Unsolved bltouch
hi I managed to get it working by changing the P9 to the P5 should be P9
peche? can you explain it to me?M558 P5 H5 F120 T3000
Yes the BLTouch should use P9.
I'm curious now what firmware version you are running. Should be 2.05.1.
Can you please send M122 and post the results? -
yes
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
Board ID: 08DGM-956GU-DJMSN-6J1FL-3SJ6S-T9NVD
Used output buffers: 3 of 24 (9 max)
Static ram: 25712
Dynamic ram: 92604 of which 396 recycled
Exception stack ram used: 432
Never used ram: 11928
Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,348) IDLE(ready,160)
Owned mutexes:
Last reset 00:40:29 ago, cause: power up
Last software reset at 2020-06-28 19:10, reason: User, spinning module GCodes, available RAM 11968 bytes (slot 1)
Error status: 0
Free file entries: 10
SD card longest block write time: 6.1ms, max retries 0
MCU temperature: min 29.1, current 40.2, max 40.8
Supply voltage: min 11.9, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: standstill, SG min/max 0/381
Driver 1: standstill, SG min/max 0/371
Driver 2: standstill, SG min/max 0/377
Date/time: 2020-06-28 20:37:50
Slowest loop: 49.05ms; fastest: 0.07ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 154, MaxWait: 305348ms
=== DDARing ===
Scheduled moves: 422, completed moves: 422, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.44ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.23
WiFi MAC address 5c:cf:7f:76:6a:14
WiFi Vcc 3.34, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 25944
WiFi IP address 192.168.1.35
WiFi signal strength -63dBm, reconnections 0, sleep mode modem
- WiFi -
So what exactly happens when you have it set to P9 and do this test?
it goes down without extracting the pin
total panic
yes weird
what can I do? do I stay in P5?
So does g30 cause it to drop the pin or not?
@Phaedrux yes
So I'm quite confused now. Is the BLtouch working or not?
Does G32 work to run the auto calibration?
@Phaedrux yes on p5 everything works if instead I switch to p9 the g29 and g32 the probe does not come out
Can you go through this section and perhaps create a new beg.g
; bed.g
; called to perform automatic delta calibration via G32
; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jun 28 2020 15:07:30 GMT+0200 (heure d’été d’Europe centrale)
G28 ; home all towers
; Probe the bed at 10 peripheral and 6 halfway points, and perform 8-factor auto compensation
; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
G30 P0 X0 Y69.49 H0 Z-99999
G30 P1 X49.78 Y68.51 H0 Z-99999
G30 P2 X95.11 Y30.9 H0 Z-99999
G30 P3 X95.11 Y-30.9 H0 Z-99999
G30 P4 X58.78 Y-80.9 H0 Z-99999
G30 P5 X0 Y-100 H0 Z-99999
G30 P6 X-51.7 Y-71.16 H0 Z-99999
G30 P7 X-67.44 Y-21.91 H0 Z-99999
G30 P8 X-60.9 Y19.79 H0 Z-99999
G30 P9 X-37.4 Y51.48 H0 Z-99999
G30 P10 X0 Y25.56 H0 Z-99999
G30 P11 X35.2 Y20.32 H0 Z-99999
G30 P12 X43.3 Y-25 H0 Z-99999
G30 P13 X0 Y-50 H0 Z-99999
G30 P14 X-24.1 Y-13.91 H0 Z-99999
G30 P15 X-20.01 Y11.55 H0 Z-99999
G30 P16 X0 Y0 H0 Z-99999 S8
; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed) -
do you think the problem comes from here?
I'm not sure. You cna use this tool to generate a new one: http://escher3d.com/pages/wizards/wizardbed.php
If it all works with P5 then that's not the end of the world. I just don't understand why P9 doesn't work.
I don't have M401 in my bed.g How come? maybe that's why it doesn't work
@nemecek if you set P9 mode, I would set P value of G31 lower:
G31 P500 X-45.712 Y36.357 Z2.5
G31 P25 X-45.712 Y36.357 Z2.5The 500 was an example in the G31 section, but P25 is used in most documentation about BLTouch P9 examples.
@JoergS5
ok and for this reason that did not work in P9? I'll try tomorrow thanks
