    Homing advice
    3.0k
    • agent0810undefined
      agent0810
      Hey guys, new to 3d printing and Duet as well so thanks for help in advance.
      i have it all setup, wired in and just trying to finish setup now so i can start printing/tuneing.
      when i do the home all option this is what i finish with:
      Status
      Idle
      Mode: FFF
      Tool Position
      X
      0.0
      Y
      0.0
      Z
      300.00
      when i try to print it seems like its trying to go further into the x stop cuz i hear clicking and grinding. then after that finishes the bed lowers to the bottom all the way.
      any advice? thank you!
      • aidarundefined
        aidar
        Hey. For start please post your config.g file as well as all homing files. Also would help if we know what board it is and what firmware version are you running on it.
          agent0810
          thanks for the reply 🙂
          Board: Duet 2 wifi
          Firmware: 3.1.1
          Printer: Ender 5 Pro
          Config.g:
          ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jul 05 2020 20:32:26 GMT-0500 (Central Daylight Time)
          M550 P"Schaal3DPrinter" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S1 ; enable FTP
          M586 P2 S1 ; enable Telnet
          M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
          M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
          M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X225 Y225 Z300 S0 ; set axis maxima
          M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
          M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
          G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
          M557 X15:215 Y15:195 S20 ; define mesh grid
          M501
          Homing files:
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jul 05 2020 20:32:27 GMT-0500 (Central Daylight Time)
          G91 ; relative positioning
          G1 H1 X-230 Y-230 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y5 F6000 ; go back a few mm
          G1 H1 X-230 Y-230 F360 ; move slowly to X and Y axis endstops once more (second pass)
          G1 H1 Z305 F360 ; move Z up stopping at the endstop
          G90 ; absolute positioning
          G92 Z300 ; set Z position to axis maximum (you may want to adjust this)
          ;G91 ; relative positioning
          ;G1 Z5 F100 ; lift Z relative to current position
          ;G90 ; absolute positioning
          ; Example Homing file for RepRapFirmware on delta printer
          M117 Use https://configurator.reprapfirmware.org/ to set up your printer config
          ;G91 ; use relative positioning
          ;******* Change F250 in the following line to F2500 when you are finished commissioning
          ;******* Change 320 in the following to a higher value if your Kossel has taller towers
          ;G1 S1 X320 Y320 Z320 F2500 ; move all carriages up 320mm, stopping at the endstops
          ;G1 S2 X-3 Y-3 Z-3 ; move all carriages down 3mm
          ;G1 S1 X6 Y6 Z6 F250 ; move carriages slowly up 6mm, stopping at the endstops
          ;G1 Z-5 F2000 ; down a few mm so that we can centre the head
          ;G90 ; back to absolute positioning
          ;G1 X0 Y0 F2000 ; centre the head and set a reasonable feed rate
          ; homex.g
          ; called to home the X axis
          G1 H1 X-230 F1800 ; move quickly to X axis endstop and stop there (first pass)
          G1 H2 X5 F6000 ; go back a few mm
          G1 H1 X-230 F360 ; move slowly to X axis endstop once more (second pass)
          G1 H2 Z-5 F6000 ; lower Z again
          ; homey.g
          ; called to home the Y axis
          G1 H1 Y-230 F1800 ; move quickly to Y axis endstop and stop there (first pass)
          G1 H2 Y5 F6000 ; go back a few mm
          G1 H1 Y-230 F360 ; move slowly to Y axis endstop once more (second pass)
          ; homez.g
          ; called to home the Z axis
          G1 H1 Z305 F1800 ; move Z up until the endstop is triggered
          Thanks again for the help!
            This sounds like a case of incorrect coordinate system.
            Please have a look at these posts
            https://forum.duet3d.com/topic/12676/mirrored-x-axis/9
            https://forum.duet3d.com/topic/14971/vcore-pro-core-xy-the-x-and-y-axis-home-issue/4
            Basically, you must decide where the front of your printer is when you're looking at it. Then the front left corner is the origin point 0,0.
            The homing position is where the endstops are. They aren't always going to be at 0,0.
            Is the X endstop on the left or right?
            Is the Y endstop at the front or back?
            The M574 commands that define the endstops must match where they physically are. High or low end of travel.
