    Wifi module idle
    2.2k
    • tkdirpundefined
      tkdirp @A Former User
      @bearer
      This happens if I send a M122 command...
      • A Former User?
        A Former User
        right, wifi not happy.
        btw could you try running stty -F /dev/tty.usbmodem14101 inlcr in another terminal and see if it sorts the line endings for you? (edit or stty -F /dev/tty.usbmodem14101 -icrnl)
        then lets try the nuke from orbit approach.
        M552 S-1
        M552 S0
        M588 S"*"
        M587 S"U'+Net48C4" p"8040P8C0#1"
        M552 S1
        M552 S-1 resets the wifi module
        M588 S"*" clears the wifi credentials
        edit fixed typo M589 to M588
        tkdirpundefined 2 Replies Last reply Reply Quote 0
        • tkdirpundefined
          @bearer said in Wifi module idle:
          in another terminal
          So, on another computer?
          • A Former User?
            A Former User @tkdirp
            @tkdirp said in Wifi module idle:
            another computer?
            no, same computer just another window with a terminal. (but its not that important, it just makes it easier to read if the end of line characters actually causes a new line - and I'm not sure if it would work on a Mac)
            • tkdirpundefined
              M589 S"*" clears the wifi credentials
              The nuke plan failed... šŸ˜ž
              • A Former User?
                A Former User
                but M122 shows the wifi version now?
                if not lets try
                M552 S-1
                M552 S0
                M588 S"*"
                M122
                edit: fixed typo M589 to M588
                • tkdirpundefined
                  @bearer
                  M122 is still not working
                  • tkdirpundefined
                    M552 S-1
                    M552 S0
                    M589 S"*"
                    M122
                    Worked.
                    • A Former User?
                      A Former User
                      ah, okay, was about to suggest just updating it without finding out which version it is, but thats all up to date then. (1.23 is the latest iirc)
                      if you run M111 P14 S1 it will enable debug output for wifi.
                      then run M587 S... P.... (with your credentials) followed by M552 S1
                      (but I suspect you really need to find another terminal for that to be usefull, or have screen translate LF into CR/LF)
                      ((edit: if you must use screen maybe log to a file and view the file (in another window) with fixed line endings tail -F my.log | sed 's/$/\r/' ))
                      tkdirpundefined 1 Reply Last reply Reply Quote 0
                      • tkdirpundefined
                        M111 P14 S1
                        After that commend, the M587 S"U'+Net48C4" Pā€8040P8C0#1" dos not seem to have any significant effect
                        • A Former User?
                          thats okay, was primarily after the ouput that say WiFi: ../src/Sock <...> found network U+Net48C4.
                          Either the + is a problem or there is some sort of interoperability issue with the router.
                          I would suggest checking the encyption type, or change it to WPA(2)/TKIP, changing the SSID and Passphrase to something without special charters.
                          Or optionally use M589 to set up the duet as an access point.
                          But first, repeat https://forum.duet3d.com/post/164593 as I had made a typo in the command to clear the wifi settings. (However as you did get an OK at some point i doubt it'll make a difference)
                          • A Former User?
                            A Former User
                            forgot the link to M589 to try AP mode
                            https://duet3d.dozuki.com/Wiki/Gcode#Section_M589_Configure_access_point_parameters
                            • tkdirpundefined
                              @bearer
                              Thank you so much
                              • A Former User?
                                A Former User
                                which bit helped? correcting to M558 or are you using the Duet as an access point?
                                • tkdirpundefined
                                  @bearer
                                  I just changed the name of the wifi I guess the "+" in the SSID name was the issue
                                  A Former User? Natuserundefined 2 Replies Last reply Reply Quote 1
                                  • A Former User?
                                    interesting feedback, perhaps something should be tested and added to the documentation.
                                      There is no hard rule for SSID special character support on the router side. Some will let you use pretty much anything, but in general it's probably best to avoid special characters in the SSID.
                                      I'll add a note to the M587 command regarding that.
                                        The WiFi firmware uses an API call provided by Expressiv (the WiFi chip manufacturer) to set the SSID. Unfortunately, the documentation provided by Expressiv is far from complete. It doesn't specify which characters it allows in an SSID. So your guess is as good as mine!
                                        • Natuserundefined
                                          Natuser @tkdirp
                                          @tkdirp How to change it? Sorry, but I'm a beginner and I have similar problem
                                            Phaedrux Moderator @Natuser
                                            @natuser said in Wifi module idle:
                                            This thread is 2 years old. It would be best if you started a new thread with your issue. Give as much detail about your situation as possible. Thanks.
