    Fluctuating HE temp. fault temp rising slow! NOT solved
    • claustroundefined
      claustro
      I was receiving a lot of " temperature rising much more slowly than the expected 1.5°C/sec " so I changed thermistor made pid tuning and saved with M500
      My thermistor is this one https://www.aliexpress.com/item/33060324923.html
      configured as follow:
      M305 P1 T100000 B4267 R4700 H0 L0
      the result fo pid tuning stored in config override is as follow
      M307 H1 A457.6 C313.0 D0.9 S1.00 V24.0 B0
      this is the temperature graph
      the variation is about 7 degrees over the target and then back ( 200-207)
      I tried to increase the dead time as suggested here https://forum.duet3d.com/topic/490/fluctuating-temperature in autotune result from 0.9 to 2 but the fluctuation remained with the same amplitude but now the temperature drop below the target (198-205)
      This problem occurs even if in standby
      what I am missing?
      Firmware Name:	RepRapFirmware for Duet 2 WiFi/Ethernet
      Firmware Electronics:	Duet WiFi 1.0 or 1.01
      Firmware Version:	2.02RC3(RTOS) (2018-10-17b2)
      WiFi Server Version:	1.21
      Web Interface Version:	1.22.4-b1
        droftarts administrators @claustro
        @claustro What M303 command did you use to tune the hot end? It's best to set a target temperature, eg M303 H1 S200. Did you have the hot end fan on? Do you have a silicone cover for the hot end? See here for guidance resolving these issues: https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
        And also: https://duet3d.dozuki.com/Wiki/Spurious_heater_faults_and_how_to_avoid_them
        You could try increasing the dead time (D) further; both of my printers are around 5 seconds (though I could probably do with tuning them, too!).
        If your thermistor is a Semitec 104GT-2, you should configure M305 like this:
        M305 P1 T100000 B4725 C7.060000e-8 R4700
        I'm not sure where you got the beta value of B4276 from? It's probably reporting very inaccurate temperatures.
        Lastly, I'd also suggest that you update you firmware, WiFi firmware and DWC. Latest version of the v2 RepRapFirmware is here: https://github.com/dc42/RepRapFirmware/releases/tag/2.05.1
        Update using the following:
        Duet2CombinedFirmware.bin
        DuetWebControl-SD-2.0.7.zip
        DuetWiFiServer-1.23.bin
        See update instructions here: https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
        You shouldn't need to update your config.g to do this, but do check the update notes in case there's anything that has changed that you rely on: https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md
        claustroundefined 1 Reply Last reply Reply Quote 0
        • claustroundefined
          claustro @droftarts
          @droftarts said in Fluctuating hotend temperature:
          thank you for answering me the command I amusing for paid tuning is
          M303 H1 S200
          Yes I read about it in duet wiki but the seller where I bought the thermistor state that the correct B is 4267 anyway I'll try 4725 ( 4267 is reported on the seller's page linked in my first thread
          I don't have silicone sock and I am using the same fan I was using before receiving errors
          I'll update the firmware, I never did 'cos I am not planning to use the new features and till now the printer worked like a charm 😞
          thank you very much for taking the time to answer me
          Andrea
          • claustroundefined
            claustro
            I managed to solve the problem simply by making another pid tuning. Now the temperature is perfect
            Thx all
            • claustroundefined
              claustro
              I am still having issues.
              I still have erratic temperature behavior,
              Error: Heating fault on heater 1, temperature rising much more slowly than the expected 1.5°C/sect
              Error: Heating fault on heater 1, temperature excursion exceeded 15.0°C
              The problem occur also when the printed is in standby, checked all connections, changed 2 HE and 2 thermistor, I am really can't think what to do now
              paid tuning also take forever and act strangely.
              26/4/2020, 16:10:31	Auto tune phase 2, heater off
              26/4/2020, 16:08:26	Auto tune phase 1, heater on
              26/4/2020, 16:08:20	M303 H1 S240
              26/4/2020, 15:34:31	M500
              26/4/2020, 15:33:30	M307 H1
              Heater 1 model: gain 505.8, time constant 218.8, dead time 4.4, max PWM 1.00, calibration voltage 24.0, mode PID, inverted no, frequency default
              Computed PID parameters for setpoint change: P17.5, I0.563, D54.0
              Computed PID parameters for load change: P17.
              26/4/2020, 15:33:18	M303
              Heater 1 tuning succeeded, use M307 H1 to see result
              26/4/2020, 15:33:14	M303
              26/4/2020, 15:13:32	Auto tune phase 3, peak temperature was 244.8
              26/4/2020, 15:13:27	Auto tune phase 2, heater off
              26/4/2020, 15:11:22	Auto tune phase 1, heater on
              26/4/2020, 15:11:16	M303 H1 S240
              Auto tuning heater 1 using target temperature 240.0°C and PWM 1.00 - do not leave printer unattended
              I am writing at 16:25 and the console report phase 2 after 15 minutes with a heater temp of 32 c°...is it normal?
