    bltouch
    1.9k
    • nemecekundefined
      nemecek @Phaedrux
      @Phaedrux yes I read but I don't know where I went wrong you can help me I'm really desperate
        I'll do my best, unfortunately I'm not a delta guru. All I can really do is suggest to go through those docs carefully and try and understand what's going on. I can try and answer any specific questions.
        • nemecekundefined
          nemecek
          ok
          thank you🙂
            I'm hoping that if we resolve the initial homing the probing will fall into place. If M401 M402 and G30 work correctly to deploy the pin and cause the head to move towards the bed that means the probe itself is working correctly.
            • nemecekundefined
              nemecek @Phaedrux
              @Phaedrux said in bltouch:
              G1 H1 X405 Y405 Z405 F1800
              do I write like this? G1 H1 X700 Y700 Z700 F1800
                That should do it.
                • nemecekundefined
                  nemecek
                  gives me this error
                  can I send you a video tomorrow? so you understand me better
                    @nemecek said in bltouch:
                    G1 X0 Y0 F6000 ; move X+Y to the centre
                    https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Homing_the_machine
                    See this section
                    nemecekundefined 2 Replies Last reply Reply Quote 0
                    • nemecekundefined
                      nemecek @Phaedrux
                      @Phaedrux good morning i read in your opinion should i delete it? G1 X0 Y0 F6000 ; move X+Y to the centre
                      • nemecekundefined
                        nemecek @Phaedrux
                        @Phaedrux ok perfect I solved the problem of the z axis by deleting this G1 X0 Y0 F6000; move X + Y to the center now and only one bltouch problem you can do
                        • nemecekundefined
                          nemecek
                          hi I managed to get it working by changing the P9 to the P5 should be P9
                          peche? can you explain it to me?
                          M558 P5 H5 F120 T3000
                            Yes the BLTouch should use P9.
                            I'm curious now what firmware version you are running. Should be 2.05.1.
                            Can you please send M122 and post the results?
                            • nemecekundefined
                              nemecek
                              yes
                              M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                              Board ID: 08DGM-956GU-DJMSN-6J1FL-3SJ6S-T9NVD
                              Used output buffers: 3 of 24 (9 max)
                              Static ram: 25712
                              Dynamic ram: 92604 of which 396 recycled
                              Exception stack ram used: 432
                              Never used ram: 11928
                              Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,348) IDLE(ready,160)
                              Owned mutexes:
                              Last reset 00:40:29 ago, cause: power up
                              Last software reset at 2020-06-28 19:10, reason: User, spinning module GCodes, available RAM 11968 bytes (slot 1)
                              Error status: 0
                              Free file entries: 10
                              SD card longest block write time: 6.1ms, max retries 0
                              MCU temperature: min 29.1, current 40.2, max 40.8
                              Supply voltage: min 11.9, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
                              Driver 0: standstill, SG min/max 0/381
                              Driver 1: standstill, SG min/max 0/371
                              Driver 2: standstill, SG min/max 0/377
                              Date/time: 2020-06-28 20:37:50
                              Slowest loop: 49.05ms; fastest: 0.07ms
                              Hiccups: 0, FreeDm: 160, MinFreeDm: 154, MaxWait: 305348ms
                              === DDARing ===
                              Scheduled moves: 422, completed moves: 422, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                              Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
                              Segments left: 0
                              Movement lock held by null
                              http is idle in state(s) 0
                              telnet is idle in state(s) 0
                              file is idle in state(s) 0
                              serial is idle in state(s) 0
                              aux is idle in state(s) 0
                              daemon is idle in state(s) 0
                              queue is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 15.44ms; fastest: 0.00ms
                              HTTP sessions: 1 of 8
                              • WiFi -
                                Network state is running
                                WiFi firmware version 1.23
                                WiFi MAC address 5c:cf:7f:76:6a:14
                                WiFi Vcc 3.34, reset reason Turned on by main processor
                                WiFi flash size 4194304, free heap 25944
                                WiFi IP address 192.168.1.35
                                WiFi signal strength -63dBm, reconnections 0, sleep mode modem
                                So what exactly happens when you have it set to P9 and do this test?
                                https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Static_test_using_the_web_interface
                                • nemecekundefined
                                  nemecek
                                  it goes down without extracting the pin😭
                                  • nemecekundefined
                                    nemecek
                                    total panic😬
                                      And yet using M401 and M402 and G30 works?
                                      m401 m402 g30 everything works
                                      • nemecekundefined
                                        nemecek
                                        yes weird
                                        • nemecekundefined
                                          nemecek
                                          what can I do? do I stay in P5?
                                            So does g30 cause it to drop the pin or not?
                                            nemecekundefined 1 Reply Last reply Reply Quote 0
