    Duet 2 Ethernet and SBC
    Beta Firmware
    29
    302
    34.1k
    • smoki3undefined
      smoki3
      30.9.2020, 08:31:36	Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
      This is what I get when trying to start a print. It happens when the first move is requested
      Tried it a few times. Always the same issue
      • wilrikerundefined
        wilriker @smoki3
        @smoki3 Thanks for reporting back the current state. I hope to get back to this sooner than later but I need to rearrange my hardware chaos on my desk. 😂
        Manuel
        My Tool Collection
        • arhiundefined
          arhi
          arrived ... few days over 2 weeks, looks like I'm going to be using this jlcpcbp in future 🙂 I'm satisfied with the results. @oliof one packed for you will be sent tomorrow so you can test, my hand is still in bad shape so not sure I'll be able to solder the headers these days so you might get to test it before me 🙂
          paneldue connector is in the way so is the probe connector, they are high so the normal headers won't work if I do not remove those two connectors... this is bad, but for the test it will be ok as I do not need the paneldue with sbc and I can live without probing for the test 🙂 but next iteration should solve this, for now I'll just use the "Double length" pinheaders so I can test it.
          The board is also covering the piece of the expansion port but since duet+sbc don't work with duex if I understood correctly that;s also not a big deal but I might make a cutout for that too
          • arhiundefined
            arhi
            got the 7yo to help me solder this, one handed soldering is a ^#^#%*)^#@ .. anyhow another issue, the excess pcb I left to not have sbc connector right on the edge (kill me why) is a problem with a heatsink .. not a huge issue but something to be aware ..
            good thing is with these long headers I can easily attach probes to sniff signals if required 🙂
            A Former User? 1 Reply Last reply Reply Quote 1
            • arhiundefined
              arhi
              so far, not working
              RepRapFirmware for Duet 2 + SBC Version 3.2-beta2 dated 2020-10-05b2
              Executing config.g... Error: Networking is not supported on this hardware
              Warning: Sensor numb
              Clearly I need to remove networking stuff from the config but I doubt that's a too big of a deal, dunno if I need to add something for the SBC ?
              Oct 05 20:34:35 raspberrypi systemd[1]: Started Duet Control Server.
              Oct 05 20:34:36 raspberrypi DuetControlServer[782]: Duet Control Server v3.2.0-beta2
              Oct 05 20:34:36 raspberrypi DuetControlServer[782]: Written by Christian Hammacher for Duet3D
              Oct 05 20:34:36 raspberrypi DuetControlServer[782]: Licensed under the terms of the GNU Public License Version 3
              Oct 05 20:34:37 raspberrypi DuetControlServer[782]: [info] Settings loaded
              Oct 05 20:34:37 raspberrypi DuetControlServer[782]: [info] Environment initialized
              Oct 05 20:34:38 raspberrypi DuetControlServer[782]: [fatal] Could not connect to Duet (Board is not available (no header))
              Oct 05 20:34:38 raspberrypi systemd[1]: duetcontrolserver.service: Succeeded.
              Oct 05 20:34:43 raspberrypi systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart.
              Oct 05 20:34:43 raspberrypi systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 7.
              Oct 05 20:34:43 raspberrypi systemd[1]: Stopped Duet Control Server.
              I didn't edit any config, only thing I did is increase SPI buffer to 8k on the pi
              will hook up the scope in a bit
              arhiundefined 1 Reply Last reply Reply Quote 0
              • arhiundefined
                arhi @arhi
                M122 "DSF"
                RepRapFirmware for Duet 2 + SBC version 3.2-beta2 running on Duet 2 1.02 or later + SBC (standalone mode)
                Board ID: 08DJM-9178L-L4MSN-6J9F0-3S46J-KT16P
                Used output buffers: 1 of 24 (10 max)
                Static ram: 23252
                Dynamic ram: 78280 of which 4920 recycled
                Exception stack ram used: 256
                Never used ram: 24364
                Tasks: HEAT(blocked,365) MAIN(running,427) IDLE(ready,19)
                Owned mutexes: USB(MAIN)
                Last reset 00:09:17 ago, cause: software
                Last software reset time unknown, reason: User, GCodes spinning, available RAM 22932, slot 0
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04433000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                Error status: 0x00
                MCU temperature: min 31.3, current 31.7, max 32.2
                Supply voltage: min 1.7, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
                Driver 0: position 0, ok, SG min/max not available
                Driver 1: position 0, ok, SG min/max not available
                Driver 2: position 0, ok, SG min/max not available
                Driver 3: position 0, ok, SG min/max not available
                Driver 4: position 0, ok, SG min/max not available
                Driver 5: position 0
                Driver 6: position 0
                Driver 7: position 0
                Driver 8: position 0
                Driver 9: position 0
                Driver 10: position 0
                Driver 11: position 0
                Cache data hit count 946232882
                Slowest loop: 5.29ms; fastest: 0.11ms
                === Storage ===
                Free file entries: 10
                SD card 0 detected, interface speed: 12.0MBytes/sec
                SD card longest read time 0.8ms, write time 0.0ms, max retries 0
                Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                === MainDDARing ===
                Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                === AuxDDARing ===
                Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
                Segments left: 0
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is ready with "M122 "DSF"" in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                SBC is idle in state(s) 0
                Daemon is idle in state(s) 0
                Aux2 is idle in state(s) 0
                Code queue is empty.
                ok
                • A Former User?
