    Need help installing ustreamer
    135
    10.8k
    • luckyflyerundefined
      luckyflyer
      @gtj0 ,
      I have both files entered and saved, rebooted but am unable to log onto http://0.0.0.0:8080 or my printers address http://192.168.0.181:8080. I've double checked that everything is correct, I removed "--encoder=HW and -m JPEG" from /etc/systemd/system/ustreamer@.service: since they don't apply to my camera. But have tried it with and without those two items.
      It starts up ok if I use the start script.
        luckyflyer
        This happens when I try to start the service manually,
        pi@duet3:~ $ sudo systemctl start ustreamer@.service
        Failed to start ustreamer@.service: Unit name ustreamer@.service is missing the instance name.
        • A Former User?
          A Former User
          @luckyflyer said in Need help installing ustreamer:
          this seems to be a so called template service, so it needs the name in the invocation; sudo systemctl start ustreamer@video0.service
          which probably means Description=UStreamer for video0 should be changed to Description=UStreamer for %I but doesn't affect the issue at hand I believe.
          • gtj0undefined
            gtj0
            @luckyflyer Yeah sorry about that. I should have given more compete instructions. @bearer is correct about being a template service and has the correct command line to manually start and stop the service.
            I don't see (or don't remember) whether the camera you're using is a USB cam or a MIPI cam directly attached to the Pi's camera connector. If it's a USB camera, then here are updated service and rules files that will automatically stop the service when the device disconnects..
            /etc/udev/rules.d/80-ustreamer.rules:
            ACTION=="add", KERNEL=="video0", SUBSYSTEM=="video4linux", TAG+="systemd", ENV{SYSTEMD_WANTS}+="ustreamer@%k.service"
            ACTION=="remove", KERNEL=="video0", SUBSYSTEM=="video4linux", RUN+="/bin/systemctl --no-block stop ustreamer@%k.service"
            [Unit]
            [Service]
            Type=simple
            ExecStart=/usr/local/bin/ustreamer --exit-on-parent-death -r 640x480 --static /tmp/ -d /dev/%i --host=0.0.0.0 --port=8080
            [Install]
            WantedBy=multi-user.target
            As a reminder... "0.0.0.0" is a special IP address that tells server software to listen for connections on all ip addresses on the system. It can never be used to actually connect to anything.
              luckyflyer
              @gtj0,
              Yes usb cam, I will try this in about an hour. Thanks to you and @bearer .
              • A Former User?
                A Former User @gtj0
                @gtj0 thanks for sharing this, gonna have to try with with my auto--bossac-recovery plan.
                re: 0.0.0.0 that had me questioning a few things (in the sense OP said he could connect to it)
                  luckyflyer
                  What mipi camera do you guys recommend for print monitoring? I've been looking at the arducam v2 https://www.amazon.com/Arducam-Raspberry-Official-Megapixel-Acrylic/dp/B083FNFPF2/ref=sr_1_3?dchild=1&keywords=arducam+v2&qid=1590854384&sr=8-3
                  Or is there something better out there.
                  Dougal1957undefined 1 Reply Last reply Reply Quote 0
                  • Dougal1957undefined
                    Dougal1957 @luckyflyer
                    Have you seen this one High Res PI Camera with interchangeable lens
                    luckyflyerundefined 1 Reply Last reply Reply Quote 0
                      luckyflyer @Dougal1957
                      @Dougal1957
                      Nice looking cam , I would like to buy from a US vendor if possible, is it available here anywhere?
                      gtj0undefined Dougal1957undefined 2 Replies Last reply Reply Quote 0
                      • gtj0undefined
                        gtj0
                        The downside of RPi cameras is the distance limit and the flat ribbon cable. You get a lot more choices if you use a USB camera.
                        I use this one
                        https://www.amazon.com/gp/product/B07HVT2XZL/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
                        because it has LED illumination, is easy to mount, move, and use for other things if needed.
                        • gtj0undefined
                          gtj0 @luckyflyer
                          @luckyflyer You can get RPi cameras with interchangeable lenses on Amazon. Here's one...
                          https://www.amazon.com/Arducam-Camera-Raspberry-Interchangeable-LS-2717CS/dp/B012ETE75I/
                            @Dougal1957
                            I would have thought it would be as it is an official Raspberry device https://www.raspberrypi.org/products/raspberry-pi-high-quality-camera/
                            and 2 meter long cables are available for cheap as well https://shop.pimoroni.com/products/raspberry-pi-camera-cable?variant=10312200583 don't know what effect they would have mind
                              luckyflyer
                              @gtj0 But don't the mipi cams offer greater programmability and flexibility than usb cams?
                              A picture of the back of my printer, a 30 cm cable would be perfect, up to the top and out.!P1030087.JPG
                                @luckyflyer I don't really know as I don't have one yet but am considering one with possible a wide angle lens on it not a cheap combination mind
                                • mdevaevundefined
                                  mdevaev
                                  Sup. The ustreamer developer here. I am glad that you use my software, but just in case I want to warn those who want to use RPi CSI cameras: it doesn't work with ustreamer. The reason is that these cameras use their own specific non-v4l2 driver. It is possible to configure them as v4l2, but this requires research and I have not yet addressed this issue. So if you don't want any problems, use regular USB cameras.
                                  Quick answers to old questions:
                                  • 0.0.0.0 is a special address that means "listen all ipv4 interfaces". If you choose this option, you can connect to the streamer via the ip address of your network card or localhost (127.0.0.1).
                                  • You can't listen to port 80 unless you are root or have the CAP_NET_BIND_SERVICE capability (blah-blah-blah the network magic). If you want to run ustreamer via systemd on port 80 under non-root user, you need to add a parameter AmbientCapabilities=CAP_NET_BIND_SERVICE to the Service section
                                  • Use the HW encoder: almost all cameras support it.
                                  • If you're afraid that someone will see your video, use password authorization. It's better than nothing.
                                  PS: I was just passing by, so if you need any help, go to discord, the link is in the ustreamer repository on github.
                                    Dougal1957 @mdevaev
                                    @mdevaev Thank you very much for that info just saved me a ton of cash
                                      luckyflyer
                                      Wow, good to know.
                                        luckyflyer
                                        Still having trouble getting ustreamer to auto start as a service. I have entered @gtj0 revised entries which are,
                                        sudoedit /etc/udev/rules.d/80-ustreamer.rules:
                                        sudoedit /etc/systemd/system/ustreamer@.service:
                                        [Unit]
                                        [Service]
                                        Type=simple
                                        [Install]
                                        Then rebooted, but no image on pc which is http://192.168.0.181:8080 or on Duet pi
                                        http://0.0.0.0:8080
                                        I then tried to manually start the service with,
                                        and get,
                                        pi@duet3:~ $ sudo systemctl start ustreamer@video0.service
                                        Failed to start ustreamer@video0.service: Unit ustreamer@video0.service not found.
                                        pi@duet3:~ $
                                        @bearer mentioned this,
                                        *) edit: this assumes the default EDITOR environment variable is set to nano, but if you've changed it you probably know how to use the editor:)
                                        I wondered about this but Raspbian buster comes with nano as the default editor and since I haven't changed editors this shouldn't be an issue.
                                        • A Former User?
                                          A Former User @luckyflyer
                                          only relevant when using sudoedit (probably other times as well, but in this context, only for sudoedit) and the instructions for getting out of nano wouldn't work for other editors - but then again, if someone have changed the default I'd wager they know how to use it.
                                            luckyflyer
                                            Hmm, that is what I'm using,
                                            should I use something else?
