    Duet won't boot problem
    743
    • mkrsjakundefined
      mkrsjak
      MY Duet 2 wifi 1.04 stopped booting. only the blue VIN diode is on, any idea where what might be wrong?
      • A Former User?
        A Former User @mkrsjak
        @mkrsjak said in Duet won't boot problem:
        fuse or 5v regulator died, check fuse then the chip labeled U3 and in general:
        https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
        • mkrsjakundefined
          mkrsjak
          Fuses are intact, how can I check the U3? Visually it looks ok.
          • A Former User?
            A Former User
            the 5v LED that isn't on is the second best indicator; if the fuse is okay and you don't get a 5v led u3 isn't working (possible but less likely one of the small diodes around u3 can fail, usually as a cascade failure i think).
            in any case if you don't have a 5v led and nothing is connected (like paneldue or zprobe etc) then odds are something is damaged.
            Does anything get hot? Does it work if powered from usb?
            • mkrsjakundefined
              mkrsjak
              @bearer said in Duet won't boot problem:
              I took a microscope and the u3 is indeed damaged.
              Is there any guide how to replace it? And what is actually the part number? 🦆
              • A Former User?
                A Former User
                any guide to rework of a QNF chip will do, but you will need proper preheating as the board is 2oz copper, and has 4 layers where 3 are most ground planes.
                Part is a A4403GEUTR
                mkrsjakundefined 1 Reply Last reply Reply Quote 0
                • A Former User?
                  could be worth noting it may be covered by the manufacturers warranty if the board is less than 6 months; unless its caused by a short in wiring or other external factors.
                  • mkrsjakundefined
                    mkrsjak @A Former User
                    @bearer The board is more than 1 year old. I thought we have EU warranty 2 years,but apparently not.
                    • A Former User?
                      that could be something to ask your vendor about; I would have consumer protection rights if purchased locally even if the manufacturer says 6 months but I can't speak to your local rules; and it would be a matter for the vendor, not the manufacturer.
                      • mkrsjakundefined
                        A4403GEUTR
                        I found this one, seems to be within fast shipping reach.
                        https://www.tme.eu/at/en/details/a4403geutr-t/voltage-regulators-dc-dc-circuits/allegro-microsystems/
                        • A Former User?
                          A Former User
                          Looks like the correct one. (but you will need a hot air station, a preheater/hotplate and some good flux as well)
                          mkrsjakundefined 2 Replies Last reply Reply Quote 0
                          • mkrsjakundefined
                            Have hotair, no preheat and really doing this the first time.
                            • mkrsjakundefined
                              @bearer are the other 2 numbers important? 4403T XXXX YYYL ? cause there are many versions with different X and Y
                              • T3P3Tonyundefined
                                T3P3Tony administrators
                                4403T XXXX YYYL
                                The A4403 datasheet is here:https://www.allegromicro.com/~/media/Files/Datasheets/A4403-Datasheet.ashx
                                The part numbering specifically
                                www.duet3d.com
                                • mkrsjakundefined
                                  mkrsjak
                                  ok, will buy and hopefully fix it, will post the result. thank you all for the outstanding help!
                                  • A Former User?
                                    just be carefull with the surrounding parts, shield with kapton or alu tape (don't take the paper backing off the alu tape, it makes a mess (when very hot))
                                    • A Former User?
                                      to add on Tonys reply; usually the last few numbers/letters refer to packageing, both in terms of which package it is (qnf, qft, bga sop etc) and how its packaged, tape, tray, tube etc; and the details are usually in the datasheets. (I posted the variant that is commonly available as "cut tape" in low quantity)
                                      • mkrsjakundefined
                                        mkrsjak
                                        QNF
                                        I was something else wrong with the board. The U3 gets fried again, even with no connections except the power IN.
                                        I will buy a replacement, but really not see a point buy from duet with only 6months of warranty. This should be fixed in general.
                                        Even shoes and heavily wearing products have 2 years. Shame.
                                          Sorry to hear you've had an unfortunate hardware failure and were unable to resolve it. The warranty provided can be reviewed here: https://www.duet3d.com/warranty
                                          Unfortunately you're out of the warranty period it would seem. However, we may be able to provide you with a refurbished board at a reduced price on exchange. Please contact roland@duet3d.com to inquire about current availability.
