BLtouch on Duet 2 Wifi RRF3
  • New to Duet. I have a Duet 2 Wifi RRF3. I have it on a CR10s Pro. I am having issues with the BLTouch. I can get it to acknowledge it with m401 and m402 but can't get it to probe the bed on z homing.
  • Moderator
    Post your config.g and homing macros. We can't help much without seeing what you have it configured to do. Copy and paste the contents of those files here.
    The fact that it responds to M401 and M402 is a good sign. It could be as simple as needing to change your homeall to use a G30 to probe the bed instead of a G1 H1 Z move to and endstop.
    Have you tested the probe with this? https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
  • I have not tried that but will now.
  • @Phaedrux ; Configuration file for Duet WiFi (firmware version 3)
    ; generated by RepRapFirmware Configuration Tool v3.1.1 on Tue Jun 09 2020 17:05:22 GMT-0700 (Pacific Daylight Time)
    M550 P"CR10sPro" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
    M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
    M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X330 Y320 Z400 S0 ; set axis maxima
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
    M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X-40 Y-10 Z2.5 ; set Z probe trigger value, offset and trigger height
    M557 X40:300 Y15:300 S20 ; define mesh grid
    M307 H0 A200.4 C697.1 D0.3 V24.1 B0
    M307 H1 A835.3 C298.2 D5.5 V24 B0
    M563 P0 S"Hemeres" D0 H1 F0 ; define tool 0
    T0 ; select first tool
    M501
    M575 P1 S1 B57600
  • ; deployprobe.g
    ; called to deploy a physical Z probe
    ; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:25 GMT-0700 (Pacific Daylight Time)
    ;M280 P0 S10 ; deploy BLTouch
    M280 P0 S10 ;deploy BLTouch
    ; homeall.g
    ; called to home all axes
    G91 ; relative positioning
    G1 H1 X-335 Y-325 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 H2 X5 Y5 F6000 ; go back a few mm
    G1 H1 X-335 Y-325 F360 ; move slowly to X and Y axis endstops once more (second pass)
    G1 H1 Z-405 F360 ; move Z down stopping at the endstop
    G90 ; absolute positioning
    G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
    ;G91 ; relative positioning
    ;G1 Z5 F100 ; lift Z relative to current position
    ;G90 ; absolute positioning
    ; homez.g
    ; called to home the Z axis
    G1 X40 Y15 F6000 ; go to first probe point
    G1 H1 Z-405 F1800 ; move Z down until the endstop is triggered
    G30 ; home z by probing the bed
  • Moderator
    @mrenz999 Your config.g, change:
    to
    See https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3
    Your homeall.g is using a Z move to home the bed against an endstop:
    But your homez.g is using G30, as it should. If you use homez.g (or home just the Z axis) does Z home correctly? If so, replace:
    in homeall.g with:
    In both homeall.g and homez.g delete this line:
    because the 'Z position' is set by the Z trigger height in your G31 command in config.g
    Calibrate the Z trigger height in G31 by following this guide: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
  • @droftarts The probe will deploy with the m401 command. But on homing it has not deployed yet.
  • Moderator
    @mrenz999 said in BLtouch on Duet 2 Wifi RRF3:
    How are you homing? Clicking 'HOME ALL'? It won't work for the reasons I've said. It might deploy if you 'HOME Z' only, but with the config.g incorrect, it will either be triggered already, or not trigger as it slams into the bed.
    Rather than testing by pressing home, check the function as described here: https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Commissioning_Testing_RepRapFirmware_Num_3
    Then do the changes I suggested in my previous post.
  • @droftarts Ok I did an individual home x then y then z. It deployed the pin and bounced back up. It was off the bed so I had to let it hit my hand. Then it shifted on the x to the middle of the bed and didn't deploy it just lowered until I turned it off. I did make the changes you suggested.
    Do I need to do something to tell it to drop the pin each time it probes a spot on the bed ?
  • Moderator
    No. It should deploy as needed with G30.
    Please post your config.g and homing files again with your changes.
  • @Phaedrux
    M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds height + speeds
    M501
    M575 P1 S1 B57600
    ; homeall.g
    G1 H2 X150 Y150 F9000 ; go to first bed probe point and home Z
    ;G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
    ; homez.g
    ;G1 X40 Y15 F6000 ; go to first probe point
    ;G30 ; home z by probing the bed
  • Moderator
    ; homeall.g
    Your homeall is incorrect. It should be:
    ; homeall.g
    G1 X5 Y5 F6000 ; go back a few mm
    G1 X150 Y150 F9000 ; go to first bed probe point and home Z
    G30 ; probe the bed
    G1 X0 Y0 ; return to parked position
    Same for the homez, it should be:
    ; homez.g
  • @Phaedrux said in BLtouch on Duet 2 Wifi RRF3:
    ; homez.g
    Thank you so much. That worked. Fixed the microstepping lol. Now to get the z height for first layer porn lol
  • Moderator
    @droftarts said in BLtouch on Duet 2 Wifi RRF3:
    @mrenz999 that's where this comes in. After that you may want to do a mesh compensation heightmap to see how your bed surface looks.
    https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
