Duet 3 rrf 3 BLTouch
I have had my BLTouch working. Things going fine. Now it stays triggered no matter what I do. No changes to wiring or config.
@mrenz999 If you could post your Config.g that would help diagnose your issue. Also your homez.g and homeall.g if they use the BLTouch for homing.
@mrenz999 said in Duet 3 rrf 3 BLTouch:
What do you mean stays triggered? What have you done?
@Phaedrux maybe he has the same issue I had and it is interference with his stepper motors. It possible it was working for testing then he tried to print and now it doesn’t work? We can only guess.
@mrenz999 Try sending an M18 E0 command before you attempt to use the probe.
@Phaedrux Sorry long work days. I unplugged the BLTouch on both side and plugged it back in. Hard reset and now it is working. Sorry it took so long to get back to you guys.
