Dimensions on a printed part
  • Hello there! I have been working on a CoreXY printer for a couple years on and off. Its based on the HyperCube Evolution.
    I have always managed to get decent prints with it, but the dimensions of the printed part has always been a bit off.
    Some information that may be relevant:
    • Im using Simplify3D
    • Sensorless homing on X and Y axis
    • BLTouch on Z axis
    • Im using linear rails and not rods. I had some issues with flexing rods earlier
    • Heated buildplate
    • Partcooling fan
    I have printed XYZ cubes with the dimensions 20x20x20mm. The Z axis dimensions is not an issue, but the X and Y axis is where im struggling. I printed 4 XYZ cubes after swapping to the linear rails. Two in 100% size(20x20x20mm) and two in 200% size(40x40x40mm). One of each size is printed in the middle of the build plate and the other is printed in the homing corner of the build plate. The build plate itself is leveled with the BLTouch and adjusted by using the bed map you get in duet.
    I made a little sketch to visualize where I have been meassuring the cube:
    • 1 is for one side of the X axis and 2 is the opposite side of the X axis
    • 3 is for one side of the Y axis and 4 is the opposite side of the Y axis
    Meassurements:
    Print one(100% middle of build plate):
    1. 20.20mm
    2. 20.00mm
    3. 20.14mm
    4. 20.06mm
    Print two(100% homing corner of the build plate):
    1. 20.20mm
    2. 20.00mm
    3. 20.14mm
    4. 20.06mm
    Print three(200% middle of build plate):
    1. 40.00mm
    2. 40.00mm
    3. 40.13mm
    4. 40.13mm
    Print four(200% homing corner of the build plate):
    1. 40.60mm
    2. 40.60mm
    3. 40.20mm
    4. 40.20mm
    What I can't figure out is why im getting diffrent dimensions on the same axis. When I printed the 200% XYZ cubes I expected the dimensions to be more off compared to the 100% version(thought the rails was not fully square). It seems to be more accurate with the 200% compared to the 100% versions as they are the same dimension on each side of the axis.
    I have meassured the frame several times to make sure its fully square. I don't belive its the frame as the dimensions is not more off with larger prints. Does anyone have any idea what this might be?
  • Any time you use a caliper to make a measurement, there is some error. That error doesn't scale with the size of the object unless there's a huge difference in the size. That means the error is a larger percentage of the 20 mm cube than the 40 mm cube. If you set steps per mm based on measurement of a 20 mm cube, the error gets multiplied when you print larger objects. If you set steps/mm based on a much larger object, when you print smaller stuff, the error gets divided. The percentage error remains constant, but what counts in the real world is the absolute error. Always calibrate steps per mm with the largest object you can reliably/accurately measure.
    A 20 mm cube is too small to calibrate anything. If you print at "normal" speed, the previous layer plastic hasn't cooled before the nozzle comes along and dumps more hot plastic on top of it. That sort of thing leads to "soft" looking small prints when compared to larger prints made on the same machine. If you have to use a 20 mm cube, print a few of them at a time to allow each to cool sufficiently before a new layer starts.
    A common 6"/150 mm caliper can measure a 100 mm cube, including the diagonals. Use a 100 mm cube if you have a 6" caliper. Measuring the diagonals of rectangular/square prints will confirm that the X and Y axes are square (the diagonals will be the same length).
    Measuring prints at the corners is generally not a good idea- if the acceleration and extrusion aren't dialed in perfectly, the dimensions measured at the corners will usually be larger than the dimensions measured at the center of the object. Corners are where the print speed varies because of acceleration, and all the nonlinearities of extrusion tend to show up.
  • @mrehorstdmd said in Dimensions on a printed part:
    Thank you for your explanation! When reading it I feel a bit silly for not meassuring the diagonals earlier πŸ˜‘
    I found this model that seemed like a good choice for meassuring: https://www.thingiverse.com/thing:4018438
    I will update my post once im done with some further testing.
  • I have printed one of the models I mentioned above above and im a little confused by the meassurements.
    Here is a picture of the dimensions of the octagon model:
    The A and B diagonals are the same length, so that means the belts should be good?
    What I don't understand is the diffrence between the X and Y axis. This seems to me like the linear rails are not lined up right? I have checked that several times now and it should be correct 😧
  • Moderator
    Are you using calculated steps per mm or are they derived from measurements?
    When you changed to the linear rails did the parallelality (is that even a word?) of the belts change at all?
    Can you post a photo of your printer looking down at it from the top to show the belt paths clearly?
  • Im using the default 80 steps/mm. I have made some changes to the extruder steps to tune it in.
    I can't say im 100% sure wether the belts changed - they are going in the same form as the old setup, but the angle might be a bit off?
    I havent been modelling the parts myself, but if it helps here is a link to what I have been using: https://www.thingiverse.com/thing:2859666
    Picture from the top of the printer:
    Let me know if I should take pictures from another angle.
    Thanks alot for your input!
  • Moderator
    In your first photo the belt paths returning to the carriage don't seem to be parallel with the rail.
  • You're right!
    Not really sure where to go from here though.. I need to find out wether its the models that are wrong or if its the printer I printed the parts on that is dialed in wrong. There are no way to adjust the belt angle with the current build 😧
    Thanks for spotting the error πŸ‘
  • Moderator
    Correcting the belt path will be the first thing to solve. You'll never get accurate prints with belts like that because the carriage position will vary as it gets closer to the edges as the angle of the belt changes.
    What does the carriage look like where the belt attaches? Can you modify it to move it over a bit? You got the parts from thingiverse. Do they also have the source files? What is different in your build from their build?
  • I get that part, and I "know" what to do to fix it, I just lack the experience with modelling parts.
    The belts are going through a hole and is clamped down.
