    Robotic kinematics
    MultiAxis Printing
    22
    389
    48.3k
    • tony73undefined
      tony73 @JoergS5
      @JoergS5
      ok! I try to contact you on the weekend, see you soon!
      JoergS5undefined 1 Reply Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @tony73
        @tony73 thanks for your patience!
        tony73undefined 1 Reply Last reply Reply Quote 0
        • tony73undefined
          tony73 @JoergS5
          @JoergS5
          Hello ! how is the construction of the robot going? did you manage to finish it and test with the firmware?
          • JoergS5undefined
            JoergS5 @tony73
            @tony73 I had other tasks during the week. But I have solutions for my design problems now and proceed at the weekend.
            tony73undefined 2 Replies Last reply Reply Quote 0
            • tony73undefined
              tony73 @JoergS5
              @JoergS5
              ok! I wait to see, I'm glad to know that you have overcome the problems of building the robot!
              • JoergS5undefined
                JoergS5 @tony73
                This post is deleted!
                • tony73undefined
                  tony73 @JoergS5
                  @JoergS5
                  how's the work going? I had read the post you deleted, I am waiting to see your robot, you say that it is very stable I could take it slow and build it if you release the construction schemes and reduction ratios. I have not tried to build anything even if I would like to try to see how the firmware behaves, I prefer to wait for your answers!
                  • JoergS5undefined
                    JoergS5 @tony73
                    @tony73 I did delete the post, because I didn't want to tell you what to do. You should decide yourself. (and as I said, you'll get all the information I have. I learned a lot about manufacturing the last days also)
                    I have new design problems, the arms were too heavy for the steppers. But I have solved it with counterweights, so it's proceeding. The printer is in fact very stiff, I expect good print results. Current status is, I have to redesign actuator 2 (it was in the way of the arm 2 movement ;-( ).
                    • tony73undefined
                      tony73 @JoergS5
                      @JoergS5
                      ok! I try to contact you in a few days!
                      • JoergS5undefined
                        JoergS5 @tony73
                        @tony73 I have a prototype now, not ideal, but working to validate the firmware. (The M114 was not wrong)
                        • tony73undefined
                          tony73 @JoergS5
                          @JoergS5
                          did you make a prototype with 5 actuators plus an extruder for 3d printing?
                          • JoergS5undefined
                            JoergS5 @tony73
                            @tony73 5 actuators yes, extruder not yet*). I have a weakness in specifications: when arm 5 rotates to the left (180 degree eg), arm 3 can be in the way for the hotend+extruder if arm 3 is "flat".
                            *) my robot has a very low payload. I still have to learn a lot about how to optimize gear ratios, counterweight and belt tension, to get a good solution. This is quite different from developing the firmware!
                            • JoergS5undefined
                              JoergS5
                              I have some images of my first pre-Prototype, before I will reconstruct it:
                              • JoergS5undefined
                                JoergS5
                                The first idea was to place Axis 1 behind the construction. This seemed to be a good idea because the axis is fixed at two points top and down and can be calibrated easily. But the disadvantages are, I have no good place to install actuator 2 and the counterweights have not much room also.
                                Arm 2 and 3 are 27 cm and 20 cm long. For production the same length will be better, but I differed them to test firmware.
                                The gears are insufficient. One stepper has a 1:27 gear, but the problem is the little 60 teeth pulley which is not sufficient. I'll produce 200 teeth pulleys as a next test now. The belt tensioning is very important also, because otherwise the belts slip very often.
                                Arms 2 and 3 have 4 arm elements 20x10x2, connected horizontally by 100x20x2. The placement of the connectors are important, they define the possible axis angles.
                                The upper and lower arm construction is 18 cm distance and makes sure the arm 4 is vertical at all times, so axis 5 is vertical also. I will remain this construction, but axis 5 supported at two hinges and with a gear.
                                The actuator 4 on the third image is a dummy to check the firmware code for R0.
                                I will try to avoid counterweights, because they support wavering of the construction.
                                The hinges are constructed by 8 mm aluminium or steel shafts, F688 ball bearings with 16 mm holes and the 8 mm holes for the arms which are fixed to the shafts. Distances will be implemented by 8x12x0.5 washers.
                                The arm connected pulleys are connected with screws to the arms, so they cannot slip when only connected to the shafts.
                                One thing to be aware is, if turning off or installing new firmware, the steppers loose current and the robot arms fall down...
                                The rebuild to the prototype will have axis 1 below the robot on a plate, bigger pulleys and a better belt tensioning system.
                                • tony73undefined
                                  tony73 @JoergS5
                                  @JoergS5
                                  Hello ! I'm sorry but yesterday I couldn't write to you, I saw the photos, to understand better, are you using this robot with some modifications, or do you have another one? however you have already worked so hard to do this!
                                  • JoergS5undefined
                                    JoergS5 @tony73
                                    @tony73 I constantly change this one. I am currently redesigning axis 1 and 2 and making the axis pulleys bigger. Then I will be able to install the extruder and print.
                                    The most work are the constant iterations, especially assembling and disassembling. I wished I have a robot who assembles it for me.... I could spare some effort with a good design program, but to understand some of the principles, I have to experiment.
                                    Currently important aspects to build the robot are:
                                    • hinges and arms without play and wobble
                                    • maximizing possible angles
                                    • find optimal gear ratio and avoid belt slippage
                                    • balancing the arms, avoiding counterweights by replacing the steppers (the steppers function as counterweights)
                                    • a procedure to protect against power off and arms falling down
                                    • tony73undefined
                                      tony73 @JoergS5
                                      @JoergS5
                                      from the photos it seems to me that you have steppers with planetary gear motor 1:27 primary pulley how many teeth? secondary 60 teeth, the steppers are cut to what, full pitch, 1/2, 1/4, 1/8, 1/16, 1/32, etc .... the gearmotor how much size at birth? I would like to understand how much reduction is needed! since you would like to put 200 tooth pulleys instead of 60 tooth ones.
                                      • JoergS5undefined
                                        JoergS5 @tony73
                                        @tony73 the gears were only for testing (and at axis 2 I had space problems), I want to avoid them because they have backlash. I will use a two or three step belt gear or a self constructed harmonic drive (axis 5). A 20/60 and 20:200 will result in 1:30.
                                        • tony73undefined
                                          tony73 @JoergS5
                                          @JoergS5
                                          60 ÷ 20 × 200 ÷ 20 = 30 reduction 1: 30 right? do you want to eliminate cycloidal motor reducers, are they the ones that have play? have you already solved the problems of movement on x coordinates?
                                          • JoergS5undefined
                                            JoergS5 @tony73
                                            @tony73 yes this is my calculation, I hope 1:10 at the last stage is enough, I will have to test it*). I had to stop firmware test, but the X values of M114 were ok, they were the world coordinates (mixing: xyz = world coordinates and UV = angles). There may be the bug: comparing X world coordinates with M208 angle of X.
                                            *) I calculated the Nm of the stepper, this was enough torque for a 60 tooth. But the belt slipped and I had to use a lot of tension to avoid it. It has an effect on wobble also, depending on acceleration/speed, weight and gear ratios.
                                            I am currently working on Axis 1 and will publish images when finished. I like cross roller bearings, but they are very expensive at the 300 mm size (hundreds of bucks), so I am building a DIY-able substitute.
