    Duet3D Mainboard+Daughter board+PT100
    1.4k
    • Reaperrhsundefined
      Reaperrhs @jay_s_uk
      @jay_s_uk i double-check, there is no space, you can see it in my main post, I copy my configuration, the daughterboard is connected on the mainboard duet3d and my sensor is connected to the rtd1 on the daughterboard
      • Carloundefined
        Carlo
        Should look like this
        M308 S1 P"spi.cs1" Y"rtd-max31865"
        M950 H1 C"out1" T1
        Working on my duet 3 mainboard
        Reaperrhsundefined 1 Reply Last reply Reply Quote 0
          Reaperrhs @Carlo
          @Carlo can you show me the hole config for heaters? just to compare with mine
          Carloundefined 1 Reply Last reply Reply Quote 0
          • Carloundefined
            Carlo @Reaperrhs
            @Reaperrhs
            Here you go
            Ignore the bold as that was a temp test with thermistor
            Eveything else is printing really well now on my setup
            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 25 2020 14:05:35 GMT+0100 (British Summer Time)
            M550 P"Duet 3" ; set printer name
            M665 L440.470 R231.924 H419.252 B185.0 X-0.00 Y-0.00 Z0.000 ; Set delta radius, diagonal rod length, printable radius and homed height
            M666 X0.00 Y0.00 Z0.000 A0.00 B0.00 ; put your endstop adjustments here, or let auto calibration find them
            M552 P192.168.0.25 S1 ; enable network and set IP address
            M553 P255.255.255.0 ; set netmask
            M554 P192.168.0.254 ; set gateway
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0.0 S0 ; physical drive 0.0 goes backwards
            M569 P0.1 S0 ; physical drive 0.1 goes backwards
            M569 P0.2 S0 ; physical drive 0.2 goes backwards
            M569 P0.3 S0 ; physical drive 0.3 goes backwards
            M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
            M350 E16 I0 ; configure microstepping without interpolation
            M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
            M92 X160.00 Y160.00 Z160.00 E1837.00 ; set steps per mm
            M566 X1000.00 Y1000.00 Z1000.00 E40.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X18000.00 Y18000.00 Z18000.00 E400.00 ; set maximum speeds (mm/min)
            M201 X1000.00 Y1000.00 Z1000.00 E120.00 ; set accelerations (mm/s^2)
            M906 X1700 Y1700 Z1700 E400 I45 ; set motor currents (mA) and motor idle factor in per cent
            M84 S45 ; Set idle timeout
            M208 Z-0.5 S1 ; set minimum Z
            M574 X2 S1 P"io4.in" ; configure active-high endstop for high end on X via pin io4.in
            M574 Y2 S1 P"io1.in" ; configure active-high endstop for high end on Y via pin io1.in
            M574 Z2 S1 P"io2.in" ; configure active-high endstop for high end on Z via pin io2.in
            M558 P5 R0.6 C"io3.in+io3.out" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
            G31 P500 X0 Y0 Z-0.17 ; set Z probe trigger value, offset and trigger height
            M557 R170 S20 ; define mesh grid
            M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
            M307 H0 A122.0 C513.7 D0.5 S1.00 V24.0 B0 ; disable bang-bang mode for the bed heater and set PWM limit
            ;M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
            ;M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
            ;M143 H1 S300 ; set temperature limit for heater 1 to 300C
            ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
            M308 S1 P"spi.cs0" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs0
            M143 H1 S450 ; set temperature limit for heater 1 to 450C
            M307 H1 A512.3 C269.6 D3.6 S1.00 V24.0 B0 ; disable bang-bang mode for heater and set PWM limit
            M950 F0 C"out9" Q500 ; create fan 0 on pin out9 and set its frequency
            M106 P0 S0 H-1 C"Part Cooler" ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"out7" Q250 ; create fan 1 on pin out7 and set its frequency
            M950 F2 C"out8" Q500 ; create fan 2 on pin out8 and set its frequency
            M106 P2 S0 H-1 C"Berd Air" ; set fan 2 value. Thermostatic control is turned off
            M563 P0 S"E3D Brass 0.4" D0 H1 F0:2 ; define tool 0
            ; Custom settings
            ;Retraction settings
            M207 S1.75 F2800 T1500 Z0.25
              Reaperrhs @Carlo
              @Carlo thanks, let me see what I'm missing (are you using a daughterboard to??)
              • Carloundefined
                Carlo @Reaperrhs
                @Reaperrhs
                Yeah I have the PT100 in 0 which is the right hand terminal as you look at it are you 2 wire or 4 wire?
                if 2 do you have the jumpers on behind the terminals ?
                  Reaperrhs @Carlo
                  @Carlo i have two wires, also the jumpers are in place, the two wires are connected in the right hand of the daughterboard
                  • Carloundefined
                    Carlo @Reaperrhs
                    @Reaperrhs
                    That's 0 channel, 4 connection block only 2 wire in the 2 center terminals ?
                      Reaperrhs @Carlo
                      @Carlo yes, center terminals
                      Carloundefined 2 Replies Last reply Reply Quote 0
                      • Carloundefined
                        Carlo @Reaperrhs
                        @Reaperrhs
                        • Carloundefined
                          Carlo @Reaperrhs
                          @Reaperrhs
                          There is a space before the Y M308 S1 P"spi.cs0" Y"rtd-max31865"
                            Reaperrhs @Carlo
                            @Carlo no luck so far, i have to double-check everything, also.. can you tell me whats define by the S1? because that's the only thing we have different
                            • Carloundefined
                              Carlo @Reaperrhs
                              @Reaperrhs
                              That's the Sensor number 1 so my bed is Sensor 0 ,hot end single hot end on my setup #1
                                jay_s_uk
                                maybe attach a photo of the daughterboard and wiring as you've installed it?
                                • JoergS5undefined
                                  JoergS5
                                  and the current heater config please
                                    Reaperrhs @jay_s_uk
                                      Reaperrhs @Reaperrhs
                                      @Reaperrhs ; Heaters
                                      M308 S0 P"spi.cs0" Y"rtd-max31865" ; configure sensor 0 as thermocouple via CS pin spi.cs0
                                      M950 H0 C"out1" T0 ; create nozzle heater output on out1 and map it to sensor 1
                                      M143 H0 S450 ; set temperature limit for heater 1 to 450C
                                      M307 H0 A512.3 C269.6 D3.6 S1.00 V24.0 B0 ; disable bang-bang mode for heater and set PWM limit
                                      M950 H1 C"out0" T1 ; create bed heater output on out0 and map it to sensor 1
                                      M307 H1 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
                                      M140 H1
                                        @Reaperrhs the one on the top is for my hotend, is the one with the PT100
                                        • Carloundefined
                                          Carlo @Reaperrhs
                                          @Reaperrhs
                                          Just copy and paste mine in comment your lines out ; line by line so you dont need to delete it
                                            Reaperrhs @Carlo
                                            @Carlo HOTEND Working Thanks!!!
