    RepPanel - A DIY alternative to the PanelDue with WiFi support
    Third-party software
    39
    243
    30.5k
    • seeul8erundefined
      seeul8er
      @oliof The LVGL docs only specify ESP32 pins. You need to find their counterpart on your TFT
      • oliofundefined
        oliof
        I found the counter parts in the official buydisplay documentation. I know they're right for the TFT part because that lights up with your precompiled binary. Can you maybe share your sdkconfig from the RepPanel_ESP32 directory that you used when building the current latest binary?
        • seeul8erundefined
          seeul8er
          @oliof https://pastebin.ubuntu.com/p/MWBQH2tVSR/
          • seeul8erundefined
            seeul8er
            Release v1.1.0 is out now!
            Thanks to contributions from Github user vden some new features are added and old bugs were fixed:
            • Change console image button
            • Added power button
            • Added extruder fan control
            • Added light switch (compile-time selection) - default not enabled
            • Fix for freezes when using supported hardware (ILI9488)
            • pdundefined
              pd @seeul8er
              @seeul8er I finally had another go with this and have made some progress. I bought a new capacitive screen from buydisplay. Unfortunately I didn't realise it wasn't 3.3v version to start with but it was easy enough to short the JP bridge. I finally managed to get the reppanel to light up. The touch screen seems to work and I managed to find my router. However the one issue I have left is that I am unable to bring up the keyboard from the top right hand corner to change the password. Do you have any idea why this might happen. All the other Icons seem to open OK.
              @PCR Any news on the PCB front ?
              • PCRundefined
                PCR
                Still waiting for a display ;(
                • PCRundefined
                  PCR
                  Orderd again. PCB will follow!
                  I_Jediundefined 1 Reply Last reply Reply Quote 0
                  • I_Jediundefined
                    I_Jedi @PCR
                    @PCR When the PCB is done... sign me up for one! I love the idea of the RepPanel, but have limited skills and time to implement... so the more plug and play the better 🙂
                    • PCRundefined
                      PCR
                      Plan is to put a prototype into production next week! Who would be in?
                      appjawsundefined I_Jediundefined kingfisherundefined 3 Replies Last reply Reply Quote 0
                      • seeul8erundefined
                        seeul8er
                        @pd Try to scroll down for the keyboard. It is hidden on the lower part of the page 🙂
                        pdundefined 1 Reply Last reply Reply Quote 0
                        • appjawsundefined
                          appjaws @PCR
                          @PCR yes please
                          appjaws - Core XYUV Duet Ethernet Duex5
                          firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                          Ormerod 1-converted to laser engraver, Duet wifi
                          OpenSCAD version 2024.03.18
                          Simplify3D 5.1.2
                          • I_Jediundefined
                            I_Jedi @PCR
                            @PCR I'm in assuming it isn't stupid expensive -- Could I have more details on intended cost and functionality... is this an 'all in one kit'? DIY?
                            • PCRundefined
                              PCR
                              Would be a pcb only. But you would need a esp and the Display! But would be easy to assemble!
                              I_Jediundefined paralepsisundefined 2 Replies Last reply Reply Quote 0
                              • I_Jediundefined
                                I_Jedi @PCR
                                @PCR why not... I'll give it a go. Looking forward to it! So I should go ahead and order the board and display? Any parameters/features I should be looking for? i assume any ESP devboard should work... but what about the screen?
                                • kingfisherundefined
                                  kingfisher @PCR
                                  @PCR I'm in - Subject to costs (+Shipping)
                                  • oliofundefined
                                    oliof
                                    @PCR yes please.
                                    • pdundefined
                                      pd @seeul8er
                                      @seeul8er Thanks. I have now managed to connect the Reppanel to my router and it has been given an ip address. However I seem to be unable to connect to the duet. Further more after several tries at typing in the duet ip address the esp32 seem to go into a loop. I am unable to delete the data I've entered. I have tried reflashing the ESP32 but altho the flashing seems to work the old data persists. Is there anyway to delete the existing data?
                                      • seeul8erundefined
                                        seeul8er
                                        @pd Strange crash. You can delete flash by calling idf.py -p PORT erase_flash
                                        pdundefined 2 Replies Last reply Reply Quote 0
                                        • pdundefined
                                          pd @seeul8er
                                          @seeul8er Yes I have tried this but I get a fatal error ESP32 ROM does not support function erase_flash. I am using a ESP32 devkitc v4. Where do you store these parameters?
                                          • pdundefined
                                            pd @seeul8er
                                            @seeul8er I am pleased to say I have found the problem. Basically this is because the Ubuntu version of esptool does not for some reason allow the erase-flash function. I had to download it from the python repository.
                                            So I have again managed to connect to the router. Please could you clarify the format of entry for the printer address. Should it anyway be discovered automatically in the same way as the SSID?