                  A Former User @arhi
                  @arhi said in Duet 2 Ethernet and SBC:
                  try without the sd card or config.g on the card?
                  arhiundefined 1 Reply Last reply Reply Quote 2
                  • arhiundefined
                    arhi @A Former User
                    @bearer said in Duet 2 Ethernet and SBC:
                    that did it 🙂
                    Connection to Linux established!
                    Executing config.g... Done!
                    RepRapFirmware for Duet 2 + SBC is up and running.
                    Oct 05 20:58:02 raspberrypi systemd[1]: Started Duet Control Server.
                    Oct 05 20:58:03 raspberrypi DuetControlServer[698]: Duet Control Server v3.2.0-beta2
                    Oct 05 20:58:03 raspberrypi DuetControlServer[698]: Written by Christian Hammacher for Duet3D
                    Oct 05 20:58:03 raspberrypi DuetControlServer[698]: Licensed under the terms of the GNU Public License Version 3
                    Oct 05 20:58:04 raspberrypi DuetControlServer[698]: [info] Settings loaded
                    Oct 05 20:58:04 raspberrypi DuetControlServer[698]: [info] Environment initialized
                    Oct 05 20:58:04 raspberrypi DuetControlServer[698]: [info] Connection to Duet established
                    Oct 05 20:58:05 raspberrypi DuetControlServer[698]: [info] IPC socket created at /var/run/dsf/dcs.sock
                    Oct 05 20:58:05 raspberrypi DuetControlServer[698]: [info] Starting macro file config.g on channel Trigger
                    Oct 05 20:58:06 raspberrypi DuetControlServer[698]: [error] M550: Machine name must consist of the same letters and digits as configured by the Linux hostname
                    Oct 05 20:58:06 raspberrypi DuetControlServer[698]: [info] Finished macro file config.g
                    where is the "filesystem" now for the duet on the sbc?
                    any script to "test the communication" ?
                    M122 "DSF"
                    RepRapFirmware for Duet 2 + SBC version 3.2-beta2 running on Duet 2 1.02 or later + SBC (SBC mode)
                    Used output buffers: 1 of 24 (11 max)
                    Static ram: 23252
                    Dynamic ram: 99132 of which 20 recycled
                    Exception stack ram used: 292
                    Never used ram: 8376
                    Tasks: Linux(ready,71) HEAT(blocked,370) MAIN(running,399) IDLE(ready,19)
                    Last reset 00:03:10 ago, cause: software
                    Last software reset time unknown, reason: User, GCodes spinning, available RAM 24332, slot 1
                    Error status: 0x00
                    MCU temperature: min 41.4, current 41.9, max 42.2
                    Supply voltage: min 1.6, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
                    Date/time: 2020-10-05 21:00:22
                    Cache data hit count 430062158
                    Slowest loop: 135.58ms; fastest: 0.10ms
                    === Storage ===
                    SD card 0 not detected, interface speed: 30.0MBytes/sec
                    === MainDDARing ===
                    === AuxDDARing ===
                    Segments left: 0
                    === SBC interface ===
                    State: 0, failed transfers: 0
                    Last transfer: 20ms ago
                    RX/TX seq numbers: 4497/4498
                    SPI underruns 0, overruns 0
                    Number of disconnects: 0
                    Buffer RX/TX: 0/0-0
                    ok
                    • A Former User?
                      A Former User
                      /opt/dsf/sd/ and f.ex. /opt/dsf/sd/sys/config.g
                      arhiundefined 1 Reply Last reply Reply Quote 1
                      • arhiundefined
                        arhi @A Former User
                        This post is deleted!
                        • arhiundefined
                          arhi
                          missed the second part of the https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3 page 😄 sorry .. everything works 😄 ... so must boot duet2 without sd card to work with sbc - great
                          • A Former User?
                            A Former User @arhi
                            or remove/rename sys/config.g - sd card in itself isn't a problem, but valid config file is.
                            • arhiundefined
                              arhi @A Former User
                              @bearer yes, but in that case better remove the card completely 🙂
                              is the "simulate job" doing some spi communication here talking between sbc and duet or is executed on the sbc only? I connected everything on my spare duet that's not in any of the printers so simulation is the best I can do (running one 50MB file right now)
                              • A Former User?
