    Configuring temp reading from sensor for heated chamber
    1.1k
    • felt342undefined
      felt342
      Hello folks,
      I would like to put an e3d normal temperature sensor to use as chamber temperature monitoring and make it visible in DWC.
      I do have DuetWifi with PT100. So I have spare two temperature sensor channels from hotends. I am curious how can I set up this in config.g? I don't have a heater yet, I would like to just to see what temperature can be raised with only heated bed.
      I would like to plug this (https://e3d-online.com/thermistor-cartridge) thermistor here -
      ; generated by RepRapFirmware Configuration Tool v2.1.4 on Thu Jan 02 2020 22:17:48 GMT+0100 (Central European Standard Time)
      G90                                             ; send absolute coordinates...
      M83                                             ; ...but relative extruder moves
      M550 P"own"                                     ; set printer name
      M667 S1                                         ; select CoreXY mode
      M552 S1                                         ; enable network
      M586 P0 S1                                      ; enable HTTP
      M586 P1 S0                                      ; disable FTP
      M586 P2 S0                                      ; disable Telnet
      M569 P0 S1                                      ; physical drive 0 goes forwards
      M569 P1 S1                                      ; physical drive 1 goes forwards
      M569 P2 S1                                      ; physical drive 2 goes forwards
      M569 P3 S1                                      ; physical drive 3 goes backwards
      M569 P4 S0                                      ; physical drive 4 goes forwards
      M584 X0 Y1 Z2 E3:4                              ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1                      ; configure microstepping with interpolation
      M92 X200.0 Y200.0 Z400 E415:415			; set steps per mm
      M566 X700 Y700 Z120 E5000.00:5000.00      	; set maximum instantaneous speed changes (mm/min)
      M203 X15000 Y15000.00 Z600 E13000.00:13000.00   ; set maximum speeds (mm/min)
      M201 X1300 Y1500 Z300 E4000.00:4000.00      	; set accelerations (mm/s^2)
      M906 X1450 Y1450 Z1400 E500:500 I30             ; set motor currents (mA) and motor idle factor in per cent
      M84 S90                                         ; Set idle timeout
      M208 X-15 Y0 Z0 S1                                ; set axis minima
      M208 X311 Y212 Z345 S0                        ; set axis maxima
      M574 Z1 S2                		     ; set active low and disabled endstops
      M574 X1 S0                			  ; set active high endstops
      M574 Y2 S0
      M307 H3 A-1 C-1 D-1                             ; disable heater on PWM channel for BLTouch
      M558 A2 S0.005 P9 H5 F400 T10000 R0.1                          ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-10 Y-18.3 Z0.99                           ; set Z probe trigger value, offset and trigger height (positive value brings bed closer)
      M557 X0:290 Y-18.0:190 S15                      ; define mesh grid
      M307 H0 B0 S1.00                        		; disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 T100000 B4138 R4700             		; set thermistor + ADC parameters for heater 0
      M143 H0 S140                            		; set temperature limit for heater 0 to 160C
      M305 P1 X200                                    ; configure PT100 for heater 1
      M143 H1 S450                                    ; set temperature limit for heater 1 to 450C
      M305 P2 X201                                    ; configure PT100 for heater 2
      M143 H2 S450                                    ; set temperature limit for heater 2 to 450C
      M106 P0 S0 I0 F500 H-1                          ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H-1                          ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S1 I0 F500 H-1                          ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 S"Left" D0 H1 F-1                       ; define tool 0
      G10 P0 X0 Y0 Z0                                 ; set tool 0 axis offsets
      G10 P0 S0 R185 									; Set tool 0 active and standby temperatures
      M563 P1 S"Right" D1 H2 F-1                      ; define tool 1
      G10 P1 X19.7 Y0 Z0                               ; set tool 1 axis offsets
      G10 P1 S0 R185 									; Set tool 0 active and standby temperatures
      M501                                            ; load saved parameters from non-volatile memory
      Industrial 3D printing service in the Netherlands - gagatstudio.com
      • sebkritikelundefined
        sebkritikel
        Check out the M305 command. In short, you will need to:
        • Assign a "virtual" heater number, e.g. P102, P103, etc
        • Define the virtual heater name , such as S"Chamber" or S"Y-Stepper"
        • Define the "heater" ADC channel, such as X3, X4. The 'X' value should be one more than the number silkscreened on the Duet/Duex CCA ( E2 would be X3, E3 would be X4)
        • Define temperature sensor values (T, B, C, R) per configurator tool or E3D documentation
        Here are two of my "virtual heaters". X3 is E2 on the DueX, X4 is E3 on the Duex
        M305 P102 P103 S"Chamber1" X3 T100000 B4725 C7.060000e-8 R4700
        M305 P103 P104 S"Y-Stepper" X4 T100000 B4725 C7.060000e-8 R4700
        EDIT: I missed this section when setting up my virtual heaters:
        Virtual heaters 100, 101 and 102 are preconfigured to use temperature sensor channels 1000, 1001 and 1002 respectively. We suggest you use virtual heaters 103 upwards if you want to create additional virtual heaters.
        Just changed P102 to P103, and P103 to P104 in my config.g to avoid conflicts with the Duex driver over temperature warning.
        https://duet3d.dozuki.com/Wiki/Heaters
        Large(ish?) IDEX - 6HC, 1HCL
        Stratasys Dimension 1200es to 6HC Conversion
        felt342undefined 1 Reply Last reply Reply Quote 1
        • felt342undefined
          felt342 @sebkritikel
          @sebkritikel
          Thank you!
          Cant check it now as printer is printing. But as I understood it should be like that if I want to plug the thermistor into the E0 sensing channel?
          M305 P103 S"Chamber" X1 T100000 B4725 C7.060000e-8 R4725		;set thermistor for heated chamber
          sebkritikelundefined 1 Reply Last reply Reply Quote 0
            sebkritikel @felt342
            @felt342 said in Configuring temp reading from sensor for heated chamber:
            @sebkritikel
            Thank you!
            Looks just about right to me! I think the only issue is 'R' should be R4700, not R4725, but I may be mistaken.
            https://duet3d.dozuki.com/Wiki/Connecting_thermistors_or_PT1000_temperature_sensors
            Per that link, it appears the 'R' value is not needed in your (our) case.
            • felt342undefined
              @sebkritikel
              Yes might be for R-value, I just used configuration tool to see the values, as there you can select E3D thermistor 🙂
              But if I don't need it then doesn't matter! I need to wait 5 hours before I can check if its works 🙂
              • mendenmhundefined
                mendenmh
                You should be able to enter these commands from DWC while the printer is running, as long as you are careful not to type the wrong command. And then you should be able to plug in the sensor. This stuff should have no effect on a running print. Make sure you discharge static before you plug in the sensor, though.
                felt342undefined 1 Reply Last reply Reply Quote 0
                • felt342undefined
                  felt342 @mendenmh
                  @mendenmh
                  Hah, that's works! Thank you!
                  Another thing is is it possible to add it to the dashboard next to the Bed heater for example? For now I can only see it in graphs section -
                  • gowenundefined
                    gowen
                    For future reference, under RRF3 the M305 command needs to be replaced with M308.
                    This is from my machine where I have a thermister connected to the second extruder (E1) thermister connector. The A term is the name of the sensor that appears in the extras list. The S value should be between 0 and 31 for a Duet 2.
                    M308 S10 A"Extra Thermister" P"e1_temp" Y"thermistor" T100000 B3950 R4700
                    More details at https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M308_Create_or_modify_sensor_or_report_sensor_parameters
