Duet3D Mainboard+Daughter board+PT100
Hi, I'm trying to set up my hotend and heated bed, I can't get the temperature sensors to work, they reading 2000c, I'm using a daughterboard, Please some help
M305 P1 X200
M308 S3 P"3.spi.cs1" Y" rtd-max31865" ; configure sensor 0 as thermocouple via CS pin spi.cs0
M950 H0 C"out1" T0 ; create nozzle heater output on out1 and map it to sensor 0
M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
M950 H1 C"out0" T1 ; create bed heater output on out0 and map it to sensor 1
M307 H1 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
M140 H1 ; map heated bed to heater 1 -
Which version of the firmware are you using?
And which Duet are you using?
M308 S1 P"0.spi.cs1" Y"rtd-max31865" would be correct if its connected to the main board and its a duet 3.
It also depends on which channel you are using on the daughter board. The other channel on the daughter board is cs0. -
I'm using a duet3d mainboard 6HC -
@jay_s_uk on the daughterboard I'm using the rtd1, by the way, I'm using the temp_0 for the sensor
@Reaperrhs said in Duet3D Mainboard+Daughter board+PT100:
is the space between " and rtd-... correct? (I know, this is like in the documentation in https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors )
@JoergS5
thanks for helping, i have one question because I'm learning as I go, for the M308 you replace the existing command or create a new one? -
@Reaperrhs I am unsure whether this is the reason, but if it is, I would replace the line without the space. I could not find the Y parameter in the source code, so I don't know whether it's only a label. But you could simply try.
unless your daughterboard is on can board 3 (an expansion board), the command won't work with 3. in front of spi.cs1
@jay_s_uk i double-check, there is no space, you can see it in my main post, I copy my configuration, the daughterboard is connected on the mainboard duet3d and my sensor is connected to the rtd1 on the daughterboard
Should look like this
M950 H1 C"out1" T1Working on my duet 3 mainboard
@Carlo can you show me the hole config for heaters? just to compare with mine
Here you go
Ignore the bold as that was a temp test with thermistor
Eveything else is printing really well now on my setup; Configuration file for Duet 3 (firmware version 3)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 25 2020 14:05:35 GMT+0100 (British Summer Time); General preferences
M550 P"Duet 3" ; set printer name
M665 L440.470 R231.924 H419.252 B185.0 X-0.00 Y-0.00 Z0.000 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0.00 Y0.00 Z0.000 A0.00 B0.00 ; put your endstop adjustments here, or let auto calibration find them; Network
M552 P192.168.0.25 S1 ; enable network and set IP address
M553 P255.255.255.0 ; set netmask
M554 P192.168.0.254 ; set gateway
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0.0 S0 ; physical drive 0.0 goes backwards
M569 P0.1 S0 ; physical drive 0.1 goes backwards
M569 P0.2 S0 ; physical drive 0.2 goes backwards
M569 P0.3 S0 ; physical drive 0.3 goes backwards
M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
M350 E16 I0 ; configure microstepping without interpolation
M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
M92 X160.00 Y160.00 Z160.00 E1837.00 ; set steps per mm
M566 X1000.00 Y1000.00 Z1000.00 E40.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E400.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E120.00 ; set accelerations (mm/s^2)
M906 X1700 Y1700 Z1700 E400 I45 ; set motor currents (mA) and motor idle factor in per cent
M84 S45 ; Set idle timeout; Axis Limits
M208 Z-0.5 S1 ; set minimum Z; Endstops
M574 X2 S1 P"io4.in" ; configure active-high endstop for high end on X via pin io4.in
M574 Y2 S1 P"io1.in" ; configure active-high endstop for high end on Y via pin io1.in
M574 Z2 S1 P"io2.in" ; configure active-high endstop for high end on Z via pin io2.in; Z-Probe
M558 P5 R0.6 C"io3.in+io3.out" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
G31 P500 X0 Y0 Z-0.17 ; set Z probe trigger value, offset and trigger height
M557 R170 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
M307 H0 A122.0 C513.7 D0.5 S1.00 V24.0 B0 ; disable bang-bang mode for the bed heater and set PWM limit
;M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
;M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
;M143 H1 S300 ; set temperature limit for heater 1 to 300C
;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M308 S1 P"spi.cs0" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs0
M143 H1 S450 ; set temperature limit for heater 1 to 450C
M307 H1 A512.3 C269.6 D3.6 S1.00 V24.0 B0 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"out9" Q500 ; create fan 0 on pin out9 and set its frequency
M106 P0 S0 H-1 C"Part Cooler" ; set fan 0 value. Thermostatic control is turned off
M950 F1 C"out7" Q250 ; create fan 1 on pin out7 and set its frequency
M950 F2 C"out8" Q500 ; create fan 2 on pin out8 and set its frequency
M106 P2 S0 H-1 C"Berd Air" ; set fan 2 value. Thermostatic control is turned off; Tools
M563 P0 S"E3D Brass 0.4" D0 H1 F0:2 ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
;Retraction settings
M207 S1.75 F2800 T1500 Z0.25; Miscellaneous
M501 ; load saved parameters from non-volatile memory -
@Carlo thanks, let me see what I'm missing (are you using a daughterboard to??)
@Reaperrhs
Yeah I have the PT100 in 0 which is the right hand terminal as you look at it are you 2 wire or 4 wire?
if 2 do you have the jumpers on behind the terminals ? -
@Carlo i have two wires, also the jumpers are in place, the two wires are connected in the right hand of the daughterboard
That's 0 channel, 4 connection block only 2 wire in the 2 center terminals ?
@Carlo yes, center terminals