                                A Former User @arhi
                                could you get away with using a regular right angle connector and solder it smd style to pads on the top and bottom of the board?
                                • arhiundefined
                                  arhi
                                  started simulation (2%)
                                  M122
                                  Static ram: 23252
                                  Dynamic ram: 100992 of which 40 recycled
                                  Never used ram: 6496
                                  Tasks: Linux(ready,59) HEAT(blocked,135) MAIN(running,435) IDLE(ready,19)
                                  Owned mutexes: HTTP(MAIN)
                                  Last reset 00:04:56 ago, cause: software
                                  Last software reset at 2020-10-05 21:21, reason: User, none spinning, available RAM 6580, slot 1
                                  Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0440f000 BFAR 0xe000ed38 SP 0xffffffff Task Linu
                                  Error status: 0x00
                                  MCU temperature: min 31.9, current 32.1, max 32.5
                                  Driver 0: position -3403, ok, SG min/max not available
                                  Driver 1: position -122, ok, SG min/max not available
                                  Driver 2: position 5600, ok, SG min/max not available
                                  Date/time: 2020-10-05 21:26:52
                                  Cache data hit count 643706022
                                  Slowest loop: 128.72ms; fastest: 0.12ms
                                  === Storage ===
                                  Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 130ms
                                  === MainDDARing ===
                                  Scheduled moves: 35273, completed moves: 35273, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                                  === AuxDDARing ===
                                  Segments left: 0
                                  HTTP* is ready with "M122" in state(s) 0
                                  File* is ready with "G1 X-41.571999 Y-2.496000 E0.125000" in state(s) 0
                                  USB is idle in state(s) 0
                                  === Filament sensors ===
                                  Extruder 0 sensor: no data received
                                  Last transfer: 6ms ago
                                  RX/TX seq numbers: 8893/8895
                                  Buffer RX/TX: 72/552-0
                                  === Duet Control Server ===
                                  File:
                                  Buffered code: G1 X-41.835 Y0.737 E0.0751
                                  Buffered code: G1 X-42.029 Y0.931 E0.0251
                                  Buffered code: G1 X-42.025 Y0.993 E0.0057
                                  Buffered code: G1 X-41.947 Y1.264 E0.0259
                                  Buffered code: G1 X-41.938 Y1.313 E0.0045
                                  Buffered code: G1 X-41.883 Y1.592 F4200
                                  Buffered code: G1 X-41.874 Y1.623
                                  Buffered code: G1 X-41.784 Y1.676
                                  Buffered code: G1 X-41.728 Y1.620
                                  Buffered code: G1 X9.712 Y-0.323 F9000
                                  Buffered code: G1 X9.775 Y-0.386 E0.0082 F4200
                                  Buffered code: G1 X10.561 Y-0.698 E0.0775
                                  Buffered code: G1 X10.830 Y-0.827 E0.0274
                                  Buffered code: G1 X12.013 Y-1.633 E0.1312
                                  Buffered code: G1 X11.223 Y-0.844 E0.1024
                                  Buffered code: G1 X11.562 Y-0.957 E0.0327
                                  Buffered code: G1 X11.968 Y-1.178 E0.0424
                                  Buffered code: G1 X12.814 Y-1.444 E0.0813
                                  Buffered code: G1 X13.857 Y-2.487 E0.1352
                                  Buffered code: G1 X14.666 Y-2.525 E0.0743
                                  Buffered code: G1 X14.851 Y-2.491 E0.0172
                                  Buffered code: G1 X14.101 Y-1.742 E0.0971
                                  Buffered code: G1 X14.761 Y-1.806 E0.0608
                                  ==> 1088 bytes
                                  Code buffer space: 2552
                                  Configured SPI speed: 8000000 Hz
                                  Full transfers per second: 29.92
                                  File /opt/dsf/sd/gcodes/belly-4-repaired.gcode is selected, processing, simulating
                                  50%
                                  M122
                                  Used output buffers: 1 of 24 (20 max)
                                  Static ram: 23252
                                  Tasks: Linux(ready,31) HEAT(blocked,135) MAIN(running,435) IDLE(ready,19)
                                  Last reset 01:05:19 ago, cause: software
                                  Error status: 0x00
                                  MCU temperature: min 31.8, current 32.7, max 33.1
                                  Driver 0: position 1514, ok, SG min/max not available
                                  Driver 1: position -4643, ok, SG min/max not available
                                  Driver 2: position 183680, ok, SG min/max not available
                                  Date/time: 2020-10-05 22:27:15
                                  Slowest loop: 157.10ms; fastest: 0.11ms
                                  === Storage ===
                                  Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 217ms
                                  === MainDDARing ===
                                  Scheduled moves: 813549, completed moves: 813549, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                                  === AuxDDARing ===
                                  Segments left: 0
                                  File* is ready with "G1 X18.978001 Y-58.014999 E0.005600" in state(s) 0
