    Duet3D Mainboard+Daughter board+PT100
    1.4k
      And which Duet are you using?
      Reaperrhsundefined 1 Reply Last reply Reply Quote 0
        jay_s_uk
        M308 S1 P"0.spi.cs1" Y"rtd-max31865" would be correct if its connected to the main board and its a duet 3.
        It also depends on which channel you are using on the daughter board. The other channel on the daughter board is cs0.
        • Reaperrhsundefined
          Reaperrhs @dc42
          I'm using a duet3d mainboard 6HC
            Reaperrhs @jay_s_uk
            @jay_s_uk on the daughterboard I'm using the rtd1, by the way, I'm using the temp_0 for the sensor
            • JoergS5undefined
              JoergS5 @Reaperrhs
              @Reaperrhs said in Duet3D Mainboard+Daughter board+PT100:
              M308 S3 P"3.spi.cs1" Y" rtd-max31865"
              is the space between " and rtd-... correct? (I know, this is like in the documentation in https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors )
                Reaperrhs @JoergS5
                @JoergS5
                thanks for helping, i have one question because I'm learning as I go, for the M308 you replace the existing command or create a new one?
                • JoergS5undefined
                  JoergS5 @Reaperrhs
                  @Reaperrhs I am unsure whether this is the reason, but if it is, I would replace the line without the space. I could not find the Y parameter in the source code, so I don't know whether it's only a label. But you could simply try.
                    jay_s_uk
                    unless your daughterboard is on can board 3 (an expansion board), the command won't work with 3. in front of spi.cs1
                      Reaperrhs @jay_s_uk
                      @jay_s_uk i double-check, there is no space, you can see it in my main post, I copy my configuration, the daughterboard is connected on the mainboard duet3d and my sensor is connected to the rtd1 on the daughterboard
                      • Carloundefined
                        Carlo
                        Should look like this
                        M308 S1 P"spi.cs1" Y"rtd-max31865"
                        M950 H1 C"out1" T1
                        Working on my duet 3 mainboard
                          Reaperrhs @Carlo
                          @Carlo can you show me the hole config for heaters? just to compare with mine
                          Carloundefined 1 Reply Last reply Reply Quote 0
                          • Carloundefined
                            Carlo @Reaperrhs
                            @Reaperrhs
                            Here you go
                            Ignore the bold as that was a temp test with thermistor
                            Eveything else is printing really well now on my setup
                            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 25 2020 14:05:35 GMT+0100 (British Summer Time)
                            M550 P"Duet 3" ; set printer name
                            M665 L440.470 R231.924 H419.252 B185.0 X-0.00 Y-0.00 Z0.000 ; Set delta radius, diagonal rod length, printable radius and homed height
                            M666 X0.00 Y0.00 Z0.000 A0.00 B0.00 ; put your endstop adjustments here, or let auto calibration find them
                            M552 P192.168.0.25 S1 ; enable network and set IP address
                            M553 P255.255.255.0 ; set netmask
                            M554 P192.168.0.254 ; set gateway
                            M586 P0 S1 ; enable HTTP
                            M586 P1 S0 ; disable FTP
                            M586 P2 S0 ; disable Telnet
                            M569 P0.0 S0 ; physical drive 0.0 goes backwards
                            M569 P0.1 S0 ; physical drive 0.1 goes backwards
                            M569 P0.2 S0 ; physical drive 0.2 goes backwards
                            M569 P0.3 S0 ; physical drive 0.3 goes backwards
                            M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
                            M350 E16 I0 ; configure microstepping without interpolation
                            M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
                            M92 X160.00 Y160.00 Z160.00 E1837.00 ; set steps per mm
                            M566 X1000.00 Y1000.00 Z1000.00 E40.00 ; set maximum instantaneous speed changes (mm/min)
                            M203 X18000.00 Y18000.00 Z18000.00 E400.00 ; set maximum speeds (mm/min)
                            M201 X1000.00 Y1000.00 Z1000.00 E120.00 ; set accelerations (mm/s^2)
                            M906 X1700 Y1700 Z1700 E400 I45 ; set motor currents (mA) and motor idle factor in per cent
                            M84 S45 ; Set idle timeout
                            M208 Z-0.5 S1 ; set minimum Z
                            M574 X2 S1 P"io4.in" ; configure active-high endstop for high end on X via pin io4.in
                            M574 Y2 S1 P"io1.in" ; configure active-high endstop for high end on Y via pin io1.in
                            M574 Z2 S1 P"io2.in" ; configure active-high endstop for high end on Z via pin io2.in
                            M558 P5 R0.6 C"io3.in+io3.out" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
                            G31 P500 X0 Y0 Z-0.17 ; set Z probe trigger value, offset and trigger height
                            M557 R170 S20 ; define mesh grid
                            M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
                            M307 H0 A122.0 C513.7 D0.5 S1.00 V24.0 B0 ; disable bang-bang mode for the bed heater and set PWM limit
                            ;M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                            ;M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
                            ;M143 H1 S300 ; set temperature limit for heater 1 to 300C
                            ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                            M308 S1 P"spi.cs0" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs0
                            M143 H1 S450 ; set temperature limit for heater 1 to 450C
                            M307 H1 A512.3 C269.6 D3.6 S1.00 V24.0 B0 ; disable bang-bang mode for heater and set PWM limit
                            M950 F0 C"out9" Q500 ; create fan 0 on pin out9 and set its frequency
                            M106 P0 S0 H-1 C"Part Cooler" ; set fan 0 value. Thermostatic control is turned off
                            M950 F1 C"out7" Q250 ; create fan 1 on pin out7 and set its frequency
                            M950 F2 C"out8" Q500 ; create fan 2 on pin out8 and set its frequency
                            M106 P2 S0 H-1 C"Berd Air" ; set fan 2 value. Thermostatic control is turned off
                            M563 P0 S"E3D Brass 0.4" D0 H1 F0:2 ; define tool 0
                            ; Custom settings
                            ;Retraction settings
                            M207 S1.75 F2800 T1500 Z0.25
                              Reaperrhs @Carlo
                              @Carlo thanks, let me see what I'm missing (are you using a daughterboard to??)
                              • Carloundefined
                                Carlo @Reaperrhs
                                @Reaperrhs
                                Yeah I have the PT100 in 0 which is the right hand terminal as you look at it are you 2 wire or 4 wire?
                                if 2 do you have the jumpers on behind the terminals ?
                                  Reaperrhs @Carlo
                                  @Carlo i have two wires, also the jumpers are in place, the two wires are connected in the right hand of the daughterboard
                                  • Carloundefined
                                    Carlo @Reaperrhs
                                    @Reaperrhs
                                    That's 0 channel, 4 connection block only 2 wire in the 2 center terminals ?
                                      Reaperrhs @Carlo
                                      @Carlo yes, center terminals
                                      Carloundefined 2 Replies Last reply Reply Quote 0
                                      • Carloundefined
                                        Carlo @Reaperrhs
                                        @Reaperrhs
                                        • Carloundefined
                                          Carlo @Reaperrhs
                                          @Reaperrhs
                                          There is a space before the Y M308 S1 P"spi.cs0" Y"rtd-max31865"
                                            Reaperrhs @Carlo
                                            @Carlo no luck so far, i have to double-check everything, also.. can you tell me whats define by the S1? because that's the only thing we have different
