New IR z probe issues
 @Phaedrux
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2M98 P"config.g"
HTTP is enabled on port 80
FTP is enabled on port 21
TELNET is enabled on port 23
Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 209C; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jul 05 2020 20:32:26 GMT-0500 (Central Daylight Time); General preferences
M550 P"Schaal3DPrinter" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives
M569 P0 S0 ; physical drive 0 goes forwards
M569 P1 S0 ; physical drive 1 goes forwards
M569 P2 S0 ; physical drive 2 goes forwards
M569 P3 S0 ; physical drive 3 goes forwards
M92 X80.00 Y80.00 Z800.00 E102.30 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X225 Y225 Z300 S0 ; set axis maxima; Endstops
M574 X2 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop
M574 Z1 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop; Z-Probe
M558 P1 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M501![0_1595371433780_B5BF8F32-97A5-4454-A1BB-D0C398173C08.heic] -
That mount seems to put it at a bit of an angle?
yea the mount isnt the best but the best i can find right now. ive stood there and pushed it level and made sure it is. i make sure it is for tests, but same results. right now when i home/or print it runs the nozzle on the glass bed so nothing comes out.
Your trigger height in G31 is still the default 2.5. Your measured amount was closer to 1.7ish, so you need to update that. The trigger height would be more consistent if the mount was improved.
It is triggering now though right?
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
so when i do home all it goes up to the nozzle then back down a bit, then i do the G30 S-1 and it goes up to almost where i need it to be, so close. but still needs to go up a bit more. i have gone through the page alot and changed the offset and trigger heights with no luck. i tried at 1.7, 5, and now im at 0, all put it at the same place.
here is my config currently; Configuration file for Duet WiFi (firmware version 3)
M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 X50 Y0 Z0.005 ; set Z probe trigger value, offset and trigger height
M501 -
@agent0810 said in New IR z probe issues:
Sorry this doesn't make any sense to me.
Are you following the instructions on jogging the nozzle to touch the bed, sending G92 Z0, raising the nozzle a bit and then sending G30 S-1? That should give you a trigger height. You then put that trigger height value into the G31 Z. Then after rebooting and homing you should be able to have Z0 just touch the bed.
Doing everything you say there, except instead of raising the nozzle i am lowering the bed. that is what has me confused, from everything im doing i feel like i should be getting the results i want.\
and to be clear, what i put in G31 Z is the output on the console right?
thanks again
and to be clear, what i put in G31 Z is the output on the console right? so i would put in 1.501 for this?
7/21/2020, 10:55:50 PM G30 S-1
Stopped at height 1.501 mm -
Stopped at height 1.501 mmYes, that's correct. You can send
G31 Z1.501
in the console, then sendG31
to check it is set, eg my G31 response is:G31 Z probe 0: current reading 0, threshold 500, trigger height 1.250, offsets X20.0 Y0.0 Test that the probe is functioning correctly by homing Z, then move Z to 0 and check the nozzle is just touching the bed. Then modify your G31 line in config.g, so that the new setting persists after a reset. Change G31 line in config.g to:
G31 P500 X0 Y0 Z1.501 ; set Z probe trigger value, offset and trigger height Ian
@droftarts thank you!
did as you asked and it is still a little to high, its not pushing the filament onto the glass bed.
i have it zeroed in the middle of the bed. this is what i see on my web interface, that normal?
@agent0810 Adjust with 'Z babystepping' (on the Status tab of DWC), until you're happy with how the first layer is going down. Presumably you'll need raise the bed a little, so this may be -0.1mm of babystepping, so you can reduce the G31 Z height by 0.1mm. If you do this, don't forget to reset babystepping (with M290 R0 S0) if you don't reset the printer.
Have you calibrated your extruder, though? If you haven't, it may be underextruding, which will also make it look like the nozzle is too far off the bed. So get that right, too.
What do you mean, zeroed? If you want X0 Y0 to be in the middle of the bed, you need to adjust M208. At the moment yours is set to:
; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X225 Y225 Z300 S0 ; set axis maxima So it's not surprising that, with the nozzle in the middle of the bed, X and Y are 120. To get X0 Y0 to be in the middle, you'll want something like:
; Axis Limits M208 X-120 Y-120 Z0 S1 ; set axis minima M208 X120 Y120 Z300 S0 ; set axis maxima See https://duet3d.dozuki.com/Wiki/Centering_the_bed_or_setting_the_bed_origin
started printing and had to z babyset +.05 to 1mm to get it where i need it.
Current Offset: 1.00 mmwhat do i need to do to keep it here?
@droftarts
print came out amazing, just need to have it default to the 1mm babystep. -
@droftarts
print came out amazing, just need to have it default to the 1mm babystep.While you can change the baby step setting in code you can also adjust the the trigger height setting of your Z probe to achieve the same thing - which is what I do.
If you used baby stepping to move the nozzle closer to the bed increase the trigger height setting by that amount.
If you used baby stepping to move the nozzle away to the bed decrease the trigger height setting by that amount.
@fcwilt
so if im currently at
G31 P500 X50 Y0 Z1.501and my current offset was 1 mm that i had to move the nozzle away from the bed. i need to decrease the Z from 1.501 to .501?
so
G31 P500 X50 Y0 Z.501?
i am fairly positive that i have tried that and it didnt work -
A larger G31 value results in the nozzle being closer to the bed.
@fcwilt
so
i am fairly positive that i have tried that and it didnt workIf you use baby stepping to move AWAY from the bed then the trigger height setting must be decreased.
If you're numbers are correct then that value is correct.
You can always determine the trigger height setting through trial and error, adjusting it up or down with G31, setting the Z=0 datum with G30 and repeating the process until moving to Z=0 has the nozzle just touching the bed.
@fcwilt
what is the P value in this line?
