    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    23.1k
    • Danalundefined
      Danal @Adrian52
      @Adrian52 said in DuetLapse available for Alpha testing:
      If you are using the raspberry pi camera, note that it has a default 5 second timeout. If you include -t 1 in the camera parameters, it works much more quickly. I have also started including -ex sports, which uses a fast shutter speed, and -mm matrix, which seems to give a better exposure; -n gives nopreview.
      With the faster response, I now sometimes get more than one extra picture per layer - I got 547 for a 0.2 layer benchy, instead of 240.
      I will add those to the defaults
      • Adrian52undefined
        Adrian52
        https://vimeo.com/415279225
        Is an effort with pla. Used detect - pause, with M226 in the gcode at each layer change. The extra frames have to be deleted before running ffmpeg again
        • arhiundefined
          arhi
          some, not so recent, rpi installation ...
          root@octopi:~/DuetLapse# ./DuetLapse.py -h
          Traceback (most recent call last):
            File "./DuetLapse.py", line 21, in <module>
              import DuetWebAPI as DWA
            File "/root/DuetLapse/DuetWebAPI.py", line 27
              URL=(f'{self._base_url}'+'/rr_status?type=1')
          SyntaxError: invalid syntax
          root@octopi:~/DuetLapse# python3
          python3     python3.5   python3.5m  python3m
          root@octopi:~/DuetLapse# python3 DuetLapse.py -h
            File "DuetLapse.py", line 21, in <module>
          after rpi-update
          root@octopi:~/DuetLapse# python3 --version
          Python 3.5.3
          root@octopi:~/DuetLapse# python3 ./DuetLapse.py -h
          • arhiundefined
            arhi
            hm and just in case wget messed something up .. git clone of both repos
            root@octopi:~/DuetLapse/DuetLapse# PYTHONPATH=/root/DuetLapse/DuetWebAPI python3 DuetLapse.py  -h
              File "/root/DuetLapse/DuetWebAPI/DuetWebAPI.py", line 27
            I don't get it, I don't see that this line changed since forever?!
            looks like F-Strings are in from 3.6 only raspbian on pi3b+ latest comes with 3.5.3 😞
            • Danalundefined
              Danal
              @arhi said in DuetLapse available for Alpha testing:
              @arhi Very interesting, I don't get that, and that line is not a syntax error. Hmmm... Let me think of a way to pin this down.
              arhiundefined 1 Reply Last reply Reply Quote 0
              • arhiundefined
                arhi @Danal
                @Danal said in DuetLapse available for Alpha testing:
                F-strings are 3.6 python from what I read online, and stretch has max python 3.5.3 ... I'm now going to move to buster and see if it uses newer python
                Danalundefined 1 Reply Last reply Reply Quote 0
                • Danalundefined
                  Danal @arhi
                  Excellent detective work. I had no idea f was that recent.
                  • arhiundefined
                    arhi @Danal
                    @Danal I don't use python at all so I don't have anything but what's normally there with the distro... so, troubles with buster too it comes with newer python but again
                    root@octopi:~/DuetLapse/DuetLapse# apt-get install python3-numpy python-numpy
                    Reading package lists... Done
                    Building dependency tree
                    Reading state information... Done
                    python-numpy is already the newest version (1:1.16.2-1).
                    python3-numpy is already the newest version (1:1.16.2-1).
                    root@octopi:~/DuetLapse/DuetLapse# python3 DuetLapse.py -h
                    Python Library Module 'numpy' is required.
                    Obtain via 'sudo python3 -m pip install numpy'
                    root@octopi:~/DuetLapse/DuetLapse# python3 -m pip install numpy
                    Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                    Requirement already satisfied: numpy in /usr/local/lib/python3.7/dist-packages (1.18.4)
                    root@octopi:~/DuetLapse/DuetLapse# pip3 install numpy
                    root@octopi:~/DuetLapse/DuetLapse# python3 --version
                    Python 3.7.3
                    root@octopi:~# python3
                    Python 3.7.3 (default, Dec 20 2019, 18:57:59)
                    [GCC 8.3.0] on linux
                    Type "help", "copyright", "credits" or "license" for more information.
