, instantaneous changes in temperature, that are not physically possible.
                You might be able to tune it a bit, as you found out, to stop the safeties from kicking in or you might change the safety mechanism to be less sensitive. This can buy you some time to get a new thermistor in.
                • pro3d
                  pro3d last edited by
                  I am also strugling with this aafter upgrading FW from 2 to 3-RC4
                  Link to thread
                  Valkyrie DIY High Temp 3D Printer
                  R&D - Engineering Designer - Viking 3D Printers
                  https://vkingprinter.com/
                  • deckingman
                    deckingman @pro3d last edited by
                    @pro3d That's a different issue. Your temperature graph is completely different to the OPs and has none of the spikes that the OP has.
                    • jens55
                      pro3d, your problem is tuning related (undulating). drmaestro's problem is a bad thermistor.
                      Re electrical noise ... I have a line voltage 1200W heater and have not had an issue with noise. At the temperatures we are measuring, the impedance of the temperature circuit is really low and unlikely to be affected by noise. Having said that, shielded cable is always good if you have it available (I didn't).
                      • jens55
                        Dang it .... the perils of one finger typing .... being out-typed by other people 🙂
                        • deckingman
                          deckingman @jens55 last edited by deckingman
                          @jens55 said in Temperature Fluctuations:
                          Re electrical noise ... I have a line voltage 1200W heater and have not had an issue with noise. At the temperatures we are measuring, the impedance of the temperature circuit is really low and unlikely to be affected by noise....................
                          Me too - although my bed is 800 Watt not 12000W. But however unlikely you think it might be, I did have a noisy thermistor signal (tried several E3D type cartridge thermistors which all had the same problem). I cured it by fitting screened cable. So please don't dismiss my suggestion out of hand - there is a reason I mentioned it.
                          • jens55
                            I sit corrected !
                            • deckingman
                              @jens55 Thank you and no worries. After seeing your post about the possibility that it could be the thermistor itself, I did edit my post to the OP suggesting that he try a new thermistor first, and if that didn't work, then try the screened cable. Between us both one or other of our suggestions should fix the OP's issue ☺
                              • drmaestro
                                Thanks for all the answers. I also think it is a thermistor problem. What is really interesting is that it sometimes works. For example that's the actual temperature chart I am getting now:temp.jpg
                                I am waiting patiently for my thermistor to arrive, then we'll see. I really like the cartidge thermistors that E3D is using (which is my actual thermistor) as they are easy to install but I've heard some of them can be problematic.
                                • drmaestro
                                  An update: Changing the thermistor took care of the problem (for now at least). I still have 1 or 2 degree fluctuations but they are not spikes and I didn't run PID tuning with the new thermistor yet, so that's probably to be expected.
                                  Thanks for the contributions...
