    Bad color, After update
    PanelDue
    paneldue
    704
    • bastienundefined
      bastien
      Hi, i just install firmware 1.24 on my paneldue( fysetc 7i) and now the screen color is bad!1593965397521962011944206099111.jpg
      • A Former User?
        A Former User
        sounds like you might have used the wrong file?
        https://github.com/Duet3D/PanelDueFirmware/releases/download/1.24/PanelDue-5.0i-7.0i.bin is this the one you used?
        bastienundefined 1 Reply Last reply Reply Quote 0
        • bastienundefined
          bastien @A Former User
          @bearer yes
          I try 1.22 and 1.17e, same problem
          • A Former User?
            A Former User
            @bastien said in Bad color, After update:
            fysetc 7i
            hmm, are you sure its a 7i design ?
            Looks a bit different to my 7i, maybe try PanelDue-v3-7.0.bin instead?
            • bastienundefined
              @bearer yes thanks, it's normal panel
              • skymasteresundefined
                skymasteres
                Has there been any resolution to this issue? I am having the identical problem
                  what firmware version does Fysetc supply it with?
                  • A Former User?
                    A Former User @skymasteres
                    @skymasteres said in Bad color, After update:
                    as OP never posted anything else I took it to be solved by using the regular PanelDue v3 binary
                      jay_s_uk
                      There was another user with a fysetc 7i and they had to use the v3 firmware to get the right colours
                      • TrevJonezundefined
                        TrevJonez
                        I just picked up a few of these fysetc panels (LCD800480 V1.1). The important thing to look at is that yes its more like a paneldue 7i in form factor, but the back of the pcb says it is based on the paneldue v3 not the 7i. So once I flashed the board with PanelDue-v3-7.0.bin files everything was as expected now.