                    >>> import subprocess
                    >>> import sys
                    >>> import argparse
                    >>> import time
                    >>> import numpy as np
                      File "/usr/local/lib/python3.7/dist-packages/numpy/core/__init__.py", line 24, in <module>
                        from . import multiarray
                      File "/usr/local/lib/python3.7/dist-packages/numpy/core/multiarray.py", line 14, in <module>
                        from . import overrides
                      File "/usr/local/lib/python3.7/dist-packages/numpy/core/overrides.py", line 7, in <module>
                        from numpy.core._multiarray_umath import (
                    ImportError: libf77blas.so.3: cannot open shared object file: No such file or directory
                    During handling of the above exception, another exception occurred:
                      File "<stdin>", line 1, in <module>
                      File "/usr/local/lib/python3.7/dist-packages/numpy/__init__.py", line 142, in <module>
                        from . import core
                      File "/usr/local/lib/python3.7/dist-packages/numpy/core/__init__.py", line 50, in <module>
                        raise ImportError(msg)
                    ImportError:
                    IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
                    Importing the numpy C-extensions failed. This error can happen for
                    many reasons, often due to issues with your setup or how NumPy was
                    installed.
                    We have compiled some common reasons and troubleshooting tips at:
                        https://numpy.org/devdocs/user/troubleshooting-importerror.html
                    Please note and check the following:
                      * The Python version is: Python3.7 from "/usr/bin/python3"
                      * The NumPy version is: "1.18.4"
                    and make sure that they are the versions you expect.
                    Please carefully study the documentation linked above for further help.
                    Original error was: libf77blas.so.3: cannot open shared object file: No such file or directory
                    I love how consistent APT system is 😞
                    • arhiundefined
                      arhi
                      apt-get install libatlas-base-dev
                      solved the numpy error
                      • arhiundefined
                        arhi
                        one hint, I don't know python but might be cool to add argument to DuetLapse to point to DuetWebAPI library?
                        I added directly to code
                        diff --git a/DuetLapse.py b/DuetLapse.py
                        index eee4a51..5119d61 100755
                        --- a/DuetLapse.py
                        +++ b/DuetLapse.py
                        @@ -17,6 +17,9 @@ import subprocess
                         import sys
                         import argparse
                         import time
                        +sys.path.insert(1, "../DuetWebAPI/");
                         try:
                         except ImportError:
                        but would be cool to read that from the argument line 🙂 so we can normally git pull changes and not need to copy stuff over each other 😄 especially as python is ignoring symlinks
                        • arhiundefined
                          arhi
                          @Danal you tested this with 3.01RC12? and DWC 2.1.7?
                          root@octopi:~/DuetLapse/DuetLapse# cd ../DuetWebAPI/
                          root@octopi:~/DuetLapse/DuetWebAPI# git pull
                          Already up to date.
                          root@octopi:~/DuetLapse/DuetWebAPI# cd -
                          /root/DuetLapse/DuetLapse
                          root@octopi:~/DuetLapse/DuetLapse# python3 DuetLapse.py -duet ender5.local.lan -camera usb -detect layer -pause no
                          Attempting to connect to printer at ender5.local.lan
                          http://ender5.local.lan  does not appear to be a RRF2 or RRF3 printer
                          Device at ender5.local.lan either did not respond or is not a Duet V2 or V3 printer.
                          root@octopi:~/DuetLapse/DuetLapse# fping ender5.local.lan
                          ender5.local.lan is alive
                          root@octopi:~/DuetLapse/DuetLapse# telnet ender5.local.lan
                          Trying 192.168.89.246...
                          Connected to ender5.local.lan.
                          Escape character is '^]'.
                          M122
                          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC12 running on Duet Ethernet 1.02 or later
                          telnet> c
                          Connection closed.
                          • arhiundefined
                            arhi
                            this last part was on me - works ok now 🙂
                            • arhiundefined
                              arhi
                              @Danal I don't know python so this should probbly be done better by somehow defining parameter to onePhoto() not mandatory, or if there's already a global with this info but this works awesome for me so if you like you integrate 😄
                              root@octopi:~/DuetLapse/DuetLapse# git diff
                              old mode 100755
                              new mode 100644
                              index eee4a51..1539257
                              --- a/DuetLapse.py
                              +++ b/DuetLapse.py
                               import sys
                               import argparse
                               import time
                               try:
                               except ImportError:
                              @@ -204,11 +207,15 @@ def unPause():
                                       printer.gCode('M24')
                                       alreadyPaused = False
                              -def onePhoto():
                              +def onePhoto(zl):
                                   global frame
                                   frame += 1
                                   s="{0:08d}".format(int(np.around(frame)))
                              -    fn = '/tmp/DuetLapse/IMG'+s+'.jpeg'
                              +    if (zl > -1):
                              +      zlayer="{0:8d}".format(int(zl))
                              +      fn = '--title "Layer '+zlayer+'" /tmp/DuetLapse/IMG'+s+'.jpeg'
                              +    else:
                              +      fn = ' /tmp/DuetLapse/IMG'+s+'.jpeg'
                                   if ('usb' in camera):
                                       if (camparms == ''):
                              @@ -226,6 +233,7 @@ def onePhoto():
                                       else:
                                           cmd = 'wget '+camparms+' -O '+fn+' "'+weburl+'" '
                              +    print(cmd)
                                   subprocess.call(cmd, shell=True)
                                   global timePriorPhoto
                                   timePriorPhoto = time.time()
                              @@ -240,20 +248,20 @@ def oneInterval():
