PanelDue Improvement Tips
  • I googled for a while and am pretty sure the stuff i am searching for is not (yet) implemented, correct me if i am wrong.
    My printer is not next to my PC, so i have to use the Panel when working at my printer.
    Issue 1 is the temperature control.
    Goal Temperature is at 0°C.
    I Want to extrude at 240.
    I press the +5 Button 48 times... This feels so wrong.
    Easily implementable would be additional +50° Buttons.
    The most elegant but hard to implement suggestion would be a slider but Buttons are more than enough.
    Issue 2 for me is the limitation of 4 Macros.
    Essential Macros i always need at the printer are
    1. Preheating
    2. Disable Steppers
    3. Retract Filament completely (Filament change)
    4. Finish Filament change (Filament change)
    5. Clean Nozzle
    And even more that would be nice to have.
    But those are essential and PanelDue at its current state can only display 4.
    A scrolling feature would be great.
  • @Tryptamine said in PanelDue Improvement Tips:
    Press and hold
  • Moderator
    Adding a +50 button could be nice I suppose. Though I don't think I've ever noticed how long it takes to set the temp. Press and hold goes pretty fast to get close and then a couple taps to get it where I want it.
    The PanelDue is pretty limited with what it can do unfortunately.
    There are more versatile options though if you really want to get more control at your fingertips.
    https://forum.duet3d.com/category/33/dueui
  • You'll be pleased to know that most of those items have already been implemented but possibly not in ways you would initially look for it, such as holding the button to quickly increase temps as mentioned by Danal. With 4.3" screen you are correct in that you can only have 4. If I am not mistaken the larger screens hold more but I cannot confirm.
    Because you can make them as large as you want, consider combining them, such as #5 cleaning the nozzle after #3 retract the filament or a pause then run #4 to finish the filament change all in one shot. Whatever you like....
    All essential macros of you have listed can be placed on the main screen as well as when your on the "control" menu, press the "macro" button and it takes you to a full page of macros you may also have set up.
    Check wiki for info on macros. I had 2 good links but I cannot yet post links because I read more than I post...
    You did notice the "Macros" button where you can access all other macros?
    I recently found out you name the macro files 00_something.g 01_something.g ... and panel will remove ##_ part but order them by the numbers.
    1. Preheating
    2. Disable Steppers
    5. Clean Nozzle
    I have on main screen for e.g.
    • preheat bed
    • go back
    • disable move restrictions
    • disable steppers
    everything else, click on "macros" and access from there ... single additional click is not a big deal ... would be cool to have them more on the main screen but not crucial...
  • Moderator
    I think there was actually someone that built a version that split the 4 macro slots into two for 8 buttons, but I can't seem to find it right now.
  • While we are discussing possible changes to PanelDue, a CNC mode specific version would be amazing! Just built an MPCNC and well, let’s just say it’s not the most efficient interface for CNC.
    If anyone knows of a CNC build for PanelDue that I haven’t found or other CNC specific interface please let me know.
  • My #1 feature request is an option to sort the gcode filenames by date. 99% of the time I want to print the file I just uploaded.
    Scrolling thru all the files, while trying to remember what I just uploaded is pretty annoying. I end up with a lot of gcode files that look like aaaaaaSomeobject.gcode with the aaaaaaa to get it to sort at least to the first page. Obviously this isn’t a very good workaround.
  • @wesc said in PanelDue Improvement Tips:
    Same here. I care mostly about the recent files.
    Having a Repeat Last Print button would be nice.
    As for the Home X, Y, Z, buttons, I never use them, just the HomeAll button.
    Can also save real estate by eliminating the time left line (we don't need 3 different estimation) and having a single one, e.g. below the Baby Step button.
    I think that the thing that Panel Due needs the most is a simple firmware upgrade process that is sone automatically when installing a new RRF firmware. That way it will be improved and flourish.
  • while waiting for what could be a long time, maybe introducing a prefix with date YYYYMMDD in the filename can help (depending on which way the default sort goes it may make it better or worse, and at least s3d should be able to do it automatically methinks)
  • @bearer said in PanelDue Improvement Tips:
    That's an interesting idea. Prusa slicer seems to have a [timestamp] macro so may also work. https://github.com/prusa3d/PrusaSlicer/issues/615
    Does PanelDue sort files in descending order? (my printer is currently printing and PanelDue doesn't let me look at the file list).
