    Solved Simple question: How to read from IO
    642
    • JBisc
      JBisc last edited by JBisc
      Sorry for the stupid question (neither google nor the forum search helped me):
      I could not find a Gcode command to read one of my IO? How is it possible? I would assume that there is a gcode command witch returns a json...
      For Marlin I found M43, but for duet it seem to be different....
      My Setup: Duet 3 MB6HC Main Board with attached RPI
      • JBisc
        Ok it seems to be easy:
        just call
        M308 S4
        to get the sensor value.
          Use any or all of:
          • M577 to wait for an input pin to be in a particular state
          • M581 (and possibly M582) to cause some action to take place when the state of an input pin changes
          • In RRF 3.01, M409 or conditional GCode to query the value of sensors.inputs[n] for some n
          JBisc 1 Reply Last reply Reply Quote 1
          • JBisc
            JBisc @dc42 last edited by JBisc
            @dc42 Thanks: I will try
            M409 K"sensors.inputs"
            Maybe some feedback: Does it make sense to include a small example in the gcode documentation, that I will be the last person who is asking? 🙂 Normally the people search for "read io"/ "read voltage" / "get sensor value" and its hard for them/me to find something in the documentation.
              dc42 administrators @JBisc last edited by
              @JBisc, you will need to create a GPIO port attached to your chosen pin using M950 with the J option, before you can see it in sensors.inputs.
              Yes an example would help. If you tell us what you are trying to achieve, we could use that as an example.
              JBisc 2 Replies Last reply Reply Quote 0
              • JBisc
                @dc42 I believe that my scenario is not a very common one. I am working on a complex algorithm to measure the 2D/3D-geometry of my workpiece. The algorithm is to complex to implement it in gcode, therefor I implement a supersiving software layer in python (think about a python-gcode wrapper) which calculates the algorithm. Then, the supervising software optimize the 3dprinter.
                • Danal
                  Danal last edited by
                  Curious side question: Where are you running the Python?
                  • jens55
                    jens55 last edited by
                    Visions of automated probing are running through my head .... could be as simple as setting resolution for x and y, setting a range of x and y and telling the printer to measure every point. Might be painfully slow but hey, it could do it. Put every value into a spreadsheet which can then be imported into Fusion360 and presto, the beginnings of a model. Obviously some hand work is required.
                    As a side question, just exactly how accurate is a 3D scanned object? Are the scanned objects dimensionally accurate or could manually probing increase accuracy?
                    In any case, having a probing tool head for quality control of a printed object might be interesting.
                    • JBisc
                      JBisc @Danal last edited by JBisc
                      @Danal currently on the RPI. Ohhhh Danal, you are the author of the wrapper which I use. Great to meet you here! Thanks for your amazing work. I started with forking your project (https://github.com/DanalEstes/PythonDSF)
                      Danal 1 Reply Last reply Reply Quote 0
                      • Danal
                        Danal @JBisc last edited by
                        @JBisc said in Simple question: How to read from IO:
                        There's another choice now as well: DuetWebAPI. Requires network connectivity to the printer (can, but not required to, run on the attached Pi) and also abstracts away V2 to V3 differences.
                        • JBisc
                          @dc42 said in Simple question: How to read from IO:
                          If I use M950 by
                          M950 J4 C"io4.in"
                          I can get only a ditgital input by calling
                          which is not what i want.
                          If I define my sensor by
                          M308 S4 P"io4.in" Y"linear-analog" A"MySensor" F0
                          I don't know a method to return my analog sensor value (to the RPI). Does somebody has an idea?
                          • JBisc
                            just call
                            M308 S4
                            • Danal
                              When you say "return to the Pi", what would happen? Push? Pull? what code reads it or responds or...
                              What do you want to happen?
                              • JBisc
                                I implemented in the following way now:
                                My python programm on the RPI sends
                                M308 S4
                                and i parse the response (on the RPI)
                                Sensor 4 (MySensor) type Linear analog using pin io4.in, reading 3.8, last error: success, unfiltered, range 0.0 to 1.0
                                  You could also get it by using M409 to request that value from the object model.
                                  JBisc 1 Reply Last reply Reply Quote 0
                                  • JBisc
                                    M409
                                    I remember that you posted in another post that analog values are not included in the current object model
                                      dc42 administrators @JBisc last edited by dc42
                                      M409
                                      Raw analog inputs are not included, but the readings from configured sensors are:
                                      20/04/2020, 09:55:19 	m409 k"sensors.analog[0].lastReading"
                                      {"key":"sensors.analog[0].lastReading","flags":"","result":21.5}
                                      • Referenced by  pouic1313 pouic1313