                                           # Z changed, take a picture.
                                           checkForcePause()
                                           print('Capturing frame {0:5d} at X{1:4.2f} Y{2:4.2f} Z{3:4.2f} Layer {4:d}'.format(int(np.around(frame)),printer.getCoords()['X'],printer.getCoords()['Y'],printer.getCoords()['Z'],zn))
                              -            onePhoto()
                              +            onePhoto(zn)
                                       zo = zn
                                   elap = (time.time() - timePriorPhoto)
                                   if ((seconds) and (seconds < elap)):
                                       checkForcePause()
                                       print('Capturing frame {0:5d} after {1:4.2f} seconds elapsed.'.format(int(np.around(frame)),elap))
                              -        onePhoto()
                              +        onePhoto( -1 )
                                   if ('pause' in detect):
                                       if ('paused' in printer.getStatus()):
                                           global alreadyPaused
                                           alreadyPaused = True
                                           print('Pause Detected, capturing frame {0:5d}'.format(int(np.around(frame)),elap))
                              -            onePhoto()
                              +            onePhoto( -1)
                                       unPause()
                               def postProcess():
                              (print(cmd) was just me debuging, that's not needed)
                              • Danalundefined
                                Danal
                                Python honors symlinks, that is exactly how I'm keeping one central copy of DuetWebAPI and not copying it around to each DuetLapse, TAMV, etc, etc. as I develop this stuff. If you want it not in the current directory, and/or don't want to use symlinks, then properly put it in Python's path please.
                                By the way, git clone will NOT update things, 'wget' has all kinds of edge cases, I haven't found a really bullet proof way to distribute scripts from github (besides set up a package server. Which I am reluctant to do, and even that requires entries in /etc directories on user endpoints).
                                Anyway, symlinks work fine, I'm curious why yours don't.
                                ln -s ../DuetWebAPI/DuetWebAPI.py DuetWebAPI.py right?
                                Screenshot to get colors:
                                arhiundefined 1 Reply Last reply Reply Quote 1
                                • arhiundefined
                                  arhi @Danal
                                  kill me if I know why but it didn't work .. I'll try again later but this work as is now so ...
                                  Need to try that again, when I did with PYTHONPATH=/root/DuetLapse/DuetWebAPI python3 DuetLapse.py it was finding api ok but failed something else, but maybe now that I fixed the other thing that will work, will try 🙂
                                  of course, git pull does ( git checkout or stash first if files are modified 😄 like they are now)
                                  git clone
                                  git pull
                                  git checkout/stash
                                  works awesome, the only issue I need to handle is this path for libs so it knows how to find api, will retest this but even as is it's not a biggy
                                  hahaha retested the symthing now, it works, the %^$#*&^#
                                  PYTHONPATH=/root/DuetLapse/DuetWebAPI python3 DuetLapse.py -h works too, I'll use this way .. the problem was obviously the numpy or whatever is that thing called...
                                  anyhow, these are irrelevant parts of that diff 🙂 .. what about that change in the onePhoto() ? makes sense?
                                  • arhiundefined
                                    arhi
                                    • Danalundefined
                                      Danal @arhi
                                      Don't you just love things like that!
                                      anyhow, these are irrelevant parts of that diff .. what about that change in the onePhoto() ? makes sense?
                                      Makes perfect sense, I just need time to look at it... probably next day or two.
                                      • arhiundefined
                                        arhi @Danal
                                        I'm not 40 any more, doing things between 3 and 5am obviously need to be doublechecked 😄 😄 😄
                                        • Danalundefined
                                          Danal @Adrian52
                                          Great program, but I still have not got it quite right. I am currently using. /DuetLapse - duet 192.168.1.16 -camera pi -detect pause, with M25 and M400 added to each layer in gcode (easy to do in kisslicer). The problem is that two frames are taken, one when the head is moved away by pause.g, the second a bit later, when the print has resumed. I also get an error message on the console 'm24: cannot print because no file is selected'. It looks as though the m24 is being sent twice.
                                          I have edited my pause.g so that there is no z shift.
                                          Just pushed changes to the detect pause logic that should eliminate this. It has been tested to ensure no syntax errors, but has not been run through a print.
                                          Adrian52undefined 1 Reply Last reply Reply Quote 0
                                          • Adrian52undefined
                                            Adrian52 @Danal
                                            @Danal here is my first go
                                            https://vimeo.com/415969620
                                            Worked fine with M226 in the gcode file. Excellent. Will try detecting layer changes later. Great work.
