    Wifi module idle
    2.1k
    • tkdirpundefined
      tkdirp
      So, the problem I had lest time seemed to be a hardware issue so, I got a new duet 2 wifi board again... and now there is a new error. In step 3 of "1.) Getting Connected to your Duet" and now the usual sequence of
      • M552 S0
      • M587 S"your-network-SSID" P"your-network-password”
      • m552 S1
      doesn't work for some odd reason and it mentions a heater despite having no wring done to the board...
      • A Former User?
        A Former User
        You didn't show what happened when you entered the M587 command?
        But try
        M552 S-1
        M552 S0
        m552 S1
        • tkdirpundefined
          tkdirp
          @bearer said in Wifi module idle:
          after putting this the results...
          • A Former User?
            A Former User
            Bad or missing parameter, hmm, are there any special characters in your SSID or Passphrase?
            tkdirpundefined 1 Reply Last reply Reply Quote 0
            • tkdirpundefined
              tkdirp
              I put in...
              • M587 S"U+Net48C4" P"8040P8C0#1”
              • tkdirpundefined
                tkdirp @A Former User
                @bearer
                If I proceed with...
                m552 S1
                this happens
                • A Former User?
                  A Former User
                  It'll keep saying no known networks found until M587 succeeds adding yours. Don't recall if + and # is on the list of characters that needs special treatment so hopefully someome else will chime in on that.
                  • tkdirpundefined
                    tkdirp
                    @bearer
                    okay 🙂
                    • Dougal1957undefined
                      Dougal1957
                      The # is ok (I have that in my PW as well with no special treatment) not sure about the +
                      But it may be worth trying
                      M587 S"U'+'Net48C4" p"8040P8C0#1"
                      Do make sure that you are sending it in the correct case.
                      Doug
                      • A Former User?
                        A Former User
                        screen shouldn't affect case, thats a workaround for pronterface or whats it called that converts all gcode to uppercase, incluing the strings for parameters like wifi credentials.
                        Dougal1957undefined 1 Reply Last reply Reply Quote 0
                          Dougal1957 @A Former User
                          It was more a warning rather than in instruction and not know the ops system I felt it worth pointing out!
                          • tkdirpundefined
                            tkdirp @Dougal1957
                            @Dougal1957
                            I guess M587 S"U'+'Net48C4" p"8040P8C0#1" seems to work because the terminal responded "ok" but when I put "m552 S1" this still happens...
                            • A Former User?
                              A Former User
                              show us M587 with no parameters?
                              • tkdirpundefined
                                @bearer
                                What does it mean to have an M587 with no parameters? I just don't know because I am pretty new to this.
                                  Dougal1957 @tkdirp
                                  @tkdirp said in Wifi module idle:
                                  @bearer
                                  just send M587 on its own with nothing after it then the Duet will tell us what it has set!
                                  • A Former User?
                                    A Former User
                                    just send M587 (with no S"......" P".....")
                                    it should return the stored netwoks in the wifi module.
                                    • tkdirpundefined
                                      @bearer @Dougal1957
                                      SSID: U+Net48C4
                                      PW: 8040P8C0#1
                                      • A Former User?
                                        A Former User
                                        what firmware are you running?
                                        check with M122. The Duet board firmware will be at the top, and the Wifi firmware will be in a a section at the bottom.
                                        • tkdirpundefined
                                          @bearer
                                          seem to be 2.03
                                          • A Former User?
                                            A Former User @tkdirp
                                            2.03
                                            thats just the RepRapFirmware version, as I said when you run M122 it will also print the version of the firmware running om the Wifi module.
