slicer setting g-code type
i am new to duet 2 wifi and have doubts about what to use in my slicer should i use marlin or reprap g-code type
Use reprap gcode flavour.
thank you
now it has started to make a sound as i switch from marlin to reprap
A good sound I hope.
a little pee noises that were not there before which happens every second from the extruder motor and think it is not good sound but I do not know
link to youtude video https://www.youtube.com/watch?v=roXHd-qJF8c
that is an interesting sound, but without any other info to go on I'm not sure what to say.
Add some details for us please: https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
3d printer ender 3 pro
and this is the whole file for confik.g
; generated by RepRapFirmware Configuration Tool v2 on Mon Jan 07 2019 23:53:31 GMT+0200 (Eastern European Standard Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 PEnder3 ; Set machine name
M552 S1 ; Enable network;M587 S"FiberSwag_IoT" P"SonosErGud123" I10.0.1.9 J10.0.1.1 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; Drive 0 goes backwards
M92 X80.00 Y79.892 Z400.00 E94.50 ; Set steps per mm
M566 X900.00 Y900.00 Z12.00 E300.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z300.00 E18000.00 ; Set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
M906 X600.00 Y600.00 Z600.00 E800.00 I50 ; Set motor currents (mA) and motor idle factor in per cent
M84 S60 ; Set idle timeout; Axis Limits
M208 X235 Y235 Z250 S0 ; Set axis maxima; Endstops
; M574 X1 Y1 S1 ; Set active high endstops
M574 X1 Y1 S1 ; X home to min. Y home to max. Normally Closed limit switches.; Z-Probe
M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
M558 P9 H5 F120 T6000 X0 Y0 Z1 ; Set Z probe type to bltouch and the dive height + speeds
G31 P25 X48 Y-2 Z1.19 ; Set Z probe trigger value, offset and trigger height
M557 X50:230 Y50:230 S10 ; Define mesh grid; Heaters
M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P0 S255 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S255 I0 F500 H1 T45 ; Set fan 1 to turn on full speed when Hotend reaches 45
M106 P2 T45:65 H100:101:102 ; Set fan 2 to turn on when MCU reaches 45 and reach full speed when MCU reaches 65 or any TMC2660 report over-temperature; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
T0 ; Select first tool -
slicer fil CE3_X_1_layer_test_bed_leveling.gcode
Your first gcode posted (blot.gcode) was using marlin flavour and included some speed commands in the start gcode. The second one you posted is in Reprap flavor, which is correct, and those commands are no longer present.
Other than the noise, what is actually happening?
When does the noise occur? During a print? Just sitting there?Your config file looks ok.
@Phaedrux it's just the sound.
As far as I know -
Does it extrude properly?
the extrusion properly I think. trying to get 3d printer running properly and try me to get it printed in good quality, but you can see that the z axis is doing poor quality I just found out. so I can't say if it extrudes properly. but try to fix it
but thanks for the help
