bltouch
  • hello sorry but I could not completely set the bltouch I have a delta can you take a look at the configuration please? when i send the g29 or the g32 it goes home and goes down without the pin pulled out so i turn off (i also have a problem with the z axis in home i don't know why it stops before the endstop)
    thank you for your assistance
    ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 27 2020 16:50:18 GMT+0200 (heure d’été d’Europe centrale)
    M550 P"Fabio" ; set printer name
    M665 R293 L519.962 B200 H367.3 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
    M551 P"admin" ; set password
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M92 X80.00 Y80.00 Z80.00 E873.08 ; set steps per mm
    M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
    M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 Z0 S1 ; set minimum Z
    M574 X2 Y2 Z2 S1 ; set active high endstops
    M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
    M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
    M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
    G31 P500 X-45.712 Y36.357 Z2.5 ; set Z probe trigger value, offset and trigger height
    M557 R180 S20 ; define mesh grid
    M140 H-1 ; disable heated bed
    M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
    M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P2 S1 I0 F500 H T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
  • I have already created the folders deployprobe.g, retractprobe.g I have also tested the bltouch pin up, down, test works
  • Moderator
    Post your homedelta.g, bed.g as well.
    Do the probe deploys and retracts when you send M401 and M402?
    When you send G30 does the probe deploy?
    https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
  • Thank you
    ; homedelta.g
    ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 27 2020 18:57:16 GMT+0200 (heure d’été d’Europe centrale)
    G91 ; relative positioning
    G1 H1 X405 Y405 Z405 F1800 ; move all towers to the high end stopping at the endstops (first pass)
    G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
    G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
    G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
    G90 ; absolute positioning
    G1 X0 Y0 F6000 ; move X+Y to the centre
    ; bed.g
    ; called to perform automatic delta calibration via G32
    G28 ; home all towers
    ; Probe the bed at 10 peripheral and 6 halfway points, and perform 8-factor auto compensation
    ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
    G30 P0 X0 Y117.2 H0 Z-99999
    G30 P1 X80.93 Y111.38 H0 Z-99999
    G30 P2 X142.66 Y46.35 H0 Z-99999
    G30 P3 X142.66 Y-46.35 H0 Z-99999
    G30 P4 X88.17 Y-121.35 H0 Z-99999
    G30 P5 X0 Y-150 H0 Z-99999
    G30 P6 X-83.34 Y-114.71 H0 Z-99999
    G30 P7 X-113.38 Y-36.84 H0 Z-99999
    G30 P8 X-103.96 Y33.78 H0 Z-99999
    G30 P9 X-63.9 Y87.95 H0 Z-99999
    G30 P10 X0 Y46.69 H0 Z-99999
    G30 P11 X63.74 Y36.8 H0 Z-99999
    G30 P12 X64.95 Y-37.5 H0 Z-99999
    G30 P13 X0 Y-75 H0 Z-99999
    G30 P14 X-43.98 Y-25.39 H0 Z-99999
    G30 P15 X-36.59 Y21.12 H0 Z-99999
    G30 P16 X0 Y0 H0 Z-99999 S8
    ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
    ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
  • m401 m402 g30 everything works
  • Moderator
    @nemecek said in bltouch:
    Are you sure that your steps per mm is 80?
  • Moderator
  • @Phaedrux yes mm is 80 😕
  • Moderator
    Try increasing the distance moved for the initial homing to ensure that it goes far enough to hit the endstops.
    That may solve one problem if you're sure 80 steps per mm is correct and it's moving the correct amount.
  • @Phaedrux yes I read but I don't know where I went wrong you can help me I'm really desperate
  • Moderator
    I'll do my best, unfortunately I'm not a delta guru. All I can really do is suggest to go through those docs carefully and try and understand what's going on. I can try and answer any specific questions.
  • ok
    thank you🙂
  • Moderator
    I'm hoping that if we resolve the initial homing the probing will fall into place. If M401 M402 and G30 work correctly to deploy the pin and cause the head to move towards the bed that means the probe itself is working correctly.
  • @Phaedrux said in bltouch:
    do I write like this? G1 H1 X700 Y700 Z700 F1800
  • Moderator
    That should do it.
    gives me this error
    can I send you a video tomorrow? so you understand me better
  • Moderator
    https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Homing_the_machine
    See this section
  • @Phaedrux good morning i read in your opinion should i delete it? G1 X0 Y0 F6000 ; move X+Y to the centre
  • @Phaedrux ok perfect I solved the problem of the z axis by deleting this G1 X0 Y0 F6000; move X + Y to the center now and only one bltouch problem you can do
  • hi I managed to get it working by changing the P9 to the P5 should be P9
    peche? can you explain it to me?
    M558 P5 H5 F120 T3000
  • Moderator
    Yes the BLTouch should use P9.
    I'm curious now what firmware version you are running. Should be 2.05.1.
    Can you please send M122 and post the results?
  • yes
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
    Board ID: 08DGM-956GU-DJMSN-6J1FL-3SJ6S-T9NVD
    Used output buffers: 3 of 24 (9 max)
    Static ram: 25712
    Dynamic ram: 92604 of which 396 recycled
    Exception stack ram used: 432
    Never used ram: 11928
    Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,348) IDLE(ready,160)
    Owned mutexes:
    Last reset 00:40:29 ago, cause: power up
    Last software reset at 2020-06-28 19:10, reason: User, spinning module GCodes, available RAM 11968 bytes (slot 1)
    Error status: 0
    Free file entries: 10
    SD card longest block write time: 6.1ms, max retries 0
    MCU temperature: min 29.1, current 40.2, max 40.8
    Supply voltage: min 11.9, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: standstill, SG min/max 0/381
    Driver 1: standstill, SG min/max 0/371
    Driver 2: standstill, SG min/max 0/377
    Date/time: 2020-06-28 20:37:50
    Slowest loop: 49.05ms; fastest: 0.07ms
    Hiccups: 0, FreeDm: 160, MinFreeDm: 154, MaxWait: 305348ms
    === DDARing ===
    Scheduled moves: 422, completed moves: 422, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 15.44ms; fastest: 0.00ms
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is running
      WiFi firmware version 1.23
      WiFi MAC address 5c:cf:7f:76:6a:14
      WiFi Vcc 3.34, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 25944
      WiFi IP address 192.168.1.35
      WiFi signal strength -63dBm, reconnections 0, sleep mode modem
  • Moderator
    So what exactly happens when you have it set to P9 and do this test?
    https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Static_test_using_the_web_interface
  • it goes down without extracting the pin😭
