    My BLV MGN cube build/upgrade saga (ongoing)
    My Duet controlled machine
    11
    54
    8.9k
    • whopping pochardundefined
      whopping pochard
      Very cool! Love to see the ballscrews.
      Looking forward to seeing the finished product!
      • Vetiundefined
        Veti
        the bed is rock solid and does not move under pressure.
        • MartinNYHCundefined
          MartinNYHC
          @Veti Can you please share details of your reinforcement rods and mounts? Where can I get them?
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti @MartinNYHC
            @MartinNYHC
            4x 8mm linear rods (had them from an old printer)
            8x SK8
            https://www.robotdigg.com/product/126/SK8-Linear-Shaft-Support-Unit
            4 SCS8LUU (screwed into 2020 profile with m3 t nut)
            https://www.robotdigg.com/product/422/SCS8LUU-Linear-Block
            2 Nema 17 2020 mounting brackets (the store from which i ordered does not sell them anymore, similar item)
            https://www.aliexpress.com/item/32892098907.html
            2 SFU1204
            the sfu1204 mount will be replaced with when i replace the other parts with the blv metal kit
            https://www.aliexpress.com/item/4001120210864.html
              MartinNYHC
              Thanks @Veti
              • fcwiltundefined
                fcwilt
                Simple can work as well.
                The part with the V groove attaches to the bed support frame, which is not shown for clarity purposes.
                I like seeing the wide variety of solutions to common issues.
                • flux_capacitorundefined
                  flux_capacitor
                  Amazing mod! The independent triple z-axis system from @Nuramori seems unavailable though: the zip file on Thingiverse contains only one small file (chain_mount_-_bed.stl). What happened to the design?
                  dhusoloundefined Nuramoriundefined 2 Replies Last reply Reply Quote 0
                  • dhusoloundefined
                    dhusolo @flux_capacitor
                    @flux_capacitor That's because he's using a different source file due to all the changes he's done.
                    Z Drive System.zip
                    If you want to stay up to date with the project join the facebook page. Thingiverse went to crap after their last update and they don't seem to keen on fixing it.
                    Nuramoriundefined 1 Reply Last reply Reply Quote 1
                    • Nuramoriundefined
                      Nuramori @dhusolo
                      @dhusolo Yep, thingiverse crapped the bed.
                      I should look at putting things on github instead.
                      • psychotik2k3undefined
                        psychotik2k3
                        @whopping-pochard you said: "The IR sensor. The mini IR sensor, presumably a clone, appears to have an old version of the firmware which causes premature triggering."
                        How can i check the firmware version and mitigate this ? thanks.
                        • Nuramoriundefined
                          Nuramori @whopping pochard
                          @whopping-pochard said in My BLV MGN cube build/upgrade saga (ongoing):
                          @Nuramori thanks for your beautiful design! It was a big inspiration for this. 😄
                          Happy to help! Looks great!
                          • Nuramoriundefined
                            Nuramori @flux_capacitor
                            @flux_capacitor if you need it let me know. I'm on here too... 😛
                            • Pro100sanek23undefined
                              Pro100sanek23 @whopping pochard
                              @whopping-pochard
                              hi, can you share a link or files of the back wall and electronics mounts? thanks
                                whopping pochard
                                As far as I gathered, if it displayed the issue, it had the old firmware. Specifically, what it looked like was it would trigger twice -- once around 8-11 mm away, and once at the proper trigger height of ~2-3 mm. You could see it as a sort of intermittent illumination at the 8-11 mm distance. I don't think you could actually check the firmware directly without an AVR programmer, which I didn't happen to have. I solved the issue by buying a genuine part. 🙂
                                I will carve out some time to update my files this weekend. I'm now hosting at PrusaPrinters because Thingiverse is too unreliable. Will ping here when I get them up!
                                -j
