duet 2 wifi bl touch trouble..plz help?
  • i have a cr 10 with duet wifi 2 and v.3 bl touch. my wiring is correct and i have everything working so far. all macros fies. deploy, retract self test alarm pin up all work fine.but when i do the self test it only does it for about 10 secounds and stops on its own. also the z probe always reads 1000. ive deployed the probe and try running the g30 and it just says z probe already triggered. tried multiple ways and done multiple troubleshoots but nothing is helping. ive been troubleshooting for months and still no luck. please help.
    running duet web control v3.1 and v2.0.5 firmware. for some reason im having a ton of trouble doing a complete update and cant figure that out either but thats another topic/thread.
    ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 30 2020 22:39:17 GMT-0400 (Eastern Daylight Time)
    M550 P"duet cr 10" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0 S0 ; physical drive 0 goes backwards
    M569 P3 S0 ; physical drive 3 goes backwards
    M569 P4 S1 ; physical drive 4 goes forwards
    M584 X0 Y1 Z2 E3:4 ; set drive mapping
    M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
    M92 X80.00 Y80.00 Z400.00 E100.00:440.00 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X36000.00 Y36000.00 Z600.00 E3000.00:3000.00 ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z100.00 E5000.00:5000.00 ; set accelerations (mm/s^2)
    M906 X900 Y900 Z900 E900:900 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X300 Y300 Z400 S0 ; set axis maxima
    M574 X1 Y1 S1 ; set active high endstops
    M574 Z1 S2 ; set endstops controlled by probe
    M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
    M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P25 X10 Y10 Z2 ; set Z probe trigger value, offset and trigger height
    M557 X15:215 Y15:195 S20 ; define mesh grid
    M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
    M143 H0 S105 ; set temperature limit for heater 0 to 105C
    M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
    M305 P2 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 2
    M143 H2 S280 ; set temperature limit for heater 2 to 280C
    M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H1:2 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 S"Hotend 1" D0 H1 F0 ; define tool 0
    M563 P1 S"Hotend 2" D1 H2 F0 ; define tool 1
    G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
    G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
    HOMEING FILES
    ; homeall.g
    ; called to home all axes
    G91 ; relative positioning
    G1 H1 X-305 Y-305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 H2 X5 Y5 F6000 ; go back a few mm
    G1 H1 X-305 Y-305 F360 ; move slowly to X and Y axis endstops once more (second pass)
    G90 ; absolute positioning
    G1 X-25 Y15 F6000 ; go to first bed probe point and home Z
    ;G91 ; relative positioning
    ;G1 Z5 F100 ; lift Z relative to current position
    ;G90 ; absolute positioning
    ; homez.g
    ; called to home the Z axis
    ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 30 2020 22:39:18 GMT-0400 (Eastern Daylight Time)
    G1 X-25 Y15 F6000 ; go to first probe point
  • Please post the content of deployprobe.g and retractprobe.g
  • that all works but. when i deploy it deploys and when i retract it retracts.
    M280 P3 S90 I1; retract BLTouch
    M280 P3 S10 I1 deploy
  • You have to invert probe signal, so add I1 to M558 command
  • Moderator
    @smithj0shua9371 said in duet 2 wifi bl touch trouble..plz help?:
    That's normal now with recent BLtouches.
    @aidar said in duet 2 wifi bl touch trouble..plz help?:
    That shouldn't be the case, but the error would indicate that, so give it a shot, but then I worry that it won't actually trigger.
    You don't need to deploy the probe before the G30, the G30 should take care of that itself when using probe type P9.
    You need to update to 3.0 first before you can go to 3.1.1
    Send M115 to see what firmware is actually currently installed.
    Send M98 P"Config.g" and report back what errors you get.
  • thats what i meant. wont let me update to 3.0 to 3.1.1. but with the bl touch its still saying its already triggered everytime im issuing G30. and every other macro file ive set up works properly. does anyone see something wrong with my config thats not allowing it to work whe i issue G30
  • @aidar you were right. now every aspect of testing works except when i run the g30 it deploys but it does not trigger when the pin is pressed. so when i issue the g30. it deploys and triggers but just starts flashing and doesnt stop moving the motors.
  • This post is deleted!
  • heres my new configuration. please tell me whats missing now that wont allow it to trigger when it hits the bed.
    ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jul 04 2020 13:11:31 GMT-0400 (Eastern Daylight Time)
    M92 X80.00 Y80.00 Z400.00 E440.00:440.00 ; set steps per mm
    M558 P9 H5 F120 T6000 I1 ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X40 Y0 Z2 ; set Z probe trigger value, offset and trigger height
    ; homeall.g
    ; deployprobe.g
    ; called to deploy a physical Z probe
    M280 P3 S10 I1 ; deploy BLTouch
    ; retractprobe.g
    ; called to retract a physical Z probe
    M280 P3 S90 I1 ; retract BLTouch
  • Moderator
    I think there is a wiring problem. The config was correct before without the I1. It was detecting that it was already triggered. By forcing it to invert it now thinks it's not triggered and so goes to probe.
    Double check your white wire going to the probein.
  • @Phaedrux i want to thank you. i cannot even tell you how grateful i am to have finailly figured this out. there was def a bad connection and some bad config files. problem solved, thanks guys
