Need help installing ustreamer
@luckyflyer said in Need help installing ustreamer:
Hmm, that is what I'm using, should I use something else?
oh dear; that is the one question you do not ask the internett and live to talk about..
jokes aside, no and yes. occasional editing of small files on debian and derivatives nano is fine. but nano isn't always available when you wander outside the comfort zone, and there are fanatics who will tell you that you won't get into (insert happy after life place) if you use anything but their favourite editor etc.
Lol can I buy you a plane ticket to the desert southwest, my guess is you you would have this sorted in about 2 minutes.
So
sudoedit /etc/udev/rules.d/80-ustreamer.rules:
sudoedit /etc/systemd/system/ustreamer@.service:
should work ok for me? -
not so sure about the 2 minutes, systemd isn't my forte.
nor am I 100% sure about the usecase and proposed solution is the best match.
but yeah, the command to edit the files as root is fine, it does the same as sudo nano /etc/.... just without loopholes and it respects the EDITOR env variable for those who have customized their profile.
are you looking for a solution that will autostart when the camera is connected, or a solution that will autostart when the pi starts (with the camera always connected)?
my day is coming to an end, but i think the last bit there might clear up some misconceptions?
I normally will keep the camera always connected so the autostart with camera connected would work for me. But either would work ok.
(the template thing might do both, idk, if I fidn a camera tomorrow i'll play with it a little in the evening)
Sounds good thanks.
I notice that line 2 uses a upper case I and line 5 uses a lower case i Don't know if this is anything or not, thought I would mention it.
[Unit] Description=UStreamer for %I [Service] Type=simple ExecStart=/usr/local/bin/ustreamer --exit-on-parent-death -r 640x480 --static /tmp/ -d /dev/%i --host=0.0.0.0 --port=8080 [Install] WantedBy=multi-user.target
thats intentional. %I gets escaped so it doesn't contain special characters, which is needed for the name (and i suspect gtj0 would have corrected it if I was mistaken:)
@bearer said in Need help installing ustre sure the camera is plugged in.
eamer:thats intentional. %I gets escaped so it doesn't contain special characters, which is needed for the name (and i suspect gtj0 would have corrected it if I was mistaken:)
Correct. It's just in the description anyway.
@luckyflyer start simple...
### Move the rules file out of the way $ sudo mv /etc/udev/rules.d/80-ustreamer.rules /root/ ### Reload systemd $ sudo systemctl daemon-reload ### Enable ustreamer@video0 to start on boot. $ sudo systemctl enable ustreamer@video0 Created symlink /etc/systemd/system/multi-user.target.wants/ustreamer@video0.service → /etc/systemd/system/ustreamer@.service. ### Make sure the camera is plugged in. ### Reboot. $ sudo systemctl reboot ### When the Pi is back up, check the status of the service... $ sudo systemctl status ustreamer@video0
@gtj0 Thanks for your help and sorry to be such a pain.
I enter each command and this is what I get.pi@duet3:~ $ sudo mv /etc/udev/rules.d/80-ustreamer.rules /root/ pi@duet3:~ $ sudo systemctl daemon-reload pi@duet3:~ $ sudo systemctl enable ustreamer@video0 Failed to enable unit: Unit file ustreamer@video0.service does not exist.
I have followed the previous steps exactly and several times using copy and paste. I'm using nano3.2 and do ctrl X Yes then enter to save and then reboot. I do this for both of the files. I'm at a loss to for why the service does not exist.
One thing I've noticed is when I go back into the editor the text that I previously entered
ACTION=="add", KERNEL=="video0", SUBSYSTEM=="video4linux", TAG+="systemd", ENV{SYSTEMD_WANTS}+="ustreamer@%k.service" ACTION=="remove", KERNEL=="video0", SUBSYSTEM=="video4linux", RUN+="/bin/systemctl --no-block stop ustreamer@%k.service"
and
are still there, is this normal? I have the feeling that the files are not being saved. I'm wondering if I don't have permissions set correctly but get no error stating that I don't. Doing research to understand about permissions.
