    Any full working Ender 5 Plus configurations?
    1178
    • catsandicecream
      catsandicecream last edited by
      I've been trying to edit a modified ender 5 configuration for the ender 5 plus and using the reprapfirmware configuration to generate config files. However the BLTouch settings generated by the configurator definitely needed editing afterwards. Also it defaults to homing Z with an end stop and not with the probe as well has homing x and y to 0 when it hits the endstops in the far right instead of front left as the origin.
        If you post your config and homing files we can probably get you sorted out. What firmware version are you using?
        • catsandicecream
          I put my config up here -
          https://github.com/yincrash/Ender-5-Plus---Duet-2-Wifi-or-Ethernet-Configuration
          And made a tiny tester @ 0.24mm layers that has a bit of stringing with PLA, but otherwise reasonably solid. I may tweak my PrusaSlicer settings.
          Tiny_Tester-e5.gcode
          How can I determine what are my max speeds for my axes and are there any optimizations I forgot? I think I will also re-use the bed mesh saved to disk instead of constantly probing the bed every run. Also, when doing the top layer, the extruder skipped a bit. Not sure if that's from my slicer settings or the extruder rate in config.
            I think you've got an ok start. If you've already got it printing that's 90% of the battle.
            Check this out: https://forum.duet3d.com/topic/14250/tuning-jerk-accel-speed-settings/2?_=1586651239957
            • catsandicecream
              catsandicecream last edited by catsandicecream
              @Phaedrux said in Any full working Ender 5 Plus configurations?:
              Thanks
              Additionally, has anyone tried making the existing touch screen panel work? I'm assuming it's the same touch screen in the CR-10S Pro, the model on the panel says "dmt48270c043_06wt". It seems to be a commodity panel, but I assume Creality put some sort of firmware on it for easy communication between the panel and the main board
              • conorsmyth
                conorsmyth last edited by
                Hi, did you get this working in the end. I'm trying to do the same. I was also wondering if you put the second z motor into one of the extruder slots or did you somehow wire the motors together to the same driver?
                Either way I'd look forward to hearing how it turned out 🙂
                • leewaa
                  leewaa last edited by
                  Old topic but possibly valuable information available on this, hence a thread revival/bump.
                  @catsandicecream did you end up making progress on this ?
                  • Reine
                    Reine last edited by
                    If someone has a working config I would be interested in having a look as I'm in the process of converting my Ender 5+.
                    • droomoo
                      droomoo last edited by
                      I also would be interested in a config dump as I have an Ender 5 Plus I want to convert as well.
                      • catsandicecream
                        Sorry, I don't have notifications turned on. I'm finally upgrading to RRF 3.x, and will have an updated configuration once I have everything working again.
                        catsandicecream 1 Reply Last reply Reply Quote 1
                        • catsandicecream
                          catsandicecream @catsandicecream last edited by
                          I've updated my config for RRF 3.x and updated it on GitHub - https://github.com/yincrash/Ender-5-Plus---Duet-2-Wifi-or-Ethernet-Configuration
                          Will happily take any input if people have better settings.
