Ender 5 Duet Wifi 2 and BLTouch 3.1
Ok so I am new to to the BLTouch and the Ender 5. I have currently updated it to a Duet wifi 2 and a meanwell PSU. I got the printer to work last night fine with manual leveling and end stop switches. I have been using the RRF Config tool to get the BLTouch to work with little success.
Currently the probe will extend but not retrack after powering up. It will not trigger as an endstop ( I unplugged the original) for homing.
Config.g; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jul 06 2020 13:33:30 GMT-0500 (Central Daylight Time); General preferences
M550 P"Ender 5" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M350 X16 Y16 Z16 E16 I0 ; configure microstepping without interpolation
M92 X80.00 Y80.00 Z400.00 E96.15 ; set steps per mm
M566 X600.00 Y600.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X30000.00 Y30000.00 Z600.00 E600.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z200.00 E4000.00 ; set accelerations (mm/s^2)
M906 X850 Y800 Z700 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X220 Y220 Z300 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"duex.pwm1" ; create servo pin 0 for BLTouch
M558 P9 C"!zprobe.in+zprobe.mod" H5 F0 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P0 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:195 Y15:195 S20 ; define mesh grid; Heaters
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P0 S1 H0 T45 ; set fan 0 value. Thermostatic control is turned on
M106 P1 S1 H0 T45 ; set fan 1 value. Thermostatic control is turned on
M950 F2 C"fan1" Q500 ; create fan 2 on pin fan1 and set its frequency
M106 P2 S0.3 H-1 ; set fan 2 value. Thermostatic control is turned off; Tools
homeall
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jul 06 2020 13:33:32 GMT-0500 (Central Daylight Time)
G91 ; relative positioning
G1 H1 X-225 Y-225 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-225 Y-225 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X15 Y15 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioningdeploy and retract
M280 P0 S10
M280 P0 S90
@TheBiologist said in Ender 5 Duet Wifi 2 and BLTouch 3.1:
M558 P9 C"!zprobe.in+zprobe.mod" H5 F0 T6000 ; set Z probe type to bltouch and the dive height + speedsHow do you have the BLtouch connected? Do you have a duex?
Depending on where you have the servo control wire connected, you may need to change the pin name used by M950. I think there is a bug in the configurator that is showing the wrong pin choices for the PWM servo control.
If you're connected to expansion header 3 like shown in the connecting a bltouch doc it should be like this:
; Z-Probe M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch M558 P9 C"!zprobe.in" H5 F0 T6000 ; set Z probe type to bltouch and the dive height + speeds
@Phaedrux said in Ender 5 Duet Wifi 2 and BLTouch 3.1:
M558 P9 C"^zprobe.in" H5 F0 T6000
@DIY-O-Sphere Good eye!
Awesome I will try that. Thanks for the quick reply
@Phaedrux yes I have it wired like in the photo. I made the suggested changes but bltouch still does not power cycle instead is flashing red at a slow steady rate. When I tried to rest the bltouch i get Error: M280: Invalid servo index 0 in M280 command.
Please send M115 to verify what firmware version you are actually using.
Then send M98 P"config.g" in the console and report the results.
m115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-12-24b1M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Warning: M950 command is not supported
Warning: M308 command is not supported
Your config is for RRF3, but your firmware is RRF2
You have to update the firmware.
First to 3.0 after that go to 3.1.1
@DIY-O-Sphere ok I have now successfully updated to 3.1.1. I am still not getting the bltouch to work. It still will not self test on power up. It drops the pin and then starts blinking red light. I have checked the wires and all connections are good. This is a legit BLTouch with their wiring.
M98 P"config.g"
M98 P"config.g"
FTP is disabled
TELNET is disabled
Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
Error: Pin 'fan1' is not free
Error: Fan number 2 not foundm115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
Fixed the fan error. Not sure what to do with the heater error or that the z probe is reading 1000 like it is being triggered.
What happens if you connect only 5v and ground? That should cause it to self test. If it's still failing on self test check the pin. You can remove the grub screw on the top of the body and remove the pin. Maybe it's bent or dirty.
If it's still failing self test try and send the error reset command and then try and deploy and retract again.
What do you have in your config.g and deploy and retract now?
This is just telling you what it thinks your bed temp could reach if it fails on. To get rid of the warning choose a lower powered heater. Otherwise, just be aware. Don't leave it unattended. Have a fire extinguisher handy. Smoke alarm. Thermal cut out fuse.
Did you change your ! to a ^ in the M558 as pointed out by @DIY-O-Sphere ?
If you did change that and it's still showing 1000 all the time, that could mean the probe is damaged, or there is a problem with your white signal wire.
@Phaedrux The probe cycles twice and then starts blinking red.
M558 P9 C"^zprobe.in" H5 F0 T6000 ; set Z probe type to bltouch and the dive height + speeds
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan1 and set its frequency
Deploy and retract
M280 P0 S10 ; deploy BLTouch
M280 P0 S90 ; retract BLTouch
@Phaedrux it is just the factory ender 5 bed heater. Is that normal?
Don't set it to P0. That meas triggered at not triggered. Use G31 P25
You need a feed rate set too. Use F60.
yeah it's not uncommon to see the warning. It's a motorized hot plate with wifi afterall.
@Phaedrux Thanks for the help! SO far so good. I will try leveling the bed tomorrow.
@Phaedrux So turned on the printer first thing this morning to try and calibrate the bltouch and went right back to the same issues. I am begining to suspect bad wire in the cable so I have ordered another. Not sure what else it could be. It was working just fine last night. Tested it unmounted, turned it off and mounted it, and then turned it back on this morning.
