'Jumpy' X/Y movement on Maestro
  • Hi all,
    I'm using a Maestro on an old Rigidbot. Been working fine for a while but all of a sudden the movements have stopped being smooth. It is moving in about 1 inch increments, the same on both X & Y so confident its not mechanical.
    Youtube Video here.
    M122 shows timeout out on 3 drivers. A few on driver 3 but 100% on 5 & 6. Is this normal of a symptom of my problem?
    M122
    RepRapFirmware for Duet 2 Maestro version 2.05.1 running on Duet Maestro 1.0
    Board ID: 08DJM-9P6T2-L43S4-7JTD4-3SJ6Q-TBSRQ
    Used output buffers: 3 of 24 (23 max)
    Static ram: 19804
    Dynamic ram: 87372 of which 0 recycled
    Exception stack ram used: 364
    Never used ram: 23532
    Tasks: NETWORK(ready,764) HEAT(blocked,1264) MAIN(running,3896) IDLE(ready,160)
    Owned mutexes:
    Last reset 04:40:26 ago, cause: software
    Last software reset at 2020-06-20 17:08, reason: User, spinning module GCodes, available RAM 23572 bytes (slot 3)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
    Error status: 0
    Free file entries: 8
    SD card 0 detected, interface speed: 15.0MBytes/sec
    SD card longest block write time: 104.6ms, max retries 0
    MCU temperature: min 27.9, current 30.6, max 50.8
    Supply voltage: min 0.0, current 23.9, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: ok, read errors 0, write errors 1, ifcount 32, reads 17625, timeouts 0
    Driver 1: ok, read errors 0, write errors 1, ifcount 34, reads 17623, timeouts 0
    Driver 2: ok, read errors 0, write errors 1, ifcount 34, reads 17625, timeouts 0
    Driver 3: ok, read errors 0, write errors 1, ifcount 22, reads 17602, timeouts 27
    Driver 4: ok, read errors 0, write errors 1, ifcount 34, reads 17625, timeouts 0
    Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 17637
    Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 17637
    Date/time: 2020-06-20 21:49:02
    Slowest loop: 104.81ms; fastest: 0.05ms
    Hiccups: 0, FreeDm: 156, MinFreeDm: 108, MaxWait: 3105021ms
    === DDARing ===
    Scheduled moves: 71370, completed moves: 71359, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Bed heaters = 0, chamberHeaters = -1 -1
    Heater 0 is on, I-accum = 0.0
    Heater 1 is on, I-accum = 0.3
    Segments left: 3
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 2
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    lcd is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 106.31ms; fastest: 0.02ms
    HTTP sessions: 1 of 8
    Interface state 5, link 100Mbps full duplex
    Config.g
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Mar 26 2020 22:56:52 GMT+0000 (Greenwich Mean Time)
    M550 P"Rigidbot"                                   ; set printer name
    M569 P0 S1                                         ; X physical drive 0 goes backwards
    M569 P1 S1                                         ; Y physical drive 1 goes backwards
    M569 P2 S1                                         ; Z physical drive 2 goes backwards
    M569 P3 S0                                         ; E physical drive 3 goes forwards
    M584 X0 Y1 Z2:4 E3                                   ; set drive mapping
    M92 X200.00 Y200.00 Z1600.00 E135.00               ; set steps per mm
    M566 X900.00 Y1100.00 Z10.00 E200.00                ; set maximum instantaneous speed changes (mm/min)
    M203 X9000.00 Y9000.00 Z400.00 E8000.00         ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z100.00 E5000.00             ; set accelerations (mm/s^2)
    M906 X1800 Y1800 Z1500 E1600 I20                   ; set motor currents (mA) and motor idle factor in per cent
    M84 S50                                            ; Set idle timeout
    M671 X-76:302 Y0:0 S8 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
    M208 X250 Y230 Z250 S0                             ; set axis maxima
    M574 X1 Y1 S0                                      ; set active low and disabled endstops
    M574 Z1 S2                                         ; set endstops controlled by probe
    M558 P1 H2 I0 F120 T12000 A10 S0.01
    G31 P500 X53 Y0 Z1                             ; set Z probe trigger value, offset and trigger height
    M557 X65:215 Y30:210 S8.5                           ; define mesh grid
    M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
    M305 P0 T100000 B4138 R2200                        ; set thermistor + ADC parameters for heater 0
    M305 P1 X200                                       ; configure PT100 for heater 1
    M143 H1 S350                                       ; set temperature limit for heater 1 to 350C
    M106 P0 C"Part Fan" S0 I0 F500 H-1 L80 B0.5     ; set fan 0 name, value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 C"Driver Fan" S0 I0 F500 H1 T80 L255
    M106 P2 C"Hotend Fan" S0 I0 F500 H1 T80 L255 ; set fan 2 name, value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 S"Extruder" D0 H1 F0                       ; define tool 0
    ; Custom settings
    M929 P"eventlog.txt" S1										; Enable logging
    M501
    M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
  • Moderator
    @dm86 said in 'Jumpy' X/Y movement on Maestro:
    Z10.00 E200.00
    I would suggest increasing your Z and E jerk speeds. Try Z100 and E2000
  • Will give it a go, config not changed so odd its just started. Will report back...
  • Moderator
    Stutter like that is usually because of low jerk on Z and having mesh compensation active. Low E jerk may also contribute when using pressure advance and could be triggered by the model/gcode as well.
    What slicer are you using? there was a bug in a recent version of Cura that has since been fixed that caused stuttering. Updating Cura to 4.6.1 fixes it.
  • CURA but I am on 4.6.1.
    I think your correct on the mesh. Upping these values has smoothed it out but not corrected it.
    Just checked my latest mesh and it does look like a mountain range for some reason. Can't get my head around the scale of this though, is the deviation on this significant?
    Using differential IR sensor on glass bed.
  • @dm86 you have driver 4 not defined with M569, but use it in M584 for Z. After correction some of the errors may go away.
  • Moderator
    I suggest you clean the bed really well before redoing the heightmap. It will pick up all the glue gunk.
    You can also add a taper off for the compensation.
    https://duet3d.dozuki.com/Wiki/Gcode#Section_M376_Set_bed_compensation_taper
  • @dm86 you could also check whether the M906 setting for x and y motors 1800 is not too high. It should be about 50 to 80 % of the stepper current, please check documentation.
    The M92 setting of 200 for x and y seem strange to me, do you have 400 step per round stepper (0.9 degree) with 16 teeth pulley? Otherwise 200 could be wrong.
  • This post is deleted!
  • Thanks all,
    Will have another go today and report back.
    @JoergS5 said in 'Jumpy' X/Y movement on Maestro:
    Good spot. I don't think it will make a difference but will correct and see. Thanks.
    Your right on the currents. I'm not sure how accurate they are though. They are 2A steppers but if I go lower they start to miss steps. I used a Duet2 Wifi on here before and had them quite a bit lower with no issues.
    M92 is correct, that is what I have. Dimension accuracy is spot on.
  • Thanks all.
    Problem solved. Was combo of dodgy bed mesh caused my loose mounting screw on sensor & low Z jerk.
    Simplified the mesh too as being glass its pretty flat, just often on a tilt.
  • @dm86 your tilt could be due to different stepper positions of the Z steppers, when you power on.
  • Moderator
  • @Phaedrux Thanks. I did but had real trouble getting it to work reliably. However that was using a capacitive sensor and was my main reason for changing to IR.
    My X is usually fairly stable anyway. Its my Y that I have issues taking the tilt out of.