            +X moves to the right, -X to the left. -Y to the front, +Y to the back.
            The homing files must move towards the endstops.
              agent0810
              Thanks for the reply!
              ill def have a look at those posts.
              and this maybe where im getting confused. the stops are in the back right corner. i thought that was 0,0. right now +x moves to the left and +y moves towards me or what im calling the front of the printer.
                So you have the choice of either viewing the "back" of the printer as the "front" and choosing the back right corner as 0,0 and the homing position, or choosing the front left as 0,0 and the homing position at the high end of travel in the back right corner.
                Either way is fine, but you need to be careful that you don't get an axis flipped which can lead to printed models being mirrored from what the slicer shows since the slicer is assuming the 0,0 position is in the front left and +X moves to the right, -X to the left. -Y to the front, +Y to the back.
                  agent0810
                  so i think i would like to keep the Back of the printer as the 0,0 since that is where the stop switches are. but im still confused on what i need to change to make that happen. i know im being a complete noob and i apologize for that .
                    Well 0,0 and the endstops don't have to match. Homing to the high end of travel is fine. This has the benefit of staying matched with the slicer view and stays consistent with the language normally used with printers, namely the right handed coordinate system, meaning +X moves to the right, -X to the left. -Y to the front, +Y to the back.
                    Here are some illustrations.
                    So in your case, here's what you need to change in your config.
                    M574 X2 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop
                    M574 Y2 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop
                    Instead of X1 and Y1, it's not X2 and Y2, for the high end of travel, back right corner.
                    And change the directions of travel for the homing moves from negative to positive.
                    ; homeall.g
                    G1 H1 X+250 Y+250 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                    G1 H2 X-5 Y-5 F6000 ; go back a few mm
                    G1 H1 X+230 Y+230 F360 ; move slowly to X and Y axis endstops once more (second pass)
                    ; homex.g
                    G1 H1 X+250 F1800 ; move quickly to X axis endstop and stop there (first pass)
                    G1 H2 X-5 F6000 ; go back a few mm
                    G1 H1 X+230 F360 ; move slowly to X axis endstop once more (second pass)
                    ; homey.g
                    G1 H1 Y+230 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                    G1 H2 Y-5 F6000 ; go back a few mm
                    G1 H1 Y+230 F360 ; move slowly to Y axis endstop once more (second pass)
                      agent0810
                      thank you for the detailed explanation, makes a little more sense now. still working on understanding the settings though. i made you suggested changes and now the extruder is in the front right corner and when i do home all sits there and bangs over and over when each of the axis homes.
                      X+ currently moves to the left
                      Y+ moves towards myself or the front
                      Z+ moves the bed up
                        Did you copy and paste my homing files into yours?
                        And just to confirm...
                          agent0810
                          yes sir, copied and pasted.
                          The Y is in the back right corner.
                          The x is on the right,
                            @Phaedrux said in Homing advice:
                            M574 X2 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y2 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop
                            And you changed M574 to X2 and Y2?
                              agent0810
                              yes sir copied all 3 homing files and pasted over mine.
                                Alright, then we may need to change a motor direction.
                                Try
                                M569 P0 S0
                                M569 P1 S0
                                  agent0810
                                  That may have done it.
                                  X+ Moves to the right !!!!!!
                                  Y+ Moves to the Back!!!!
                                  Z+ Moves up!!!!!
                                  so after i home, the "position tool" says its X - 225.0, Y 225.0, Z - 300.00 thats what i want right?
                                    Phaedrux Moderator @agent0810
                                    @agent0810 said in Homing advice:
                                    Are those negative values?
                                      agent0810
                                      no dashes,
                                      Status
                                      Printing
                                      Mode: FFF
                                      Tool Position
                                      X
                                      225.0
                                      Y
                                      225.0
                                      Z
                                      300.00
                                        The last thing to check is that when you move to 0,0 it's at the corner of the bed. If it's not, then you'll have to adjust the M208 maxima values.
                                          agent0810
                                          so when i "home all" it sends it to the back right corner. when i got to 0,0 it goes to the front left corner. when i try to start a print, it starts in the back right corner, bangs against the stops then the bed starts to lower all the way.
                                            What do you have in your start gcode?