@luckyflyer Are you sure the
ustreamer@.service
file is located in/etc/systemd/system
and that it's named exactly that?Try
ls -al /etc/systemd/system
thencat /etc/systemd/system/ustreamer@.service
@gtj0
ls -al /etc/systemd/systempi@duet3:~/ustreamer $ ls -al /etc/systemd/system total 76 drwxr-xr-x 17 root root 4096 May 29 22:30 . drwxr-xr-x 5 root root 4096 May 19 06:26 .. -rw-r--r-- 1 root root 1551 Apr 7 06:06 autologin@.service drwxr-xr-x 2 root root 4096 May 19 07:56 basic.target.wants drwxr-xr-x 2 root root 4096 May 19 06:36 bluetooth.target.wants lrwxrwxrwx 1 root root 42 May 19 06:38 dbus-fi.w1.wpa_supplicant1.service -> /lib/systemd/system/wpa_supplicant.service lrwxrwxrwx 1 root root 37 May 19 06:36 dbus-org.bluez.service -> /lib/systemd/system/bluetooth.service lrwxrwxrwx 1 root root 40 May 19 06:37 dbus-org.freedesktop.Avahi.service -> /lib/systemd/system/avahi-daemon.service lrwxrwxrwx 1 root root 45 May 19 06:26 dbus-org.freedesktop.timesync1.service -> /lib/systemd/system/systemd-timesyncd.service lrwxrwxrwx 1 root root 34 May 19 06:38 dhcpcd5.service -> /lib/systemd/system/dhcpcd.service lrwxrwxrwx 1 root root 35 May 19 07:58 display-manager.service -> /lib/systemd/system/lightdm.service drwxr-xr-x 2 root root 4096 May 19 06:26 getty.target.wants drwxr-xr-x 2 root root 4096 May 19 06:31 getty@tty1.service.d drwxr-xr-x 2 root root 4096 May 19 07:58 graphical.target.wants drwxr-xr-x 2 root root 4096 May 19 06:35 halt.target.wants drwxr-xr-x 2 root root 4096 May 25 20:04 multi-user.target.wants drwxr-xr-x 2 root root 4096 May 19 06:28 network-online.target.wants drwxr-xr-x 2 root root 4096 May 19 06:35 poweroff.target.wants drwxr-xr-x 2 root root 4096 May 19 06:38 rc-local.service.d drwxr-xr-x 2 root root 4096 May 19 06:35 reboot.target.wants drwxr-xr-x 2 root root 4096 May 19 06:36 remote-fs.target.wants drwxr-xr-x 2 root root 4096 May 19 08:03 sockets.target.wants lrwxrwxrwx 1 root root 31 May 19 06:36 sshd.service -> /lib/systemd/system/ssh.service drwxr-xr-x 2 root root 4096 May 19 06:36 sysinit.target.wants lrwxrwxrwx 1 root root 35 May 19 06:28 syslog.service -> /lib/systemd/system/rsyslog.service drwxr-xr-x 2 root root 4096 May 19 06:29 timers.target.wants -rw-r--r-- 1 root root 217 May 30 12:24 ustreamer@.service: pi@duet3:~/ustreamer $
pi@duet3:~ $ cat /etc/systemd/system/ustreamer@.service cat: /etc/systemd/system/ustreamer@.service: No such file or directory
Looks like the first one is there, but not the second.
I think it's something with my editor but don't know how to check to see. -
@luckyflyer maybe try making it executable?
sudo chmod +x /etc/systemd/system/ustreamer@.service
(long shot)
tried it,
pi@duet3:~ $ sudo chmod +x /etc/systemd/system/ustreamer@.service chmod: cannot access '/etc/systemd/system/ustreamer@.service': No such file or directory
@gtj0 @bearer
Been reading up on the cat command, was wondering if that would be a good way to create and save the missing file? -
hmm, does the filename have a
at the end?sudo mv /etc/systemd/system/ustreamer@.service: /etc/systemd/system/ustreamer@.service sudo chmod +x /etc/systemd/system/ustreamer@.service
@gtj0 said,
@luckyflyer Are you sure the ustreamer@.service file is located in /etc/systemd/system and that it's named exactly that?
I noticed that inls -al /etc/systemd/system
that in line 29 it is
ustreamer@.service:
With a colon, instead of
ustreamer@.service
Is this a problem?
They say great minds think alike................ maybe, I don't know lol.
well, you can use cat and heredoc to create files like so
cat << EOF > /tmp/yourfilehere These contents will be written to the file. This line is indented. EOF
but redirects and sudo gets messy so you'd need something like
cat << EOF | sudo tee /tmp/yourfilehere These contents will be written to the file. This line is indented. EOF
but you'll have to deal with escaping on the command line etc. i to use it from time to time, but its not always the best option.
How would I get rid of the :