    By looking through the holes top-down on the X axis rail I can clearly see the belt in the center of the rail where it comes from the Y axis, and is way off center towards X min. I would have to move the hole by 1-2mm.
    The reason I thought it could be the parts is just because I have not seen alot of feedback on the remixed parts. I started out with a Hypercube Evolution and moved to HyperCube Fusion, but sinse im using the Zesty Nimble and could not find a mount that would fit it I ended up with a remixed version of the Fusion.
    The fusion360 file is uploaded with the project, but I will have to do some learning before beeing able to edit it there. I have only been messing around with simple models in 123D Design.
  • Moderator
    @Jaran said in Dimensions on a printed part:
    If you can give me an absolute best educated guess on how much it needs to move I can give it a nudge in Fusion 360 for you and upload the STL.
  • That would be fantastic if you have the time! πŸ™‚ However I think there might be an issue with the cad file.
    I just tried to open the file myself, and got an error saying "New design cannot be created from a local file containing references". Im guessing this is because its remixed from the "original" Hypercube Fusion design. Is there any way to know whats missing and add it in?
  • Achieving dimensional accuracy isn’t as simple as a single scale measurement. I use S3D for slicing and it has X, Y, Z part scaling plus a horizontal offset. I don’t know IdeaMaker well, but I’m guessing X and Y-axis compensations in the Printer Settings dialog work for XY scale. Part Scaling can also work, although I don’t know why they have chosen Width Depth and Height over X, Y, and Z. Under the OTHER tab, XY size compensation may be the same as S3D’s Horizontal Offset.
    Attached you will find a part I'm calling a Calibration Cross - STL and JPG drawing. It includes internal and external features, both large and small. I have also attached an Excel Spreadsheet (Zipped) which allows you (by trial and error) to see the impact of scaling and horizontal offset values in correcting part dimensions.
    Print off a Calibration Cross with no scaling and no horizontal offset. Enter the measured values into the spreadsheet and experiment with different X & Y scale factors as well as the horizontal offset value to minimize the resulting error on all of the measured dimensions. The solver add-in can help narrow in on the best values.
    Whenever I’m going to print using a new setup, filament, significantly different print speed, layer height, temperature, etc, I start by running a Calibration Cross and use the spreadsheet to calculate scaling and offset numbers. This technique has proven to be a reliable way to ensure dimensional accuracy on parts. The Z-scale on my N2+ has proven to be quite accurate, so I just use 100% on that.
    I can generally achieve part accuracy better than +/- .1mm (.004") on all dimensions.
    calibration-cross.xlsx
    calibration-cross.stl
    100mm.stl
  • Moderator
    Yes I just ran into the same problem opening it up.
    You'd have to have all the referenced files from the hypercube fusion in place alongside it I think. Perhaps you could request the original remixer export a simple step file of the piece in question so it can be more easily modified. Or maybe they can nudge it over the needed 1-2 mm for you.
  • @zemlin Thank you for your input! Im using S3D aswell. This will for sure come in handy, but first I need to get my belts fully aligned. I guess this could fix the issue with the belt if it comes down the the printed part beeing printed wrong, but I don't belive its that much off.
    @Phaedrux Tried a bit with the original Hypercube Fusion files but ended up with the same error. I read a few comments on the remix im using from people requesting the cad files aswell, but it seems like the creator has abandoned the design. Im at the point now where I think I might just move over to the original Fusion design and remix the hotend mount plate to suit the holes of the original hotend mount. Should only be 5 holes, I belive that is something I might manage myself πŸ™‚
    Thanks alot to all of you! I will post back once I have some updates.
  • Moderator
    Great chance to improve your fusion 360 skills.
  • @Phaedrux Sure is! I have been planning to pick it up. The few times I have had the need to model anything I have managed with 123D Design, but with the time I regret opting to that 🀠
  • Moderator
    The Lars Christensen videos on youtube are a great way to pick up fusion.
  • @Phaedrux Thank you! I will check his videos out.
  • A little update on this issue:
    I have finally swapped out all the parts for the X and Y axis and extended the Z axis to be able to reach the hotend. All in all these new parts feel alot more sturdy and well designed compared to the old parts I had.
    I did manage to model up a new mount for the Zesty Nimble im using. As im impatient I gave it a go in 123D Design and it worked out OK. I did not scale the mount holes up enough so it did not fit perfectly. Nothing the dremel couldnt fix... 🀠
    I had some issues fitting the parts together after snapping the hotend into its place as the part expanded a bit due to the preassure. I ended up breaking off some of the model to actually make it fit. The hotend sits sturdy even without the part I broke off.
    The whole setup does not look too nice, but it works. I will try to make it look better with the time.
    So, back to the dimensions:
    I have only printed a few calibration cubes and will have to do some more tests the following days, but so far it looks promising. The two cubes I have printed came out as 20.05x20.05mm and 20.05x20.05mm, so both came out with identical dimensions. I will print the calibration hexagon tomorrow.
    Even though the parts seem better now I still noticed that the belts going for the XY idlers to the hotend itself still seems a bit off like the old setup, though not as much.
  • Back to the drawingboard! Seems like im having the exact same issues with the dimensions when I printed the hexagon. The only change I made was swapping out the filament.
    I saw that the belt seem to have the same angle as the old parts. I tried to import the parts into fusion to see how they lined up:
    It does not look like the parts are fully lined up. If you look at the right side of the picture you can see the outline of the hole the belt goes into. The line is going from the top of that hole to a bit over center on the idler. Is this enough to make up the problems im having? I just find it weird how nobody else with the design have pointed it out πŸ˜•
    Is there a way I can verify that it actually is the belt doing it? If I loosen one belt and tighten the other, and vice versa I should see some changes on the dimensions depending on which belt is tight/loose?
