Extruder temperature problème
Cable seems to be ok, and thermistor is not loose (it is the cylindrical e3d v6 sensor)
@JuL said in Extruder temperature problème:
I'd hook up an ohm meter at the Duet end and work your way up the cable flexing it at every point to be sure. I'd do the same for the heater wiring. I just caught one this way a couple weeks ago.
I'll try asap.thx
So, I tried hook up ohm meter on thermistor cable (board side) after my extruder reach 200°C, resistance rise linearly and suddenly drop too. I did the same without the cable (thermistor side), exact same result. I think my thermistor is dead. (please, ask if you don't understand my poor english )
I had the same problem last week
The problem was in the e3d connector. I replaced it and the temperature was back to normal. -
I removed the connectors and soldered, exact same problem. I will now wait untill E3D open and send a new one
I received the new thermistor. Everything seem's to be ok now. Thanks to everyone who tried to help me!
How can I mark this post as "solved"? -
https://forum.duet3d.com/topic/7773/forum-feature-mark-as-question-solved
@bearer
