Watercooling, heated-chamber, high-temp-ready IDEX
So I have my first try on this thread:
https://forum.duet3d.com/topic/16244/watercooling-heat-chamber-tool-changer-high-temp-3dp-buildBut I'm abandon tool-changer design as I found myself not able to trust the tool-changer to have it run un-attended. And the printed locking mechanism is another concern.
So, instead of spending time and effort to improve reliability of tool-changer, I decide to go back to dual-X Cartesian design.
I just finish the design stage and waiting for 30mm extrusion to arrive during the weekend, then I can start building the 2nd attempt.
Titus
Very cool! Can't wait to see it come together!
Mechanical is most done now...
Y assembly (up side down)
Front view
Electronics and water cooling side cabine
Yes that's Misumi cardboard box as temp panelAnd yes, this has 4 Z motors, as I figure it's easier/cheaper for me to get the same rigidity with 4 Z motors on each corner, than other 2 motors design which all require stiff Z frame for structure support.
I need to find a way to do Z calibration as I don't want to have BLtouch seat in the heat chamber. Maybe I will do a remove-able Z-probe bar to use flat top as reference point, we will see.
Until next time
Titus -
@titusou said in Watercooling, heat-chamber, high-temp 3DP build (2nd attempt):
CAD at its best. (Cardboard Aided Design)
What are you going to use to as guides for the bed frame - rods or linear guides?
Thanks.
@fcwilt said in Watercooling, heat-chamber, high-temp 3DP build (2nd attempt):
I have 2 linear rails on the left side vertical column to structure on X/Y direction holding, where Z is seating on 4 leadscrew motor.
Titus
Titus
Ah.. Yes... I see them now. At first all I saw where the 4 lead screws.
Thanks.
Can you use stall detection for the z probe? But I have a BLTouch in my heated chamber. I run it up to 70C and so far itβs fine.
@baird1fa said in Watercooling, heat-chamber, high-temp 3DP build (2nd attempt):
I dont think stall detection work well with Z leadscrew...
I got all the wiring semi-done now. Need to redo X/U with drag chain to make it cleaner.
Cooling loop is using customized alum distribution block I'd from other projects, Probably oversized but it seems works. Yes it has 3 loops, one reserved for Y motor later. Haven't run the pump yet.
After lots of try&error I managed to get 4 independent Z motor running G32 auto bed calibration with "probe bar". It's working but quite hassle to use as I also need to put 50mm block during the probing.
Basically I use M291 message with input-response to control step flow. Moving XY to Z1 motor location > place probe bar + block > probe > remove probe bar + block > Z2 again > Z3 again > Z4 again. It take quite a while to finish.
I will see if using traditional gauge indicator will make G32 operation easier. Since bed is quite ridge I don't think I need to use G32 frequently.
And then... put BLTouch on X for G29 meshbed, maybe make BLTouch detachable to avoid long-term high-temp chamber exposure.
Until next time
Titus -
Gauge indicator is super fast to use as Z frame leveling probe bar, then just use hand to rotate the Z motor leadscrew to make Z frame level on 4 corners.
And then, the 2 screw detachable BLtouch mount for G29 meshbed leveling.
Achieve 0.020mm mean error, HAHA!!!
Next... start the X/U calibration...
Until next time
Titus -
During calibration testing I figured the temp X/U wiring is really too temp to use even with simple calibration. Solution: get it drag-chained
Until next time
Titus -
Would you be able to share your config set? It may prove helpful for new users trying to setup an IDEX.
@Phaedrux said in Watercooling, heat-chamber, high-temp 3DP build (2nd attempt):
Will do once I get it cleanup a bit, it's quite a mess right now
Titus
Change the subject for better searching
Titus