                                  Last transfer: 9ms ago
                                  RX/TX seq numbers: 52153/52155
                                  Buffer RX/TX: 1008/1512-0
                                  File:
                                  Buffered code: G1 X19.514 Y-57.642 E0.0406
                                  Buffered code: G1 X20.322 Y-57.460 E0.0759
                                  Buffered code: G1 X20.667 Y-57.806 E0.0447
                                  Buffered code: G1 X21.102 Y-57.712 E0.0408
                                  Buffered code: G1 X21.441 Y-57.589 E0.0330
                                  Buffered code: G1 X21.008 Y-57.156 E0.0561
                                  Buffered code: G1 X21.162 Y-57.084 E0.0156
                                  Buffered code: G1 X21.778 Y-56.936 E0.0581
                                  Buffered code: G1 X22.168 Y-57.326 E0.0506
                                  Buffered code: G1 X22.516 Y-57.201 E0.0339
                                  Buffered code: G1 X22.527 Y-57.198 E0.0010
                                  Buffered code: G1 X22.875 Y-57.043 E0.0349
                                  Buffered code: G1 X22.570 Y-56.738 E0.0396
                                  Buffered code: G1 X22.922 Y-56.598 E0.0347
                                  Buffered code: G1 X23.303 Y-56.482 E0.0366
                                  Buffered code: G1 X23.569 Y-56.747 E0.0344
                                  Buffered code: G1 X24.290 Y-56.479 E0.0706
                                  Buffered code: G1 X24.049 Y-56.237 E0.0313
                                  ==> 860 bytes
                                  Pending code: G1 X24.257 Y-56.166 E0.0202
                                  Pending code: G1 X24.765 Y-55.963 E0.0501
                                  Pending code: G1 X25.017 Y-56.216 E0.0327
                                  Pending code: G1 X25.163 Y-56.167 E0.0141
                                  Pending code: G1 X25.760 Y-55.969 E0.0577
                                  Pending code: G1 X25.471 Y-55.680 E0.0375
                                  Pending code: G1 X25.906 Y-55.483 E0.0437
                                  Code buffer space: 1868
                                  Full transfers per second: 30.03
                                  during simulation:
                                  • arhiundefined
                                    arhi @A Former User
                                    yes, that would work but I hate those comb soldering + it would require thicker board to properly work, also I don't think I ever seen 90 degree female double header, usually male is 90 degree and we need female here.
                                    Thing is, there's nothing important between connector and edge of the board, I can just move the connector closer to the edge (cut the edge closer to connector) but for now it's not a big deal since I just used another rpi that does not have active cooler on it and the passive heatsinks are more than enough as this will be in a box with duet that will have active cooling anyhow so air movement will happen for sure 🙂 ... also, dunno when plugins will come but for now load is very low so rpi is rather cold
                                    • arhiundefined
                                      arhi
                                      test jig
                                      • arhiundefined
                                        arhi
                                        finished simulation
                                        M122
                                        Static ram: 23252
                                        Last reset 11:58:35 ago, cause: software
                                        Error status: 0x00
                                        MCU temperature: min 31.7, current 32.6, max 33.4
                                        Driver 0: position -936, ok, SG min/max not available
                                        Driver 1: position -3271, ok, SG min/max not available
                                        Driver 2: position 320880, ok, SG min/max not available
                                        Date/time: 2020-10-06 09:20:31
                                        Slowest loop: 353.02ms; fastest: 0.11ms
                                        === Storage ===
                                        Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 244ms
                                        === MainDDARing ===
                                        Scheduled moves: 1563560, completed moves: 1563560, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                                        === AuxDDARing ===
                                        Segments left: 0
                                        File* is idle in state(s) 0
                                        RX/TX seq numbers: 9278/9280
                                        Buffer RX/TX: 0/0-0
                                        File:
                                        Buffered code: M98 P"print_stop.g"
                                        Buffered code: ; Build Summary
                                        Buffered code: ;   Build time: 10 hours 10 minutes
                                        Buffered code: ;   Filament length: 159104.0 mm (159.10 m)
                                        Buffered code: ;   Plastic volume: 382690.08 mm^3 (382.69 cc)
                                        Buffered code: ;   Plastic weight: 478.36 g (1.05 lb)
                                        Buffered code: ;   Material cost: 22.00
                                        ==> 424 bytes
                                        Code buffer space: 4096
                                        Full transfers per second: 32.35
                                        • arhiundefined
                                          arhi
                                          now question is how is simulation related to real stuff wrt sbc/duet communication
                                            dc42 administrators @arhi
                                            The simulation runs on the Duet, so the SBC to Duet traffic is much the same as for a real print, except for fewer status requests/responses because of the shorter duration.