  • @zapta said in PanelDue Improvement Tips:
    descending order?
    seems to be the wrong way around unfortunately.
    Agree with everything here.
    • home buttons, I find separate X/Y/Z/ALL very useful, removing them would be a big nono
    • sort by date, this would be super but would require bit more changes than I expected. PanelDue uses M20 S2 P.. or M408 S20 P... to fetch list of files and there is no datetime info in this list. You need to do then M36 for each file in order to fetch file details where datetime is. So in order to "sort by date" if you have a lot of files, that would last rather long time (for 1000 files instead of sending one g-code and parse response you need to send 1001 codes ) .. so probbly easiest way would be to implement M20.1 that sends response that include timestamp for each file in the json so it's easier to sort on the client. Other problem is that with a lot of files this takes a lot of ram so probbly either implement some paging inside M20.1 or.. as with lot of files this can easily crash the system on duet2 😞 duet3 has lot more RAM so it's safer but with SBC on duet3 question is if you want to have paneldue at all or just attach a hdmi touch screen on the SBC. Maybe there's easier way, I didn't see how DWC fetches the list with all the details, does it fetch file by file or uses some other way.... TBH it is easier to make slicer name file with YYMMDDHHmm prefix
    as for the "useful features" go, I'd really like to have a screen with movement buttons arranged like in octoprint, or pronterface, or something in between
    as the way they are now I crashed my head so many times
    having a separate button to select "how much" and then huge buttons to click on "move this axis" waaaaaaaaaaaaaaaay better than bunch of tiny buttons
    I thought that some preliminary work was done in RRF (or was it on the duet board?) to allow RRF to update the paneldue firmware. I remember reading something about that a long time ago. Yet another desirable and promised feature that never got developed. 😞
    And now, with the push to use a SBC (raspberry pi) with a duet3 board, I'm not sure that the feature would ever happen. Sadly, I get the impression that I'm one of a very small group that prefers the paneldue to a full web interface for simple control at the printer. As well, its much easier to wire a paneldue (4 tiny wires) when compared to a HDMI display (which requires a thick HDMI cable and a power cable.)
    As for some of the requests... I think a lot of people aren't taking into account the extremely limited screen space (and resolution), the slow bandwidth of the paneldue connection (57k bps), and the slow drawing speed of the display. Adding buttons isn't easy when there's no place to add them. As well, it's extremely hard to make one interface that makes everyone happy. Some want home x/y/z. Others don't want them (or in the case of a delta printer, they don't even make sense.)
    My honest opinion is that the paneldue firmware is actually pretty good for what it is (and the very limited storage space available on the paneldue board.)
    Could it be better? Perhaps, but I don't know how it would be done that would keep everyone happy.
    As for repeating the last print... I think it would be doable with RRF3.01 using a macro. Something like this might work (inside a macro)
    echo "Repeating print of " ^ job.lastFileName
    ; select the file to be printed as the filename of the last job
    M23 job.lastFileName
    ; start printing the selected file
    M24
    This isn't perfect, because it doesn't check the status of the printer before starting a new print. My first thought was to check if "state.status = "idle"", but that doesn't work because state.status returns "busy" while running a macro. I'm sure there's a way to do it, I just don't know off the top of my head.
  • @garyd9 said in PanelDue Improvement Tips:
    The OP (and myself) or on RRF2 but if there is a solution for RRF3 that's something. Upgrading to RRF3 is on my todo list but read somewhere that it will be easier or safer to do it in a month or so.
    I'm running RRF3 on the duet2ethernet (standard 3 axes cartesian, precision piezo sensor, single extruder, few fans) since 3.0 was out and it is printing on average 26-27 hours a day (2 printers) and hasn't had a single issue. Most of the bugs are related to duet3 boards with SBC and extensions. This core "single duet2eth" part, from what I can say, works flawlessly.
  • @zapta i wouldn't say easier in any way or form; but safer with respect to more widely tested as features (probably?) won't be added to 3.1.x - yes.
    I think i read it was planned or something to that effect as well, but i also suspect it got pushed down on the list, even more so as new versions will be few and far between.
    the touch display from the Raspberry people is quite nice, single 15 way flat flex for display and touch, but does need usb power or two adittional 0.1" jumpers from the Pi. but at least there doesn't have to be any bulky connectors that portrude.
  • This post is deleted!
