    New IR z probe issues
    IR Height Sensor
    3.5k
      trigger sensitivity.
      • agent0810undefined
        agent0810 @fcwilt
        @fcwilt
        i am not sure what i am doing wrong. i set it to the .501 and its still to far from the bed, filament isnt sticking. im not sure where to go from here. since it was to far away i lowered it to 0 and its still to far away.
        droftartsundefined jumpedwithbothfeetundefined 2 Replies Last reply Reply Quote 0
          Phaedrux Moderator @Phaedrux
          @Phaedrux said in New IR z probe issues:
          A larger G31 value results in the nozzle being closer to the bed.
          If it's still too far away you're going in the wrong direction. Instead of 0.5 you would need to add to the value, so 2.5.
            droftarts administrators @agent0810
            @agent0810 Think of it this way; when the probe triggers, it sets the Z height to the Z offset. So when it triggers, it sets Z to 1.5mm. If you then move the bed up to Z0, the nozzle should be touching the bed. If it's still away from the bed, the Z offset needs to increase. From your numbers, it should probably be around Z2.5.
            There is also a guide to do this: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
            It may make a difference where you probe the bed. If you're homing over in the corner (and make sure the probe is homing over the bed if you do), then moving to the centre to print, it could be if your bed is not level, and the corner is lower or higher than the centre. You can check this manually (move the nozzle around to the corners of the bed, manually adjust bed level), or by getting mesh compensation going (https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation) and looking at the mesh it creates. You can also do three point levelling manually, if you have bed adjusters; see https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant
            • jumpedwithbothfeetundefined
              jumpedwithbothfeet @agent0810
              @agent0810 I have an ender 5 and i have had exactly the same issue, its enough to drive you mad! but any way it seems if you follow this process exactly it helped me sort it out.
              Important do NOT home the Axis's until the list tells you too!
              1. Turnoff printer!
              2. Turn on and go straight to config.g and change G31 Z to 0
              3. save and reset board
              4. heat bed to what ever temp you normally use and wait for it reach it (this is important on the ender 5 as the bed support is poor)
              5. Heat nozzle to your most used temp and wait!
              6. once both are heated now home all axis's ( i use the middle of the bed)
              7. Jog Z to zero ( the nozzle should be well off the bed)
              8. type M564 S0 into the console this will disable the axis limits
              9. jog nozzle down until it touches the bed or paper which ever you prefer
              10. type G92 Z0 into the console this resets the Z axis height
              11. turn nozzle heater off (can affect the BLtouch touch sensor reading not sure regarding IR sensor)
              12. now type G1 Z5 followed by G30 S-1 to do a single bed probe i made a macro to do this it helps!
              13. probe the bed at least 5 or more times and go to the console and take the average trigger height.
              14. save the trigger height in config.g G31 Z then the reset board and print! well after G29 that is 🙂
              i'm sure you have carried out all these steps but it seems its the sequence that works, hope this helps!
              Regards Jim
              6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                agent0810
                Thank you for the reply! I appreciate all your guys help! I did exactly as you said and I’m still having issues. The back(furthest from me) is to high, the nozzle pushes up against it and no filament comes out. The side closest to me is a little to low, the filament doesn’t stick, thinking about putting some tin foil below the front to raise my glass bed up a bit in the front. Thoughts?
                  Getting a good mechanical level to start with is always preferred.
                  agent0810undefined 1 Reply Last reply Reply Quote 0
                    agent0810 @Phaedrux
                    @Phaedrux does that mean you think the tin foil under the glass bed is a good idea? Thank you!
                    jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
                      @agent0810 have you tried printing out some bed supports you can find these on Thingiverse I have some fitted to my bed and it helps, I would also not use Foil under your glass plate, shiny things and IR probes don’t mix! I have literally just got back from screwfix with some high temp black paint for my bed plate 🙂
                      This what I have fitted to my ender, if you can even get on Thingiverse at the moment seems the site has gone c@£p again 😞
                      https://www.thingiverse.com/thing:3661405
                      Regards Jim
                      agent0810undefined 1 Reply Last reply Reply Quote 1
                        agent0810 @jumpedwithbothfeet
                        @jumpedwithbothfeet
                        Hmmm I have tried and I can’t get a good first layer to print them 😞
                          @agent0810 couple of questions....have you used hairspray etc on the bed? What does the height map look like maybe a screen shot? And when you probe the bed multiple times what do the readings look like?
                          Regards Jim
                            @jumpedwithbothfeet
                            I have not used anything on my beds, before trying to get this IR blaster working i was having awesome adhesion and first layers.
                            I have not done a heat map, ill look up how to do that.
                            Here are my readings from yesterday:
                            7/27/2020, 8:02:35 PM Connection established
                            7/27/2020, 8:02:20 PM Connection interrupted, attempting to reconnect...
                            HTTP request timed out
                            7/27/2020, 8:02:10 PM Upload of config.g successful after 0s
                            7/27/2020, 8:01:37 PM G30 S-1
                            Stopped at height 0.195 mm
                            7/27/2020, 8:01:23 PM G1 Z5
                            7/27/2020, 8:01:14 PM G30 S-1
                            Stopped at height 0.196 mm
                            7/27/2020, 8:00:58 PM G1 Z5
                            7/27/2020, 8:00:45 PM G30 S-1
                            7/27/2020, 8:00:25 PM G1 Z5
                            7/27/2020, 7:59:46 PM G30 S-1
                            Stopped at height 0.192 mm
                              Phaedrux Moderator @agent0810
                              @agent0810 said in New IR z probe issues:
                              G29
                              Those look quite good.
                                agent0810 @Phaedrux
                                @Phaedrux
                                Tried the G29 and the head moves to the front left corner (closest left corner to me) and errors out. im guessing the error is because the probe is on the left of the head so its not over the bed to be triggered.
                                7/28/2020, 3:24:43 PM Error: Z probe was not triggered during probing move
                                  Yes you'll need to modify your M557 command to keep the probe within the bed area bearing in mind the probe offset. That is to say, you need to position the nozzle so that the probe is in the right place.
                                    agent0810 @Phaedrux
                                    @Phaedrux
                                    M557 X15:215 Y15:195 S20 ; define mesh grid
                                    that is what my currently, what do you recommend changing it to?
                                      G31 P500 X50 Y0 Z0.005 ; set Z probe trigger value, offset and trigger height
                                      Is that probe offset correct?
                                        agent0810 @Phaedrux
                                        @Phaedrux
                                        i believe so.
                                          https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#main
                                          To optimize the mesh size you'll need to subtract the offset from the full axis length so that you're only asking it to probe areas of the bed the probe can physically reach. Otherwise the firmware will just skip the areas that it can't get to.
                                          So if the probe is 50mm to the right of the nozzle, and the nozzle can only go to x0, then the probe can only reach x50. So that's the minimum on the X side for M557. Make sense?
                                            agent0810 @Phaedrux
                                            @Phaedrux
                                            the probe is on the left of the nozzle when im looking at it. so should it be -50?
