    RepPanel - A DIY alternative to the PanelDue with WiFi support
    Third-party software
    39
    243
    30.5k
    • paralepsisundefined
      paralepsis @seeul8er
      @seeul8er Sorry if I'm being dense, but I'm not working out how to get the password changed!
      I've got v1.1.0 flashed, everything hooked up to the suggested ER-TFTM035-6 screen, it boots and sees available networks, all that good stuff. I'm able to select an appropriate WiFi network. But I need to type a password for that network.
      There's a cursor on the line for the password, and asterisks, but I cannot work out how to type in the right password. I have tried using the keyboard icon in the top-right, but that doesn't seem to be the right thing -- that seems to be strictly for sending gcodes?
      Sorry for the dumb question, hope it's an easy answer :).
      Thanks!
      Railcore II 300XL w/ Duet 3 & RRF 3.5rc4, Makerbot R2X w/ Duet 2 WiFi & RRF 3.4
      paralepsisundefined 1 Reply Last reply Reply Quote 0
        paralepsis @PCR
        @PCR Yes, interested in the PCB. Thanks!
          paralepsis @paralepsis
          Nevermind, discovered the scroll. Sorry for the distraction.
          • seeul8erundefined
            seeul8er
            @pd The following options are supposed to work for the address:
            • Auto discovery using the update/scan button
            • Manual IP entry: XXX.XXX.XXX.XXX
            • Manual mDNS address entry: XXXXX.local
            The prefix http:// or https:// is auto added if not existing. The text field shows .local by default, but there is more in there, the textfield just autoscrolled in that case. Make sure to delete the complete entry before entering your address.
            • PCRundefined
              PCR
              Display is Here! Works too! Will make a final PCB Design tomorrow!
                paralepsis @PCR
                @PCR Excellent!
                • PCRundefined
                  PCR
                  PCB is Ready. Please Upvote this Post so i can see how many i will order!
                  Price should be about 4 € + Shipping
                  Then you only need
                  • ESP32 (https://arduino-projekte.info/wemos-lolin32/) This one got the Battery circuit onboard. I added a switch to the PCB if you want to turn off the RepPanel with the Battery
                  • The display.
                    *2x20 Pin Male Connector ( Thinking about including it)
                  I_Jediundefined paralepsisundefined 3 Replies Last reply Reply Quote 11
                  • NexxCatundefined
                    NexxCat
                    I'd certainly be interested in grabbing a couple of PCB's for this. I have several Duet powered printers 🙂
                    • I_Jediundefined
                      I_Jedi @PCR
                      This post is deleted!
                      • I_Jediundefined
                        I_Jedi @PCR
                        @PCR Count me in for one, 2x20 pins would be helpful 🙂 send me details of how to pay and cost of shipping to 96744 USA
                          paralepsis @PCR
                          @PCR Count me in for two. Please let me know an estimate of shipping to 60515 USA. Thanks for doing this!
                          • A Former User?
                            A Former User
                            Tempting; whats the deadline?
                            • PCRundefined
                              PCR
                              Orderd some with extra spares! Hopefully my tracing is right. Will write when they are here!
                              • KenOloundefined
                                KenOlo
                                Yes, I'm interested
                                • PCRundefined
                                  PCR
                                  ATTENTION I tested the PCB. The Screen freezes after some time. I suspect a Software Problem. I am using RRF 3.2. So this could be the problem due to oiverloading etc. If someone smarter than me could look at the code it would be awesome! Till then buy at your own risk!
                                  Edit: Solved. You need atleast one filament file on the duet
                                  WhatsApp Image 2020-09-16 at 15.55.12(2).jpeg WhatsApp Image 2020-09-16 at 15.55.12.jpeg WhatsApp Image 2020-09-16 at 15.55.12(1).jpeg WhatsApp Image 2020-09-16 at 15.55.26.jpeg
                                  Drop me a PM if you want one! It comes without the ESP Modul, without the GPIO Header/Paneldue, without the Display --> Blank PCB
                                  PCB 4€
                                  GPIO and Paneldue header 1€
                                  ESP32 preflashed 8€ ( i could not use the ESP32 Lolin lite because of not enough pins)
                                  Display you have to buy yourself 😉
                                  • PCRundefined
                                    PCR
                                    RepPanel_PCB.step
                                    The PCB with the Display as a .STEP. If someone wants to make a Case!
                                    • oliofundefined
                                      oliof
                                      Finally got this going, thanks to @PCR s PCB -- very nice. Accidentally invented the sandwich design where the ESP32 sits between the PCB and the display -- makes for a sleek setup. I'll look into making a case for this (-:
                                      I think I need to do two or three things to the code to make this cover my use case -- babystepping during printing, ordering of macros (at least show the numbered macros first like on PanelDue), and maybe one or two other things (-:
                                      • seeul8erundefined
                                        seeul8er
                                        @oliof Great to see you finally got it working. I agree on the macro/job ordering thing. Shouldn't be a big deal.
                                        I do not think I'll invest the time into implementing babystepping. Once you dialed the bed in you really never ever need babystepping in my opinion.
                                        oliofundefined 1 Reply Last reply Reply Quote 1
                                        • oliofundefined
                                          oliof @seeul8er
                                          @seeul8er I might take a stab at it, some of my printers aren't holding their level super well.
                                          • oliofundefined
                                            oliof @oliof
                                            Got distracted ....
                                            Will print a first version tonight...
                                            droftartsundefined DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
